#15 | |
![]() ![]() Drives: 2018 Redline Edition 2SS Join Date: Dec 2014
2018 Redline Edition 2SS- A8, NPP, MRC, Recaro seats, ECS Novi 1500 tuned by EFX, cat deletes, Mighty Mouse Wild CC, GM STB, smoked ZL1 3rd brake light, Xpel XR Black 35% tint all around, Street Scene front splitter, C7 Carbon ZL1 side skirts Drake Muscle Car wicker bill, Adams Polishes Ceramic Coating
2010 Infiniti G37x Sedan for the DD. Last edited by FrostySS; 07-19-2018 at 09:29 AM. |
#16 |
![]() Drives: Wicked Fast Join Date: Sep 2010
So avg max whp on lt1 before it likes to pop? 700-800 whp?
#17 | |
![]() ![]() Drives: 2017 Camaro SS 1LE (F1A-94 FBO H/C) Join Date: Jun 2017
your forgetting much more to keep that setup up and running..Goodluck
Performance Mods: F1A-94, DSX Flex Fuel Kit, MSD Spark Plug Wires, KOOK 2" off road headers, MBRP Race catback exhaust, Pray Performance Custom Boost Cam, Rocker Arm Trunion Upgrade Kit, 7.850" Hardened Chromemoly Length Pushrods and Johnson Racing 2110R Lifters, TSP CNC'd Heads, Ported MSD intake manifold, 103mm Katech Throttle body, Forged Pistons/Rods, RPM Meth kit, DSX Aux Fuel system, AEM Failsafe and banks gauge, LT4 HPFP, LT4 injectors, BMR motor mounts, Hurst Short Throw, Manley SS exhaust valves
Videos of my car? Check here: https://www.youtube.com/channel/UCNi...Qy1OL4NVGlPogw |
#18 |
![]() Drives: 2ss Join Date: Jan 2018
#19 |
![]() Drives: 2017 SS Join Date: Jul 2018
My point is im not interested in spending 1000s to gain 80-90 hp..
#20 |
#coolstory
2010 Infiniti G37x Sedan for the DD. |
#21 | |
BAMF SS
But $6000 for a procharger p1sc kit that adds 130 hp is not. I cant make sense of your reasoning, but it's your car.
2016 1SS A8: FBO + Circle D + P1X + Meth + Tuned by Pray Performance
Stock Longblock 800 SAE rwhp. 9.4 @ 145 mph. Last edited by danhr; 07-28-2018 at 11:00 PM. Reason: I hate autocorrect |
#22 |
![]() Drives: 21 SS Join Date: Oct 2017
From tune with rotofab I gained 20, never found out #'s once I had e85, ported im/tb, headers because street tuned with those.
But I bought rotofab used and then dry filter so $3oo, katech tb $150, pray ported stock $300, skidmark e85 sensor $160, tx sp headers $900, tune 500 and retune $100 about $2400 all in
FBO, E85
11.1@123 |
#23 |
I already had HP tuners so ...
100.00 to unlock my ECM/TCM 200.00 for a reference tune to work off of from Pray 550.00 pray ported intake manifold/tb 400.00 Rotofab dry 250.00 lightly used CA performance cat deletes 160.00 SMG flex fuel sensor 1710.00 for 60-70whp...basically a low 11second combo. Drag pack would put it into the 10's.
#24 |
![]() ![]() ![]() ![]() ![]() ![]() Drives: '17 Camaro 2SS & '99 Camaro Z28 Join Date: Feb 2014
I'm of the belief the motor / block itself will handle well over 1,000 easily.. ..the weakness is, to get there you'll have to use boost - and you will run into issues with the pistons / rods long before you get there.
#25 |
Drives: All GM Performance Join Date: Jul 2011
One of our shop Camaros (16 1SS) made 410 rear wheel in stock trim. FBO it made 464 wheel.
After that, we did an AFM delete and cam swap to our new GenV Polluter Cam and made 530 wheel. That was with no head work. Our dyno has also been known to be on the stingy side. But those are SAE corrected numbers. |
#26 |
![]() Drives: 2016 2SS A8 Join Date: Feb 2016
E85 sensor - 300
PrayPorted TB/IM - 650 2in TSP headers - 600 Speed engineering X-pipe - 180 Roto Fab Wet - 430 $2160 Buy stuff on sale or get a combo deal from a dealer/installer and probably get all the stuff new for 2k. DYI Tune for 2016 - 150 (Extra credit needed on a A8 car that deletes the AFM exhaust actuators instead of zip-tieing them) Street Tune - 400 DYNO Tune - 550 2017s cost 200+ more to tune due to the locked TCM Don't know my exact gains, but I ended up with 488/493 for $2300. 2.5k average to be about 490/490 in a daily with E85 is about your best bang for the buck. 6k to be at about 550 is a pretty big jump in Dollar to HP/TQ ratio. Depending on how much a person can do themselves, going with GPI drag cam will put you in the upper 550 range, an run the do-it-yourselfer about 2500-ish depending on how crazy you get with overbuilding. 5k to be abouts 560ish on E85. A 1k savings, lot more work, but on the flip side you could always turn the boost up with the support of a LT4 fuel system. Just a matter of picking your poison.
16 Summit White 2SS-MRC-NPP-A8 :: PrayPorted IM - LT5 TB - Mishimoto Catch Can - RotorFab - E85 - TSP 2" LongTubes - Speed Engineering X/Mid Pipe
DIY Hpt Tune - DR - 1.75-60' - 7.47@95 - 11.56@120 with +2676DA |
#27 |
So I took the time to see what STD correction would be on the aforementioned 16 Camaro and it looks like it makes a solid 480/485 FBO.
Just like all other Chevrolet V8's form years past. The cam swap is the biggest power gain you can do. Other than forced induction. |
#28 | |
BAMF SS
curious on the actual list of mods, as well.
Stock Longblock 800 SAE rwhp. 9.4 @ 145 mph. |
