#15 |
![]() Drives: 2018 1SS 1LE & 1973 Datsun 240Z Join Date: Sep 2015
#16 | |
"M1SS1LE"
Drives: 2017 SS 1LE Join Date: Dec 2015
#17 |
I use a mag pad to jack up one side of the car, using the cutout in the rocker just behind the front most cutout as the jacking location. I then put the jack stands under the front and rear ZL1 Addons lift points on that side. I then do the same thing on the other side of the car. I use the 3 Ton Esco brand jack stands with the large rubber saddles (22% off on Amazon in Canada right now). They're the only type of jack stand I really feel safe resting those ZL1 Addons lift points on.
Nigel |
#18 |
![]() Drives: 2017 Hyper Blue A10 ZL1 Join Date: Dec 2016
I replace my wheels almost every week or so in summer due to racing. Never had an issue with the ZL1addon jack pads. However, I do have to take care that the jack is squarely on the jack pad. A few times, I noticed the jack was a little off with the jack pad lip catching the jack pad wrong. Even a little jacking had it slipping. Having no issues means that I have to get on my knees and look, but never a problem when I do take that precaution.
- Life is a highway... I want to ride it all night long...
Sold 2010 997 GT3, 2016 WRX, 2006 997 C2S, 2003 996 C4S, 2001 Boxster S, 1997 E420 AMG etc.. |
#19 | ||
![]() ![]() Drives: 2019 2LT 2.0T M6 Riverside Blue Join Date: Jan 2018
So 3 days went by and ZL1 addons did not respond to my initial email. I emailed them again and got the following response:
#20 |
![]() Drives: 2017 1LE Join Date: Nov 2017
^ concur...
'17 Bright Yellow 1LE. PDR, STB, !CAGS
Borla 60606, 11925. Tony Mamo ported TB, ROTOFAB, !Sound Tube |
#21 | |
![]() Drives: 2018 Camaro 1LE Summit White Join Date: Oct 2017
Damn,, why didn't I catch this? The saddle on my floor jack is under 4". Why did I purchase these pucks? Lick and Stick with just my floor jack on the pinch. |
#22 | |
My take on this? You should not be lifting the car from one pinch weld at one corner only. There is way to much weight and stress. Two jacks at the same time. Front or rear L&R. ( That's probably pushing it as well) The cutouts in our rockers accessing the pinch welds are for dealerships to use while lifting with a four point lift only. Distributing the weight at all four corners. |
#23 |
![]() Drives: 2024 ZL1 M6, 1969 Cessna Skylane Join Date: Jun 2018
I have the permanent ZL1 addon jack points installed and I have a good quality 3 ton floor jack. I’m trying to figure out a jack stand solution which would work on both the available pinch weld points and with the addon points as I can lift the rear up all at once from the middle point between the mufflers.
I have a screw jack that works great on the pinch weld. I’m thinking about getting another and using them as jack stands. I just need to figure out some kind of rubber pad to stabilize it on the addon points. https://www.amazon.com/gp/product/B07CZGTXYH/ |
#24 |
![]() Drives: 2018 ZL1/1LE Red Join Date: Oct 2013
On my set (pads and pucks)... larger for the front and shorter for the rear, in the channel outer walls I added a thin layer of adhesive corkpad.... When the pad/puck goes up the pinch weld metal is about dead center over the two magnets.
Honestly though, that channel should be 1/3rd less the size to accommodate 2 or 3 layers of material. They are way to wide as-is.
BobR
2018 ZL1 1LE (Red) - New Dec 2017 2015 ViperGT (Gunmetal w/Red stripes) 2013 ZR1 Anniversary 2014 ZL1 - BrightYellow, 6sp 2011 Porsche GT3RS - White w/red graphics 2009 Porsche C2S 2001 Ferrari 360 |
#25 |
![]() Drives: 2017 Camaro SS Join Date: May 2018
My solution for a screw jack fitting a ZL1 bolt on jack pad. Also tacked on 22mm nut. same as lug nuts.
#26 |
I was thinking about doing something along those lines, but I want to be able to switch between a saddle for the lift point and the existing one that works nicely on the pinch weld. So I’ll machine something similar which slides into the existing saddle.
#27 |
![]() ![]() Drives: 2017 50th Anniversary 2SS Join Date: Sep 2016
Nothing gives me more anxiety than jacking this car up. I've had mine do the exact same thing twice and have finally found a great solution.
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1 These line right up on the pinch weld and wide enough on either side of the pinch weld to support more of the frame for a solid feeling as you jack the car up.
#28 | |
![]() ![]() Drives: 16' Camaro E-Force SS Join Date: Jul 2016
I think car manufacturers are making it harder and harder for us to jack up our cars on purpose. It shouldn't be this ****ing hard and cause this much anxiety whenever we need to life the car.
Leo
2016 e-Force 2SS Instagram @cleoent |
