Old 06-29-2018, 11:58 AM   #15
Elite Engineering
Elite Engineering's Avatar
Drives: 2010 Camaro
Pray is correct. Only up to 85% of this can be prevented as the back filling of spent gasses causes some of the coking and cannot be stopped.
Meth injection would have to spray constantly to be much help as it is the cooling and cleaning of a fuel spraying on the valves that prevents this.
Venting will substantially reduce your engines life with the increased wear and the power robbing parasitic loss by the pistons pushing against that pressure is never good. Again, you will not find a Professional form of racing that "vents" Crazy for anyone to argue that leaving most of the wear and damage causing crap in the crankcase is somehow good. Venting only a small amount is pushed out.
Then as parasitic power loss is never good, why would one settle for it or the ring flutter issues that create far more crankcase blow-by issues?
Pull suction at all times on the crankcase. Learn from the Pros.
Elite Engineering is offline   Reply With Quote
Old 07-07-2018, 08:38 AM   #16
EDFHOBBIES
Dyno Show Queen LOL
EDFHOBBIES's Avatar
The deposits also depend on what your pouring into the motor as far as oil... No Joke. Euro grade standards ACEA vs API are a lot higher. Their oils are full of Additives that are bad azz for wear and generates a high TBN of 12 plus which is great (this leads to ultimate protection and long oil intervals) but now take a look at LOW ASH oil hardly near as much additives lower TBN of 8 something, that low of a TBN number is something you will see in cheap oil..
Some of the problem are the calciums and magnesiums and other additives that are whats depositing they are great for anti wear but burn terrible and gum up when in a heated situation. now with DI it even worse.
I work a lot on Diesel this is no new news to me really the diesel fleets having to conform a long time ago with Tier 4 low ash oil and sulfurs.
0.5 Ash is really good
less than 1.0 is SO SO
above 1.0 is high Ash
GM knows there's a problem they are trying to bandaid i think with this new 0W-40 low ash oil..
I'm probably going to use the Mobile 1 Euro 0W 40 w a TBN of 12.7 and a vented catch can vs the Dexos low ash ESP 0W -40 TBN of 8.5
Old 07-08-2018, 05:31 PM   #17
oldman
Drives: SS 6 speed of course
Intresting take on this. I'd like to the the results. So you won't run any crank case gas thru the intake (vented catch can)?
Old 07-08-2018, 05:32 PM   #18
oldman
Originally Posted by markblackwell View Post
Just Add Meth
I woner what a very small amount of water / meth sprayed in starting at a low boost level would do? I think only time would tell.
Old 07-08-2018, 06:46 PM   #19
EDFHOBBIES
Dyno Show Queen LOL
EDFHOBBIES's Avatar
Usually meth cleans very good.. good enough to clean the Teflon of the rotors of the blower. I would think it do good let's face it DI is for fuel economy and better atomization of the fuel so less fuel to clean areas like this.. can't hurt.
