Old 05-09-2018, 09:59 PM   #15
KingLT1
KingLT1's Avatar
Drives: 2016 1SS NFG A8
Pray Performance has a P1x car putting down over 660whp and ran 10.0 @ 138. A D1SC will damn sure make more then 520whp or something is wrong. That Blower should make 600+ on 9-10psi. I could see the base P1SC only making 520whp on 7psi. But then again Dyno numbers are meaningless without a baseline. They all read different...
Old 05-09-2018, 11:52 PM   #16
Inkedmongo
Drives: 2ss
Im confused because we have a member running a P1X on stock LT1 fuel system, 93 octane, no meth injection, 10psi of boost and hitting 600whp with no problems at all. but if you leave this thread and go up to the one where the guy just installed a P1SC at 7psi on pump gas he is saying his tuner showed almost out of fuel.
I think at this point I am going to just go LT4 fuel system, cam with +32% lobe, meth injection, and turn the boost up to about 10 to 12psi or so and stick with pump gas only (we only have 91 on tap here)
Anyone have a ballpark on what a D1SC stage 2 should be throwing down to the back wheels if throw on a bone stock LT1 with no mods at all?
Inkedmongo is offline   Reply With Quote
Old 05-10-2018, 06:34 AM   #17
DapperDan
DapperDan's Avatar
Drives: 2017 1SS A8 Nightfall Gray
All comes down to how much boost, that can changed with pulley size . But your man factor is going to be fuel!!! And all these cars are different with when the stock fuel system gets to its limit. From everything I have seen and read ,about 540 -600 rwhp on a stock LT1 fuel system regardless the size of the blower , some tuners may take the fuel system to the edge for 600 some may want to leave a safety net and make 540 , if your looking for an exact anwser there isnt one , if your fuel system will only supply enough fuel for 550 hp then you could have a maggie stacked on top of a whipple stacked on top of all the different size prochargers and your only getting 550
DapperDan is offline   Reply With Quote
Old 05-10-2018, 09:27 AM   #18
Charlie540i
Drives: 2016 Camaro SS
Measuring different cars with different setups in different dynos and zones is wayyyy misleading....
a dyno is just a tool, just that. Do a baseline and the compare from that base the gains and this is what really matters. Without a base, you will never know about gains... Also make sure it's on the same gear and don't go jumping from dyno to dyno trying to find a "number".
Last don't go comparing track times, because this is also affected by zone, track conditioning, vehicle setup and driving abilities...
Charlie540i is offline   Reply With Quote
Old 05-10-2018, 09:30 AM   #19
Inkedmongo
Drives: 2ss
To confirm, are you saying if we took 3 OEM factory stock cars, bolted on 3 cookie cutter Procharger kits with exact same pulley on all 3, used the same location, same dyno, and same person tuning all 3 on the very same day, and each car will run out of fuel to deliver at a different amount of power or rwhp, and not just 1 or 2, but possibly by a substantial number?
Old 05-10-2018, 10:30 AM   #20
oneredry
HYPER SS
oneredry's Avatar
Drives: 2016 Supercharged 2SS
to a degree, yes. I wouldn't say substantial by any stretch. but noticeable. Each car is slightly different in its own way. not sure as to why because they roll off the same assy line
Ordered: 1/15/2016
2000 status 02/01/16
3000 status 02/29/16
3400 status 03/07/16 TPW of 03/14/16
4200 status 03/17/16 in transit!
Delivered 03/23/16
2SS Hyper Blue | 6M | NPP | Mag ride | ceramic white Int. | Black out bow ties | P3 Gauge| Front splitter. | 6 pot upgraded brembo brakes. | Magnuson Supercharger/95MM pulley | Rotofab Intake | ZL1 side skirts | HRE FF04 wheels - Michelin PSS4 | ZL1 add ons rock guards and lift points.
| AWE touring - resinated catback with link pipes.
oneredry is offline   Reply With Quote
Old 05-10-2018, 10:39 AM   #21
Inkedmongo
Drives: 2ss
True, the only thing I can factor is being electronic.
I learned back in my days of slot car racing that you could take a stack of 100 armatures, meter read them, and try different ones in the exact same motor can, magnets, air gap, gearing, and weight car and some would be rockets and some would not be. Some would draw more amps, some would pull hardly any at all.
I just don't see where the drastic differences come into play on some of these readings on these cars I am reading about.
I keep going back to when Procharger told me about having two Camaros with the exact same mods, same tuner, same dyno, and one stopped producing fuel almost 130-150whp before the other did. They later confirmed after they replaced the hpfp on the low number car it improved, but never got a number as to how much.
If it wasn't for reading that, I could see where the cars could all be putting down the same power physically to the wheels before the fuel system cannot handle it anymore, and the variables being the resistance and readings on the dyno, the tune itself, the weather conditions and elevation. It's just the stories of where cars are at the same place on the same dyno and everything is consistent and get way further results that I am scratching my head over. Lol
Old 05-10-2018, 01:15 PM   #22
oldman
Drives: SS 6 speed of course
Originally Posted by grampa_ss View Post
I just found this thread..https://www.camaro6.com/forums/showt...=482828&page=2
In it is a statement by Procharger
"The pulley size would have been ordered by your selling dealer.
We try and get it as close as possible to their request.
(given the variables, such as altitude, engine rpm, modifications, etc)"
and...
3.70" = 11psi (but will need meth) ~650+ rwhp
3.85" = 9.5psi (but will need meth) ~600+ rwhp
4.13" = 8psi ~550-580rwhp
The 4.13" is pretty much the last pulley the factory fuel system can hang on with.
Plus is right at about the point of "diminishing returns" as far as power goes if only on pump gas.
(octane limit)... after that you have to reduce timing, which in turn affects how the D/I injection works, and not a lot of good idea for motor longevity.
I think I have a 4" pulley?? anyway with stock LT1 fuel system and 32% cam lobe. I have ported heads, and headers, think I will run out of fuel?
Old 05-10-2018, 02:00 PM   #23
L78toLT1
L78toLT1's Avatar
one word. Reality.
Magnuson, Edlebrock, whipple all claim to have 580 wheel HP, yet I haven't seen one system come close to its advertised set up. For example, while I understand the logic behind it all such as elevation, type of dyno, fuel used that day etc. on average for the PD chargers, they have been averaging 510 to 540whp. myself, I managed 517, after a adjustment of tuning, I managed to squeeze 527. All I did was lower the pulley size and have it retuned and now I'm sitting at 562. which is exactly where I wanted to be. All with out any fuel or meth. Anymore I would be flirting with the edge of running out of fuel. I'm not sure what your goal exactly is, but if your looking for reliability on the basics. Then what you currently have/looking into is just fine. (meaning no adding fuel or cracking the motor open.
Are you running the zl1 tank pump? I have almost exactly the same setup as you and Ted j recommended against even getting into boost or starting the tuning process until I swap the pump. I dropped the tank a few days ago, Lord, what a pita for a 58 yr old working off of Jack stands! I'm going to attempt to get it back to together tonight but suspect it may be a two evening project. Your final results sound promising, can't wait to get mine dialed in.
Baby Blue
Old 05-10-2018, 02:19 PM   #24
KingLT1
KingLT1's Avatar
I believe it's the HPFP. There was a thread going a while back talking about the inconsistency from one to the other.
