Old 04-30-2018, 04:23 PM   #15
trohde78
trohde78's Avatar
Drives: '17 Red Hot 2SS 6MT
That's not bad at all for that many miles. It looks just like my twin turbo 335i "after" it was walnut blasted! :-)
trohde78 is offline   Reply With Quote
Old 04-30-2018, 04:31 PM   #16
parbreak
Drives: 2017 50th Camaro SS
I found it really ironic as I was reading this thread that an ad for Mishimoto Catch Can popped up.
50th Anniversary Edition |Borla Atak and 60606 mid pipes| Kooks 1 7/8" | ProCharger Stage II |305/45/17 DRs | Circle D 3500 stall | LT4 fueling | Custom made Lowside Aux Pump | Alky Control Meth | DSX E85
parbreak is offline   Reply With Quote
Old 04-30-2018, 08:37 PM   #17
WhiteNight
WhiteNight's Avatar
Drives: MB 1SS
Im surprised there isn't an essay on this thread from one specific vendor.
WhiteNight is offline   Reply With Quote
Old 04-30-2018, 08:40 PM   #18
parbreak
Please don't even suggest that
Old 04-30-2018, 09:46 PM   #19
L78toLT1
L78toLT1's Avatar
I'm thinking the lack of carbon buildup is primarily a function of modern oils formulated to combat buildup. At 13k, my ports were oily to the touch but the valves looked good. We're definately ingesting a good bit of oil but based on the pics in the original post, it does not appear to cause excessive carbon buildup
Baby Blue
Old 04-30-2018, 10:04 PM   #20
Mr. Wyndham
I used to be Dragoneye...
Mr. Wyndham's Avatar
Drives: 2018 ZL1 1LE
That's a really good point, too!
I also remember the "weird" design of the valve covers on the Gen V engines GM did with the odd protrusions and cavities. It was quietly mentioned that this was a new PCV feature.
Old 04-30-2018, 11:54 PM   #21
6spdhyperblue
Drives: 2SS 1LE
according to GMs SAE article on combustion for gen v small block it is the puff of hot exhaust gases back into the intake port from the combustion chamber after the intake valve opens is what causes the majority of build up. Those hot particles hit the relatively cool material and cling to it. Over time this builds up deposits. GM focused on valve timing events and made certain tradeoffs to minimize this action.
Old 05-01-2018, 10:27 AM   #22
WhiteNight
WhiteNight's Avatar
Drives: MB 1SS
Hmmm. If that is true then if you go with a cam with positive overlap than you are looking at major carbon build up.
Old 05-02-2018, 12:32 AM   #23
JaxChris
Originally Posted by 62nalide View Post
Catch can or not that's Direct Injection for you. That really isn't that bad from what we have seen with cars that only have 30K miles.
It's not bad at all. That's what BMW and VW hope to look like after a few passes of seafoam and intake additives.
Old 05-02-2018, 10:32 AM   #24
Gunmetalmissle
Drives: 16 ngm ss
Makes me feel better. I would love to know what oil he used and the change intervals.
Gunmetalmissle is offline   Reply With Quote
Old 05-02-2018, 12:54 PM   #25
Spartan268
Spartan268's Avatar
Drives: HB 2SS
Same here. I'd imagine an aftermarket catch can will further help the engine.
Spartan268 is offline   Reply With Quote
Old 05-02-2018, 01:17 PM   #26
GuywithL86
Drives: Black
Just PM'd the guy on the other forum
mobile 1, 9-12k intervals
GuywithL86 is offline   Reply With Quote
Old 05-02-2018, 01:31 PM   #27
GuywithL86
Drives: Black
guy is providing me with more info, confirmed he used 0w-20
So basically what we have here is the worst possible conditions for carbon buildup.
-Long intervals between oil changes (9-12k)
-No catch can
-over 100k miles
-0w-20 oil, aka super thin, which undoubtedly allows more oil into the intake since there are numerous records of the truck motors burning it through the intake via AFM
extreme carbon buildup theory circulating all GM DI v8 forums = pretty much busted (we'll of course need more high mileage examples to make it 100%)
Thank you 00pooterSS of performancetrucks
Old 05-02-2018, 01:37 PM   #28
JaxChris
It proves that the catch can is not needed on the GM Gen V. Your runners won't be any cleaner than that after 100k unless you vent to atmosphere.
