Old 05-01-2018, 09:34 PM   #15
MP3BOOSTED
MP3BOOSTED's Avatar
Drives: 2017 Camaro SS 1LE (F1A-94 FBO H/C)
What else you doing?
Btw do you still have stock fuel system ?
So now i'm saving up for a new clutch, driveshaft, half axles, rotary assembly (better crank, pistons, etc), and procharger..
yeah i'm still running stock fuel system, cam has the added 32% fuel lobe. but yeah i will be going with a LT4 pump and other parts i need for that as well for my build.
Performance Mods: F1A-94, DSX Flex Fuel Kit, MSD Spark Plug Wires, KOOK 2" off road headers, MBRP Race catback exhaust, Pray Performance Custom Boost Cam, Rocker Arm Trunion Upgrade Kit, 7.850" Hardened Chromemoly Length Pushrods and Johnson Racing 2110R Lifters, TSP CNC'd Heads, Ported MSD intake manifold, 103mm Katech Throttle body, Forged Pistons/Rods, RPM Meth kit, DSX Aux Fuel system, AEM Failsafe and banks gauge, LT4 HPFP, LT4 injectors, BMR motor mounts, Hurst Short Throw, Manley SS exhaust valves
Videos of my car? Check here: https://www.youtube.com/channel/UCNi...Qy1OL4NVGlPogw
MP3BOOSTED is offline   Reply With Quote
Old 05-01-2018, 09:38 PM   #16
ULTRAZLS1
ULTRAZLS1's Avatar
Damn going all out. Good luck
Old 05-03-2018, 08:36 PM   #17
Camarentino
Camarentino's Avatar
Drives: 2018 Camaro 1SS 1LE
Hey Ultrazls1 and everyone else
First off very nice setup
I deleted my secondary cats and pulled the fuse on the npp. I have the mbrp catback on order. My question is do I still have to follow mbrps instructions on leaving the npp connected and relocated or since the fuse is pulled I can just disconnect and tuck the harness away without a check engine light.
2018 Camaro 1SS 1LE w/PDR Summit White
KN intake-MBRP cb- 2nd cat deletes- ACS sides- iroc Z spoiler- Eibach Pro- Katech 95TB- MSD Manifold-GM strut bar- Custom tune by Arun Ahuja @ CCPERF.ca
Camarentino is offline   Reply With Quote
Old 05-03-2018, 09:40 PM   #18
ULTRAZLS1
ULTRAZLS1's Avatar
You will have no engine light with it unplugged. Even with the fuse in
Old 05-03-2018, 09:55 PM   #19
Camarentino
Ok great thank you
Old 05-10-2018, 08:33 PM   #20
ULTRAZLS1
ULTRAZLS1's Avatar
https://m.youtube.com/watch?v=XT8Zk7...ature=youtu.be
In car wot quick pull
Old 05-10-2018, 10:17 PM   #21
KingLT1
KingLT1's Avatar
Drives: 2016 1SS NFG A8
Sounds killer. I need to get mine shifting like yours.
Old 05-10-2018, 10:28 PM   #22
ULTRAZLS1
ULTRAZLS1's Avatar
Thanks
It actually shifts a bit more firm with my track tune. This is my street tune with TM still in it. Hard to explain but the shifts feel maybe even a touch quicker with TM but without the TM it hits harder. Weird
It’s faster without the tm at the track I’ve tried both
Old 05-11-2018, 09:05 AM   #23
KingLT1
KingLT1's Avatar
Yeah I have been playing with mine, but have not got it where I want it yet. I have only played with shift inertia, not shift speed or time. Only have so much time to play with it. It took me a day just to dial in the damn maf. my fuel trims were +8% at idle and part throttle from the ported im/tb and rotofab.
Old 05-11-2018, 01:54 PM   #24
Nightfall SS
Nightfall SS's Avatar
Drives: 2016 Camaro 1SS
Question with these exhausts. With the stock suitcase removed it appears that there is potential to introduce drag on the lower portion of that rear bumper plastic? At high rates of speed does anyone think this could pose an issue flexing the bumper? Other than that I like the way it sounds as well as the potential weight savings over the stock NPP system. Also wish I could shift half that well in the M6 :/
1. Phastek detachable front license plate bracket 2. Blacked out Bowties 3. Blacked out sidemarkers/third brakelight 4. Rotofab dry/no soundtube CAI 5. VMAX ported throttlebody 6. Kooks 1 7/8 Longtubes with Hi-Flow Cats 7. EFI Tuning Flex Fuel kit and tune 8. HP Tuners NGAUGE 9. Zeitronix ZT-2 Wideband(reads on NGAUGE) 10. Ported MSD intake manifold 11. CORSA XTREME axle back w/ dual quad black tips
12. Racestar Darkstars 17X9.5 with Mickey Thompson ET Street SS 305-45 17 Radials 13. Kicker 3-way door speakers. DYNOCOM mobile dyno trailer: 471hp/490TQ@97degrees ambient/ethanol percentage=80%
Nightfall SS is offline   Reply With Quote
Old 05-11-2018, 04:03 PM   #25
ULTRAZLS1
ULTRAZLS1's Avatar
I’ve had the car to about 150 mph and nothing has been bent. I also lost no speed with it. I think the car is low enough to the ground very little drag getting caught in that area. I thought the same thing
Old 05-13-2018, 11:24 AM   #26
Nightfall SS
That’s great to know, thanks man
Old 05-13-2018, 05:12 PM   #27
oldman
Drives: SS 6 speed of course
Mothers need to hide the babies when this bad boy pulls into the parking lot... hehe..
Old 05-25-2018, 10:56 AM   #28
andes101
Drives: 2016 2ss
Thanks
who do you have tuning your car? and i wonder if the catless texas speed headers with connection pipes would match up right up to the mbrp catback system hmmm
andes101 is offline   Reply With Quote
