#15 |
![]() ![]() Drives: A few Join Date: Oct 2017
OK but you know those bigger brakes are slowing you down... when you aren't using them right? And not slowing you down any better when you are using them if you can already exceed the coefficient of friction of the tire?
I've always found that the sweet spot is having JUST enough brakes to stop the car lap after lap, no more, no less. Certainly if you need more thermal mass and cooling/etc hasn't helped, then run bigger rotors - it's the logical solution at that point.
-Dave
HPDE/DD: 2018 Camaro ZL1 1LE || HPDE/DD: 2015 Subaru BRZ ||Tow Vehicle: 2004 GMC Sierra 2500 8.1L || Weekend toy: 1994 MR2 Turbo || The other weekend toy: 1993 MR2 Turbo || Track car: 1998 Integra Type-R || Race car: 1996 Integra GS-R || New race car build: 1992 Honda Civic Hatchback Too many cars.. never. |
#16 |
![]() ![]() Drives: 17' 1SS 1LE GBA-Black Join Date: Mar 2017
#17 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2SS 1LE Join Date: Oct 2011
These looked nice, but the felt like wood compared to my previous SS and my new 1LE. All 3 are brembos.
2018 2SS 1LE 2023 Colorado ZR2 2022 Stinger GT-line AWD |
#18 |
![]() ![]() ![]() ![]() Drives: ZL1 1LE Join Date: Oct 2016
I’m pretty sure the rear calipers are the same, yeah? Same brake pad part number.
#19 | |
![]() ![]() ![]() ![]() Drives: 1LEs Join Date: May 2009
#20 |
![]() ![]() ![]() ![]() ![]() ![]() Drives: 17 SS 1LE Join Date: Dec 2015
How hard would it be to do a ZL1 brake upgrade in the rear?
#21 |
![]() Drives: 2017 Camaro 1LE SS Join Date: Oct 2016
There is absolutely no logical reason to change to ZL1 brakes on a 1LE. The reason that ZL1's have larger brakes is because it's a heavier car. And that is one reason that it's heavier because of the front rotors. On a 1LE you have ample braking with oem package. You DO NOT want more unsprung weight on the front of a 1LE. Unless you want to go slower.
#22 | |
Hint - I know of at least one SS 1LE and another one coming that has changed to J6H brakes - with absolutely no regrets. |
#23 |
The rears definitely do look different, but they appear to be the same pad internally.
#24 |
#25 | |
Hot Dog
Drives: '17 1SS 1LE Join Date: Feb 2016
Pedal feel during the test drive felt identical to the J6M's, unsurprisingly. I'm looking forward to less than 450°F caliper temps on-track this year.
#26 | |
I used to be Dragoneye...
There are other reasons to go bigger....thermal capacity, heat dissipation, swept area = more braking force. All of these things become more helpful the faster you go...and since the ZL1 is capable of higher speeds, pulling a car down from 140 is much different than from 120, for example. So I'd argue the weight factor is lower on the list...higher speeds is probably #1 or #2. That said, you are right that the OE braking system on the SS 1LE is very well suited to that vehicle...an upgrade to more aggressive pads will net far better results than an expensive upgrade to the OE ZL1 brakes. |
#27 |
I'd have to wonder if there aren't any good aftermarket setups? If you don't have enough braking and want to/need to upgrade, you can usually do better than the cost-cutting OEM stuff and get a significant improvement by going aftermarket, often without drawbacks such as massively increased weight or marginal improvement.
#28 | |
Or if you really want to go crazy, look into Carbon Ceramic rotors. But for 99% of drivers...a good rotor, and a really aggressive pad balanced front/rear will get the max braking power they'll ever need. Couple that to a slick tire, extra cooling, and I can't imagine how else to improve braking performance. |
