Old 03-19-2018, 05:57 PM   #15
Badmojo
aka BeastZL1
Badmojo's Avatar
If it's on factory tires, then you can't always hear them spin.
2019 Camaro ZL1 1LE
Racing for ALS Youtube Link
Old 03-19-2018, 06:02 PM   #16
Tampabucs4
Tampabucs4's Avatar
Drives: 2018 blue ZL1
But my car did prior to mickeys too
Tampabucs4 is offline   Reply With Quote
Old 03-19-2018, 07:19 PM   #17
17CamaroZL1
Life's Short, Live Fast!
17CamaroZL1's Avatar
Mine feels super planted unless the tires break loose. It typically doesn't break loose above 40 mph unless it's cold out, then it can get sideways at 60 or better!
12/26/2016 Ordered!
2/8/2017 Built!!
3/2/2017 Brought Home!!!
Old 03-19-2018, 07:41 PM   #18
Tampabucs4
Tampabucs4's Avatar
It’s wierd it’s not the back that’s leading the left to right. It the front thy feels it. Maybe alignment issue
Old 03-19-2018, 07:46 PM   #19
Boosted4life
Drives: 2018 ZL1 A10
I feel it and I'm on stock tires. I figured it was the tires following the grooves in the pavement
Boosted4life is offline   Reply With Quote
Old 03-19-2018, 07:56 PM   #20
Stress
Drives: BMW
Originally Posted by Tampabucs4 View Post
Has anyone zl1 felt like it’s floating left to right when flooring at high speeds say 50+?
Yes, same here. Your description is spot on. Gets spooky on a narrow road. I've been trying different tire pressures and will check alignment next.
Stress is offline   Reply With Quote
Old 03-19-2018, 09:42 PM   #21
Ricco
Ricco's Avatar
Drives: 2018 ZL1 Vert A10
Check your tire pressures. I had this symptom on a different car and it turned out that I had a slow puncture in one of the rear tires.
2018 ZL1 Vert - 854Whp / 791Wtq
2016 BRZ
2013 X5D
2005 STI
2001 2.5 RS
Previous cars in chronological order
2016 GT350, 2014 MEV Rocket, 2013 Nissan Qashqai + 2, 1.6L Diesel, 2010 Nissan Note 1.5L Diesel, 2012 Dodge Ram 2500 6.7L Cummins, 2009 Subaru Impreza STI, 2005 Dodge Ram 1500, 2004 Mini Cooper S, 1997 Subaru Impreza Catalunya special Edition, 1992 Daihatsu Charade GTti, 1978 Mk1 Ford Fiesta
Ricco is offline   Reply With Quote
Old 03-19-2018, 09:58 PM   #22
URBAN LEGEND
URBAN LEGEND's Avatar
I have that situation as well. I am about the move the rear bar one link forward as the manual says to see if this gets sorted out. I want to punch it at 70 mph and be confident that all is well. Manual for the ZL1 1LE says one link forward helps cure oversteer.
🔺22 RS E TRON GT
🔺21 Model S Plaid
URBAN LEGEND is offline   Reply With Quote
Old 03-19-2018, 10:24 PM   #23
speedraider
speedraider's Avatar
Drives: 2016 Z06, 2017 ZL1
Originally Posted by ninetres View Post
Having mis-matched tread/sidewall mis-matched front-back can contribute to the car walking on some surfaces. Even some matched treads will walk with grooves in the road surface.
100 % right, rear wheels have more flex than fronts. Gets scary at high speeds. I had this problem with nitto nt05r on my vette, had to put nt05 in the front, problem solved
speedraider is offline   Reply With Quote
Old 03-20-2018, 06:20 AM   #24
Jmueller
Drives: 2017 ZL1 A10 Nightfall Gray
100% have felt this and the first few times it happened I puckered up pretty good. It’s a dramatic feeling and really seems like the car is just about to lose control. Stay in it and it goes away, but it makes the first 1/2 second of full throttle pretty scary.
I figured it was tire sidewall flex. Really would like to get this issues resolved.
Jmueller is offline   Reply With Quote
Old 03-20-2018, 06:23 AM   #25
Jmueller
This is not a mismatching tire issue. This happens on stock ZL1s with newish factory tires. I can’t say if it happens with different tires. I have had mismatched tires causing float on other cars. That feeling is present all the time with any steering input at highway speed. The feeling others and myself are talking about happens when going full throttle while already at highway speed. It’s different than mismatching tires.
Old 03-20-2018, 07:18 AM   #26
Fraxum
Fraxum's Avatar
Could part of it be bushing compression?
Old 03-20-2018, 09:03 AM   #27
cwebster
Cal
Drives: 2017 6th Gen Camaro ZL1 Coupe M6
From day 1 my car had a tendency for rear-end to slide right during burnout and if I lost traction on a launch or gear shift at full throttle. It would also tend to steer left at WOT. When I first ran my Mickey Thompson DRs it was way worse. With DRs it would also tail-wag on the big end over 90-130 MPH - felt like it was gonna go sideways. At first I thought it seemed like an eLSD issue - favoring one side.
I now believe the tendency to slide right or steer left was a biased thrust angle caused by a poor 4-wheel alignment from the factory. I recently had a complete alignment done and it's rock solid now. I feel like the tail-wagging was definitely the taller sidewalls (F/R mis-match) on the DR's flexing at high speed.
In competition modes, the tight suspension will follow cracks in the pavement too, giving the car a tendency to shift right or left depending on where it engages uneven or cracked pavement.
I think most of the complaints of the front-end shifting side to side will be suspension issues, whereas rear-end float would more likely be sidewall / tire size mismatch or alignment issues. ZL1 1LE may be able to compensate some with their user adjustable suspensions but should probably check other common causes first.
--Cal
cwebster is offline   Reply With Quote
Old 03-20-2018, 09:56 AM   #28
ReefBlueCoupe
ReefBlueCoupe's Avatar
Drives: A few of each
Mine does this - feels to me like the ELSD and TC as others have said. There's really nothing else it could be. It's an instantaneous back-and-forth of the rear that lasts for 1/2-1 second at WOT or hard acceleration while the car is already moving. It sorts itself out after that.
Keep in mind we are dealing with GM-level refinement and calibration of a complicated system trying to manage 650 ft-lbs, not Italian-supercar-level refinement and calibration. Either the calibration was rushed, the engineers didn't encounter this scenario during development (unlikely), or the processing of I/O from/to the ELSD unit/TC system just isn't happening fast enough (processing is too slow). It'd be great if there were an updated calibration to take care of this, but I haven't heard of anything. Then again, if it's not the calibration but is instead the processing speed that's the problem, nothing but swapping ECU components will fix that.
It's never felt out of control to me, but was unnerving the first few times I went WOT from a roll and didn't expect it.
I've felt mechanical diffs do this on the dragstrip in the past, but usually it's WAY more pronounced and doesn't go away, and with big drag tires and big sidewalls, things can get out of control quickly. Hence why we have spools and Waveloc/similar for high-hp cars accelerating hard.
'18 MBM ZL1 1LE
ReefBlueCoupe is offline   Reply With Quote
