#15 |
![]() Drives: 2016 1SS - M6 Join Date: Jun 2017
To dispel some further myths .....
A bent pushrod does not always cause a engine to run rough and sometime will not display any characteristics of being "hurt" other than loss of HP.......which some cases can be hard to detect without a dyno. That said, I agree with others in that the speed you were at and the gear you went into I doubt caused any damage at all Be safe ! |
#16 | |
![]() ![]() Drives: Tesla M3 LR-AWD [Former 1SS owner] Join Date: Jan 2018
To the OP.. you'll be fine. |
#17 |
![]() Drives: 2016 Camaro SS M6 Join Date: Oct 2016
2nd gear is supposed to go all the way to 80... so I think you're fine.
http://www.camaro6.com/forums/showthread.php?t=409961 |
#18 |
2018 1LE, NASA Instructor
Drives: 2018 Camaro SS 1LE Join Date: Jan 2018
I'm told (by owners who have done the money shift) that Porsche 911 on a money shift will shatter a clutch disk/plate or some other thing rather than blow the engine. It is still a $4,000 repair at a Porsche dealer but the engine is saved.
Do we have anything similar in our clutch design? Or does the clutch always will and the engine loses? |
#19 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2013 Triple Black ZL1 Vert M6 ECF Join Date: Mar 2011
What I was trying to point out is that when the car is traveling at one speed, and you push in the clutch and select a to-low of a gear for the speed you're driving at and let the clutch out, it's the rotational speed of the rear wheels, the rear end ratio, and the gear ratio of the gear you selected, that determines the speed the engine will try to achieve, completely independent of whether it has fuel and/or spark. The speed of the engine is being mechanically determined, not by fuel or spark inputs (or lack of). We both seem to be correct, just in different ways. |
#20 |
![]() Drives: 2018 1SS M6 Summit White, MRC & NPP Join Date: May 2016
Thanks for all the responses! Kind of put my mind at ease. I’m hoping the ECU eventually forgets whatever it records. I wouldn’t want any warranty issues should I need the warranty in the future.
#21 |
![]() Drives: 2017 Camaro SS & 2018 ZL1 1LE Join Date: Mar 2017
This happened to me in my SS. Had to replace the coil packs, I got them to replace the heads too. Any tips for NOT doing this while racing? When I did it I was racing someone went 3rd to 2nd
#22 | |
SoCal HT5! SD
Drives: 2016 red hot 2ss M6 Join Date: Nov 2011
![]() This will keep you from missing 3-4, as you are pushing down and away from you, rather than down and toward you.
#23 | |
#24 |
SoCal HT5! SD
no problem bro!
