Old 02-22-2018, 07:12 PM   #15
ssmike
BL1ZZRD
ssmike's Avatar
Drives: '16 Camaro 2SS, '20 Equinox Redline
Well I installed the mild to wild controller anyway. If the only benefit is that it keeps the valves open all the time, even while cruising, that will be fine. I’ll give it a try! Here’s how I installed it into the fuse block without having to notch the cover.
ssmike is offline   Reply With Quote
Old 02-26-2018, 05:29 PM   #16
Ventmaster
Ventmaster's Avatar
Drives: 2017 1SS 6spd
Originally Posted by SuperSound View Post
Yes you can, you have to put the car into Service Mode (5 sec hold on Engine Start, not holding the brake). Then it will boot all the modules in the car and you can change the NPP setting.
Good to know the next time I forget to switch to Stealth before shutting down. Thanks SuperSound!
Ventmaster is offline   Reply With Quote
Old 02-26-2018, 06:11 PM   #17
SuperSound
SuperSound's Avatar
Drives: '17 Camaro 2SS A8
Np. It's good for testing wires for switched power too.
Sent from my SM-G950U using Tapatalk
Old 02-27-2018, 01:34 AM   #18
MemoTRCKSS
Memosanchez22
MemoTRCKSS's Avatar
Drives: 2016Camaro2SS
valves stay open all the time if set to track mode in the sound management car folder right ????
MemoTRCKSS is offline   Reply With Quote
Old 02-27-2018, 06:40 AM   #19
ssmike
BL1ZZRD
ssmike's Avatar
I tried this. Set to Stealth mode but it still started with valves open.
Yes, however I've been told that the valves will close when cruising below 3k rpm's. I tried it and didn't hear a difference when I opened with mild to wild.
Old 02-27-2018, 12:19 PM   #20
Fraxum
Fraxum's Avatar
Originally Posted by Alpha1BC View Post
Could maybe wire in your own switch/relay into the fuse circuit? You wouldn't have the remote functionality, but you could easily get the same effect of pulling the fuse with the flip of a switch for less than half the price of the M2W kit.
This ^ as MLee said. I think even less that $20 and about an hour of time running the wire. Fun little project.
The CA6 NPP is improved from the 5th gen with Stealth full time if you want it.
Oops! Edit: read the thread to me you dummy.
Old 02-27-2018, 04:32 PM   #21
SuperSound
SuperSound's Avatar
You sure you were in Service Mode not accessory? The DRLs will come on and your 12V socket will be working in Service Mode but no accessory. I originally came across the work around in this thread.
http://www.camaro6.com/forums/showth...=446963&page=2
Old 02-28-2018, 01:55 PM   #22
srcstc
What'd you use to stick into that ground slot? I'm having a hard time finding something that'll stay in there.
Rich
srcstc is offline   Reply With Quote
Old 02-28-2018, 02:10 PM   #23
SuperSound
SuperSound's Avatar
Rich
If I'm looking at the right picture, the ground slot looks to be fuse (can't remember the exact type) slot. You can cut apart an old fuse and use the blade to plug in. Just be sure to solder or crimp connect the wire to the old fuse blade.
Old 02-28-2018, 02:48 PM   #24
ssmike
BL1ZZRD
ssmike's Avatar
Rich
I used a red open crimp lug and cut half of the fork off and plugged it into the ground socket
Old 02-28-2018, 05:48 PM   #25
srcstc
It's not an unused fuse slot (female). It's an unused slot for one of the relay looking square cubes. The only metal in there is on the very bottom. There's nothing on the sides to make contact with a fuse prong.
Old 02-28-2018, 06:02 PM   #26
srcstc
I tried a yellow blade terminal but it's not working.
Old 03-01-2018, 05:11 AM   #27
ssmike
BL1ZZRD
ssmike's Avatar
I’m out of town today so I’ll get a better picture for you tomorrow night
Old 03-01-2018, 06:26 AM   #28
srcstc
Thanks
