Old 02-16-2018, 08:51 PM   #15
Stephen12ZL1
Stephen12ZL1's Avatar
Drives: '21 ZLE A10
Originally Posted by ReefBlueCoupe View Post
Anyone with the 56" Race Ramps back up on to them to say service the rear diff? If so, did the front end clear the ground? I can try it, but haven't yet.
yes, this will work fine even with my antiquated rhino ramps
Old 03-05-2018, 02:01 PM   #16
blk04sr
Drives: N/A
FYI they make extenders for those who have the 56" version
https://raceramps.com/car-ramps/gara...amps/xtenders/
blk04sr is offline   Reply With Quote
Old 05-10-2018, 10:35 PM   #17
Mr. Wyndham
I used to be Dragoneye...
Mr. Wyndham's Avatar
Drives: 2018 ZL1 1LE
I can post pictures at a bit of a later date...but I can confirm that the Race Ramps RR-TR 7" (74" length) will clear the ZL1 1LE with the front struts in full height setting with about an inch to spare. So it should also clear in full low setting.
Old 05-11-2018, 10:06 AM   #18
Sooner Cole
Sooner Cole's Avatar
Drives: 2019 ZL1-1LE A10
I got the 56" two piece ramps for 17 ZL1. They worked perfect. When I got my 18 ZL1LE, I had to get the extenders as the approach angle was just a little too steep.
19 ZL1-1LE A10
Sooner Cole is offline   Reply With Quote
Old 05-11-2018, 07:39 PM   #19
MValdez17
Drives: 2010 Camaro 2SS/RS
Just received my 67" Race Ramps today. They clear the splitter, but do rub up on the rubber and plastic pieces that sit under the splitter. Going to have to order the XTenders unfortunately.
I would suggest getting the 72" for the ZL1 1LE.
MValdez17 is offline   Reply With Quote
Old 05-11-2018, 07:52 PM   #20
Chevyman2
Chevyman2's Avatar
Drives: 2018 zl1
I also have 67 inch race ramps and confirm rubbings zl1 . I found discount ramps had the best price at time of my purchase.
Chevyman2 is offline   Reply With Quote
Old 07-15-2018, 01:06 AM   #21
nicktechla
nicktechla's Avatar
Drives: 2012 Porsche 911 Turbo S
So these 67" ramps rub a bit?
https://www.amazon.com/Race-Ramps-RR...ace+ramp+67%22
IG: 2fast2nick
-- Current --
2012 Porsche Turbo S - PDK - Basalt Black Metallic
-- Past --
2017 Camaro ZL1 Coupe - Red Hot - A10, PDR - HRE P101
2015 Mustang GT PP - Whipple Supercharger
nicktechla is offline   Reply With Quote
Old 07-15-2018, 03:42 AM   #22
satanschariot666
Drives: camaro
all lenghts ramps will rub dont worry about that you can even get the 56
all you need to clear it with room to spare is to find a spot where a floor is slightly offset from the pavement
even the slightest rise of the front wheels will do it
u can even put the cardboard the ramps came in and drive over it w the front wheels
once the car is pointing up there will magically be tons of clearance
satanschariot666 is offline   Reply With Quote
Old 07-15-2018, 03:46 AM   #23
satanschariot666
Drives: camaro
straight is an illusion
things that appear straight are infact curved
Old 07-15-2018, 09:49 AM   #24
nicktechla
nicktechla's Avatar
nice, thanks
IG: 2fast2nick
-- Current --
-- Past --
Old 07-08-2020, 11:33 AM   #25
Needs about 4" to get on an 18' Aluma Tilt
I put a couple of 12" X 1" square pieces of wood I put under the race ramps that work well.
Old 07-08-2020, 06:40 PM   #26
Tyrolblue67
Drives: 2019 ZL1 Camaro
I bit the bullet and went with the Race Ramp 80's. Plenty of clearance.
Tyrolblue67
Tyrolblue67 is offline   Reply With Quote
