Old 04-03-2020, 10:48 PM   #15
JCunningham
JCunningham's Avatar
Drives: 2017 2SS M6
no you cant. it will loosen again. the nut is part number 11612295 $10 MSRP
Old 04-03-2020, 10:57 PM   #16
2SS Capt
2020 Shadow Gray 2SS
2SS Capt's Avatar
Thanks!
So what will the dealer replacing it do? Won't it just come loose again? Or do they do something different?
Old 04-03-2020, 11:01 PM   #17
JCunningham
Drives: 2017 2SS M6
they will use a new nut. the nut is a lock nut. you cant reuse a lock nut.
Old 04-03-2020, 11:03 PM   #18
2SS Capt
2SS Capt's Avatar
If I do it myself, is there anything to be concerned about (anything I should know before removing the nut and replacing)? Do you know the proper torque?
For a $10 nut I'd almost rather do it myself, just want to be sure I do it right and not screw up anything...
Old 04-03-2020, 11:05 PM   #19
JCunningham
Drives: 2017 2SS M6
ya id do it myself too. ill get you the tq spec
Old 04-03-2020, 11:06 PM   #20
JCunningham
Drives: 2017 2SS M6
199lbft they dont recommend any loctite being its a lock nut. its easy. dont use a impact take it off with a breaker bar. just put it on with a ratchet and torque it.
Old 04-03-2020, 11:28 PM   #21
2SS Capt
2SS Capt's Avatar
Sounds good... Yikes 199 ft/lb, I think my 1/2" drive torque wrench only goes to 150 ft. lbs...
Curious as to why no impact wrench? Will it damage something?
Old 04-03-2020, 11:32 PM   #22
JCunningham
Drives: 2017 2SS M6
probably the splines. GM says in the factory shop manual not to use air tools.
Old 04-03-2020, 11:33 PM   #23
2SS Capt
2SS Capt's Avatar
Thanks!
Old 04-04-2020, 09:01 AM   #24
L78toLT1
L78toLT1's Avatar
199 ftlbs lol! I suppose 200 is just too damn much!
Baby Blue
Old 04-04-2020, 01:37 PM   #25
supersportss
Drives: 2019 SS
Originally Posted by HyperspaceTurd View Post
The big fat 36mm nut that keeps your axle and hub um, on.
Not to be confused with lug nuts, jam nuts, or deez nuts.
LMAO Deeeeeeeezzzzzzzzzzzzz.
supersportss is offline   Reply With Quote
Old 06-12-2020, 11:03 AM   #26
2K16SummitSS
Resident Land Surveyor
2K16SummitSS's Avatar
Drives: 2016 Camaro 1SS - Summit White M6
I replaced my axle nuts a few weeks ago. Torqued them down to 200 ft lbs. Fixed all my noise and rear slop issues...for a week. They seem to have already backed off again. Guess I get to do it again and hope for a better result? I'm out of warranty so on my own with this.
2016 Summit 1SS 49th Anniversary Commemorative Limited Plutonium Edition - M6, Solo Axleback & !RearCats, Ultra-Rare Cloth Seats, Forgestar CF5V 19x10-285/35 19x11-325/30
2001 NBM Trans Am WS6, Wifey's Grocery Getter - Torquer V2 cam, Racetronix Fuel Pump, Yank 3000 Stall, Transgo 1-2 kit, TSP LTs, Magnaflow, Strano Springs/Koni STR.T shocks, 17x9.5/17x11 TTIIs, Ed Wright tuned
2K16SummitSS is offline   Reply With Quote
Old 06-12-2020, 11:08 AM   #27
2SS Capt
2SS Capt's Avatar
What about some Loctite 272 Thread Locker? (The same stuff GM recommends for your caliper bolts)
https://www.amazon.com/gp/product/B0002KKTR2
Old 06-12-2020, 11:39 AM   #28
2K16SummitSS
I used blue last time (it was what I had on-hand). I will use red this time. I'm also going to look at my stake job when I take the wheels back off. May need to stake them better this time. Only things I can think of to change.
