Old 01-18-2018, 04:18 PM   #15
lsp408
Drives: 2018 HB ZL1 M6
Originally Posted by Ironman24 View Post
My engine sound management menu has disappeared several times after setting the car to stealth to not annoy the neighbors. When I do a cold start and get on the road I can't put the exhaust back into track mode. It will eventually show back up after several starts.
Have you taken car to dealer to address the issue?
lsp408 is offline   Reply With Quote
Old 01-23-2018, 08:44 AM   #16
Ironman24
Ironman24's Avatar
Drives: 17 ABM ZL1 M6
Not yet, I will get around to that at some point. Just not a big dealer service fan and try to stay away as long as possible. lol
Ironman24 is offline   Reply With Quote
Old 01-23-2018, 08:53 AM   #17
LesBaer
FMPG
LesBaer's Avatar
Drives: 2016 2SS
This has been an issue since the 6th gen came out. It'll come back if you shut the car down and wait for a few minutes, but it's annoying. Pretty disappointed that GM/Chevy haven't addressed this yet. The only way to fix this is to install an aftermarket exhaust controller that connects to the fuse box so you circumvent the user interface. I've been using a Forza brand unit personally since it's made a lot better for dealing with engine heat than the Mild to Wild.
ARH 1 7/8" ceramic coated full sys w/NPP; Maggie 9.2psi (85mm); Jannetty rough idle cam(TSP), tune and LT4 fuel system; Forgeline VX1 Black PVD (20x10,11); R88R 315's; ALPriority; BMR rear arms, bushings, DS loop; RF intake (red); nGauge
93 octane: 712rwhp, 654rwtq / E85 (E66 mix): 734rwhp, 674rwtq (SuperFlow Dyno)
LesBaer is offline   Reply With Quote
Old 07-18-2018, 07:03 AM   #18
Ten4Lou
Ten4Lou's Avatar
Drives: 2018 ZL1 NGM
I was looking for easy memory recall under comfort and convenience tree, the only thing showing is Chime Volume...
Below are the items missing...
Auto memory recall
Easy exit
Reverse mirror tilt
Anyone have any idea?
I just bought a new 2018 ZL1 last week and I have noticed the same exact issue. The first two days I had the car and was going through the menus to set up options, Auto memory recall, Easy exit & Reverse mirror tilt were missing. Then when I went back in on the third day, those items were there.
I wonder if the TSB mentioned in this thread is for people who have this intermittent problem, or is the TSB only for people who never have the items appear?
Hope that didn't sound confusing? Basically, I hate to waste the time having the TSB applied if it isn't going to improve my situation.
Thanks!!
Ten4Lou is offline   Reply With Quote
Old 07-18-2018, 10:12 AM   #19
Gunkk
Thank you Al Oppenheiser!
Gunkk's Avatar
Originally Posted by FASTNUF View Post
When I use remote start, my Engine Sound Management selection goes away each time. Only comes back when I restart the car by the button.
+1 this.
Someone else also suggested using the unlock button a couple times before hitting the key fob remote start to "wake up" the computer so it doesn't lose the menus.
I've been able to reproduce both on my car.
Old 03-04-2021, 05:13 AM   #20
Andrew S
Andrew S's Avatar
Drives: Camaro 2SS Redline Edition
From your experiences, does the problem with the disappearing(and reappearing) menu get worse with time? If I can live with the way it is now, should I try to get it fixed anyway?
My car is no longer on warranty, so I would have to pay for replacing the module. Just wondering if its worth it.
Andrew S is offline   Reply With Quote
Old 03-04-2021, 12:28 PM   #21
Bangkok_ZL1
Flying around Thailand
Bangkok_ZL1's Avatar
Drives: 2019 Camaro ZL1
A computer controlling a car is a trip
Bangkok_ZL1 is offline   Reply With Quote
Old 03-04-2021, 05:10 PM   #22
It's some module initialization order glitch, didn't get any worse or better on my car (it hardly ever happens). Pressing unlock before lock when using remote start eliminates it completely.
Since I have the latest pre-refresh infotainment software as of late 2019 and it's the same, I don't think this is worth spending money on. Just my 2 cents'.
Old 03-07-2021, 03:32 PM   #23
Andrew S
Andrew S's Avatar
Thanks for the tip. I will try this with the remote.
The menu hasn't come back on since driving the car about 5 times. :(
But its mostly settings I never went into anyway
Nevertheless it would be nice if it worked again.
Old 03-08-2021, 03:07 PM   #24
Andrew S
Andrew S's Avatar
Thanks a milion. It worked ��
Old 11-13-2023, 09:18 AM   #25
JustinRapp
Drives: 2018 SS 1LE & 2017 2LT 1LE
I know this is an old thread -but my 2018 is doing the same. Pretty annoying!!!
JustinRapp is offline   Reply With Quote
