Old 01-05-2018, 10:51 AM   #15
Emoto
Sure, why not?
Emoto's Avatar
Drives: 2016 Camaro 2SS, Jeep JKU Rubicon
We're going to need pics of the woman in order to determine her level of guilt.
Emoto is offline
Old 01-05-2018, 10:54 AM   #16
Maximus SS
Drives: 1le
Originally Posted by Richard0nee View Post
I think we all want to know the same!
Yup +10
Maximus SS is offline
Old 01-05-2018, 11:01 AM   #17
ctrlz
Originally Posted by fastball View Post
The leather is only part of the problem. It no doubt soaked into the cushion and maybe got down into the electronics inside the seat - heater element, cooling fan, circuit boards, electrical connections......
Even if it didn't leak into the electronics, the seat cushion is most likely toast. You'll never get the fluid out, and no matter how well you clean the leather, you'll always have the effervescent aroma of straight tequila urine in the car..... especially when your passenger turns on the cooling fans. The cushion can be replaced without replacing the entire seat.
Whatever you do, if you know her address, send her the bill.
This guy has it right. That much urine soaked into the foam. The heating grid I would not worry about as much. That and the cooling fan could be cleaned once removed (although the grid may be molded into the foam). I would pull the seat and take it apart. Depending on how the upholstery is fitted, it may be impossible to access the foam as a separate piece. Time to look for a parts recycler (a.k.a. junkyard) that will sell you a seat.
I'll leave it to others to comment on how exactly you got into this situation and how you might avoid it in the future!
ctrlz is offline
Old 01-05-2018, 11:03 AM   #18
DC5
Drives: 2019 Chevrolet Camaro SS 1LE
Originally Posted by PhantomV8 View Post
How much would it cost to replace the seat? Do you think any would have made it down to the carpet through the cushioning?
Seat foam is generally 2-3" thick and reasonably dense. Therefore, I find it HIGHLY unlikely that the urine traveled through the seat foam and onto the underlying carpet.
As mentioned above, use a product with active enzymes to destroy the source of the odor. If, after testing it on an inconspicuous location, the product isn't compatible with the leather or is not effective in removing the odor, I would proceed to replace the seat bottom foam. If the seat construction is similar to the Fifth-Generation Camaro, replacement of the seat bottom foam is not that difficult.
DC5 is offline
Old 01-05-2018, 12:19 PM   #19
Camaro_QC
Camaro_QC's Avatar
Drives: 08 Tiburon GS, 2018 Camaro 2.0T
A situation like this would PISS me off for sure...
Good luck!
Camaro_QC is offline
Old 01-05-2018, 12:27 PM   #20
Bhobbs
Bhobbs's Avatar
Drunk girlfriends are always a pain in the ass, more so than sober girlfriends.
Good luck Op, let us know how it turns out.
Bhobbs is offline
Old 01-05-2018, 12:31 PM   #21
nicktechla
nicktechla's Avatar
Drives: 2012 Porsche 911 Turbo S
I had an ex vomit in my car after coming back from mexico.. I had to get rid of the car
IG: 2fast2nick
-- Current --
2012 Porsche Turbo S - PDK - Basalt Black Metallic
-- Past --
2017 Camaro ZL1 Coupe - Red Hot - A10, PDR - HRE P101
2015 Mustang GT PP - Whipple Supercharger
nicktechla is offline
Old 01-05-2018, 12:31 PM   #22
soloknight6
SoCal HT5! SD
soloknight6's Avatar
Drives: 2016 red hot 2ss M6
YIKES! Sorry OP, but I think your seat it TOAST. Every time a passenger turns on the heater/coolers, that smell will return. Time to start hunting for a seat on Ebay, you may be able to find one intact in the 500-700 range. What kind of adult just unloads on your seat? How toasted was she?
Now Ive got another reason to not let hammered friends ride in my car haha.
soloknight6 is offline
Old 01-05-2018, 12:33 PM   #23
mako22
mako22's Avatar
Drives: 2017 HB 2SS
A girl I was seeing texted me at 3am to pick her up at the bar - I got out of bed, got dressed and drove over in my 2011 SS - and she was a complete mess. She got in and at the first light, she started leaning forward and dry heaving - I frantically pulled over, pushed the door open - and then pushed her out. When the light turned green, I decided to keep going and left her there.
I knew a hookup was not in the cards, and I was already pissed off about the possible puke in the car.....so I feel my actions were justified.
mako22 is offline
Old 01-05-2018, 12:34 PM   #24
soloknight6
SoCal HT5! SD
HA! Great job!
Old 01-05-2018, 12:37 PM   #25
mcintyre1969
mcintyre1969's Avatar
Drives: 1968 SS/RS, 2006 H2 2016 2SS White
yea, yea, yea replace seat cushion, now back to the story .......
2016 2SS White fully loaded
mcintyre1969 is offline
Old 01-05-2018, 12:44 PM   #26
avalonandl
avalonandl's Avatar
Drives: 2019 ZL-1
You can order a new cushion cover and have a upholstery shop change it. pull the cushion foam out and relace that too.
avalonandl is offline
Old 01-05-2018, 12:47 PM   #27
6spdhyperblue
Drives: 2SS 1LE
Definitely should take the leather and cushion off and clean it and replace if needed
6spdhyperblue is offline
Old 01-05-2018, 12:54 PM   #28
fastball
Drives: 2017 Camaro 2SS 6MT
You'd have to check with the dealer, but I'm pretty sure the cushion and leather covering on it are all one part. You just need to specify the color.
But in all seriousness, we're talking about human bodily fluids. As someone in the healthcare field I can assure you you do not want to just "clean" the contaminated areas. You need to replace them.
No one in their right mind would ever sit in your passenger seat again if they found out someone urinated in it.
fastball is offline
