Old 12-28-2017, 08:49 PM   #15
hammdo
'It's an experiment'
hammdo's Avatar
Drives: [COTW 2/09/15] '11 GPI LSA SC Z/LE
I use flatstoppers:
https://raceramps.com/car-ramps/car-.../flatstoppers/
http://www.camaro5.com/forums/showpo...postcount=1021
But really only sits about 3 weeks in the winter here in Dallas (around the holidays)...
-Don
747 RWHP 794 RWTQ
"Horsepower sells cars, torque wins races." - Enzo Ferrari
See My Build: http://www.camaro5.com/forums/showthread.php?t=385577
hammdo is offline   Reply With Quote
Old 12-28-2017, 10:29 PM   #16
camaro5
camaro5's Avatar
Drives: X-15 Velocipede
You’re going to want to raise the vehicle up. You want to get the weight of the vehicle up off of the tires, because that will destroy the tires over time.
That means you’ll need jack stands or some sort of supporting device. On a vehicle, you want the jack stands out as close to the wheels as is possible.
Because you want the springs compressed.
You do not want them hanging down and unloaded. Which can damage them over time.
http://www.motorweek.org/features/go...g_term_storage
A big problem for cars is the tires on them, they tend to flat spot when they’re sitting.
Now the old tried and true way to do it is to use jack stands, one at each corner, as close to the wheels as is possible.
This prevents that. Under this BMW we have something new.
It’s called a tire cradle, and the manufacturer says that it will prevent flat spotting.
Race Ramps RR-FS Flatstopper (Pack of 4)
4.3 out of 5 stars 120 customer reviews | 32 answered questions
List Price: $267.00
Price: $253.12 Free Shipping for Prime Members
https://www.amazon.com/Race-Ramps-RR.../dp/B003ZAGJAM
Go from the presence of a foolish man, when thou perceivest not in him the lips of knowledge
General Motors ASEP, A.S. Automotive Technology, Telecommunications Specialist, CISCO Network Engineer
STANDARD DISCLAIMER
camaro5 is furnishing this information "as is". camaro5 does not provide any warranty of the information whatsoever,
whether express, implied, or statutory, including, but not limited to, any warranty of merchantability
or fitness for a particular purpose or any warranty that the contents of the information will be error-free.
camaro5 is offline   Reply With Quote
Old 12-29-2017, 08:11 AM   #17
Zl1dad
Drives: 2013 zl1
Originally Posted by rjacobs View Post
You've obviously never purchased shocks/struts from a store... they are banded in the compressed position.
You obviously don't know what a LOADED strut is. That means spring is compressed on strut already but not with vehicle weight.
Sent from my HTC 10 using Tapatalk
Zl1dad is offline   Reply With Quote
Old 12-29-2017, 08:12 AM   #18
Zl1dad
Drives: 2013 zl1
Originally Posted by HDRDTD View Post
Back when the 5th gen ZL1's came out, Goodyear had posted a recommendation for the tires that recommended not driving on them under 40 degrees F, to not even store them at temps less than 20 degrees F.
Evidently the tires were subject to sidewall cracking under those conditions, so many of us that don't have a heated garage, would take the stock tires/wheels off during the winter months and store them indoors.
I have no idea if those same recommendations apply to the tires that come on the 6th gen ZL1's, but perhaps that's where the OP's worries came from ?
Exactly sir
Old 12-30-2017, 06:38 AM   #19
awh3r
Drives: 2018 Black ZL1
Rubber Mats
Originally Posted by JeffFox View Post
As advised by my dealer I park the Camaro on rubber matts for the winter. I was advised "hanging" the wheels/leaving the car on jackstands may expose the strut shafts to the elements and if done this way grease should be applied to the exposed part of the shafts to prevent rusting. Of course with the weight of the wheels and tires removed the exposed length of each shaft would be lessened. Hope this helps. I do not use jackstands for winter storeage.
Can you tell me where you got your mats? Are they specifically made for this purpose? I have my ZL1 in a heated garage however i am concerned that the tires will develop flat spots. Thank you for your help.
awh3r is offline   Reply With Quote
Old 12-30-2017, 07:10 AM   #20
motorhead
The car was bult and design to spend its life on its tires. It was only designed to be on its jacking points for short periods of time. Ive been storing cars for many years as friends of mine do too. Non of us have ever lifed a car to store it. I have never seen an valid reason to do so. I can only see reasons way its a bad idea. Number one being the chance if it coming off and falling. No chance of damage while sitting on its own shoes.
Old 12-30-2017, 07:16 AM   #21
JB'sZL1
Drives: 2013 ZL1 and 2019 Ram Laramie
Google flatstoppers or other brands. Can be had at Amazon, EBay or other vendors.
JB'sZL1 is offline   Reply With Quote
Old 01-01-2018, 12:03 AM   #22
JeffFox
Drives: 2018 2SS Coupe A8
I use these, they seem a bit thin but worked fine: https://www.amazon.com/exercise-tile...ssx%3Arelevanc
JeffFox is offline   Reply With Quote
Old 01-01-2018, 12:26 AM   #23
CruzySS
CruzySS's Avatar
Drives: 2016 Camaro 2ss
The tires will not crack below 20 degrees just sitting there. Only if you try and move it. Had tires exposed to ( -25) degrees.. yes negative 25 degrees.. with no cracking of any sort.
CruzySS is offline   Reply With Quote
Old 01-01-2018, 09:06 AM   #24
wwiiavfan
Drives: 2017 1SS Hyper Blue
Best of both worlds. Had these made locally for about $150.
wwiiavfan is offline   Reply With Quote
Old 01-01-2018, 09:40 AM   #25
Soleil
Soleil's Avatar
Wow this is perfect how thick is the plate?
Soleil
Old 01-01-2018, 10:32 AM   #26
JeffFox
That is my understanding also.
Old 01-01-2018, 01:13 PM   #27
wwiiavfan
1/4” thick mild steel.
Old 01-01-2018, 03:48 PM   #28
motorhead
I love this idea. Keeps the car safely planted as it was designed and keeps it's shoes round.
Great idea.
