Old 09-22-2017, 10:12 AM   #15
1le32907
Drives: Summit white 1le ss
Originally Posted by PRAY View Post
You should be able to re cal the sensor. Just check your trims with a scanner. The narrow band 02's are in control of everything but WOT. Normal driving should still be fine with them in control.
Yea normal and accel driving seems to read okay some times the o2 does go to 9 but i don’t feel any loss of power which makes me think the bung is not right. How to do you re cal the os wideband bung?
1le32907 is offline   Reply With Quote
Old 09-22-2017, 10:17 AM   #16
PRAY
PRAY's Avatar
Drives: 2016 2SS
I am not sure on the AEM. I run a LM2 with a interface. I just go into the interface and do a re cal. I am sure there is a procedure for the AEM.
Old 09-22-2017, 10:48 AM   #17
1le32907
Will running methanol ruin the wideband o2 bung in the x pipe
Old 09-22-2017, 10:58 AM   #18
PRAY
PRAY's Avatar
Drives: 2016 2SS
I don't believe so. Lot's of guys have been running it regularly for a long time.
Old 09-22-2017, 11:11 AM   #19
1le32907
Okay I’ve been hearing mixed stuff that why I ask lol
Old 09-22-2017, 11:11 AM   #20
Joe's_cool_1le
Drives: Black 2017 Camaro SS 1LE
Here is the response I just received on AEM's forum.
2017 1LE SS Black - Mods - Forged - lowered compression - BTR custom Cam - Whipple, 3.500 upper and 8.0 lower pulley, Roto-Fab, 1 7/8 Kooks headers, off road pipes, & 3" Kooks full exhaust. LT4 fuel system, with Alky single nozzle running 100% meth. (not installed yet) DSX Tuning flex fuel and DSX tuning Aux pump
Joe's_cool_1le is offline   Reply With Quote
Old 09-22-2017, 11:23 AM   #21
1le32907
Could we both have exhaust leaks
Old 09-22-2017, 11:51 AM   #22
PRAY
PRAY's Avatar
Drives: 2016 2SS
I concur.
Old 09-22-2017, 11:57 AM   #23
1le32907
Aren’t our o2 sensors turned off
Old 09-22-2017, 12:00 PM   #24
PRAY
PRAY's Avatar
Drives: 2016 2SS
Only the rears get turned off with headers. Your fronts are still in full control of the car. You would have to be in OLSD running off your WB to not use the factory fronts.
Old 09-22-2017, 12:03 PM   #25
1le32907
What is olsd
Old 09-22-2017, 12:06 PM   #26
PRAY
PRAY's Avatar
Drives: 2016 2SS
What is olsd
Open Loop Speed Density.
Old 09-22-2017, 12:11 PM   #27
1le32907
Thank you
Old 09-22-2017, 12:59 PM   #28
1le32907
Hey joe did your shop use kooks header gaskets or gm gaskets if it’s the kooks I think we may have found the issue
