#15 |
![]() Drives: 2017 ZL1 A10 Join Date: Nov 2009
I don't know of any tuner worth a damn that just turns it on. They all tune to the vehicle.
#16 |
![]() Drives: 2015 Charger SRT Hellcat(732rwhp) Join Date: Mar 2017
Will this allow you to run blends? Can I have some 91 AND some E85 or E40 in the tank at the same time? Or do I have to run one out before filling with the other?
Rides-
2015 Hellcat Charger-732rwhp/708rwtq 2017 ZL1 6M- Rotofab CAI, Katech ported Tbody |
#17 |
Drives: 2017 50th 2SS Join Date: Jan 2017
Yes, the whole purpose of the flex sensor is to allow the flexibility to run any variation of fuel mix from full e85 to straight gasoline..
#18 |
![]() Drives: 2019 Corvette ZR1 Join Date: May 2017
It really depends on modifications. The fuel lobe on the cam is worth a lot at higher power levels.
#19 |
retired badass
I don't see anything on their site for "low side" pump. From what Im seeing this would cost over $2 g for less than 50 HP? bout craziest thing Ive ever read.
2016 2SS M6 Black
Kooks 2in headers/full exhaust, Hurst short shifter, Dsx E85 kit, BMR solid engine mounts. Retired USMC |
#20 | |
https://dsxtuning.com/collections/flex-fuel-kits |
#21 |
![]() ![]() ![]() Drives: 2017 ZL1 Join Date: Aug 2016
How much power are people getting just from sensor 50/50 mix?
#22 | |
retired badass
2016 2SS M6 Black
#23 |
Camaro pilot
Drives: 69 Camaro, 2014 ZL1 Join Date: Dec 2015
Why would GM have the tables in the ECU, but not activated? Seems like it could be just another selling point. (Maybe future proof?)
2014 ZL1 Camaro
1969 Camaro |
#24 |
In reality, the Flex Fuel kit is going to give you the HP, the low side fuel system is going give you the extra fuel when you are making bigger power. So for the 300 bucks plus tune is worth it. Especially when you add force induction into the mix. Flex Fuel kit is possibly one of the best bang for buck mods out there. Especially on GM vehicles where you can switch back and forth on fuel once it's tuned.
#25 |
![]() Drives: 2018 ZL1 A10 Join Date: May 2017
I was always curious about this. Are there any fail safes for if the sensor stops working that you won't blow up your motor?
#26 | |
retired badass
2016 2SS M6 Black
#27 |
![]() Drives: Camaro Join Date: Mar 2017
Because the computer and operating systems are used in a variety of other vehicles with various configurations that do support flex fuel. They aren't going to reinvent the wheel just to have that feature turned on or off. It's not activated from the factory because the factory fuel system on the LT4s are not up to the task of running a full 85% ethanol fuel with any sort of headroom what so ever.
19 ZR1 | 16 Viper GT | 09 Z06 | 94 LS1 GT | 16 Denali | 19 CTS
http://www.gonicd.com |
#28 |
Thank you Al Oppenheiser!
