Old 10-13-2017, 01:32 PM   #15
apexit53
apexit53's Avatar
Drives: 22 1SS 1LE Summit White
Originally Posted by hzycamaro View Post
Since you have driven both BRZ and Camaro in autocross, you must have a clear understanding of the difference. I once took a ride with an instructor in his open top Miata, such a big difference!
Yeah I mean lets face it, autocross does favor smaller cars. Though Ill say Ive had a blast this season racing tough competition in FS and learning a new car. Also its more fun on the street
#53 F Street
2025 FS National Champion
2025 Sponsor autocrossdigits.com
Autocrossing Videos
https://www.youtube.com/channel/UCm-...3tiMt0KOg_2Aag
Instagram: apexit_53
apexit53 is offline   Reply With Quote
Old 10-13-2017, 06:02 PM   #16
jwisjw
Drives: 2017 Camaro SS
The last event at Crow's Landing, I ended up raw timing my former class, STX, which I raced a FR-S as well. So it is very course dependent in California. The courses up towards Irvine/AAA Speedway SCCA area are pretty "brisk"... Enough to notice brake fade on the stock pads. I would encourage you to try one event at least to see how you like it. More Camaros, the merrier.
Jeff Wong
ESP Camaro
jwisjw is offline   Reply With Quote
Old 10-13-2017, 07:06 PM   #17
Tim202
Drives: 2018 ZL1 1LE
I think his complain comes from the fact that fast acceleration doesn't give you much advantage in autocross because of tight turns and slow courses
True, but fast acceleration is good for drag strip. Autocross is a good how-do-I-turn-my-car-better teacher. Some would even say that autocross is a better handling teacher than a road course. I however have too little experience at road courses to make that call.
My point is compared to light and small cars, Camaros are more difficult to get a good result in autocross. Maybe I should not compare Camaro with Miata in the first place. Maybe that's why SCCA has so many different classes
Yes a good miata driver will kick our butts, but I still have fun in my class.
Tim202 is offline   Reply With Quote
Old 10-15-2017, 07:14 AM   #18
jwisjw
Just curious, have they classed the ZL1 1LE yet? IIRC, the ZL1 was in A street, would imagine the ZL1 1LE would probably be closer to SS or the obvious, CAM-C.
Jeff Wong
ESP Camaro
Old 10-15-2017, 10:33 AM   #19
Norm Peterson
corner barstool sitter
Norm Peterson's Avatar
Drives: 08 Mustang GT, 19 WRX
Autocross will teach you more about transient handling, road course is where you're far more likely to reach your car's steady-state (midcorner) balance. The risks are far lower, which makes it easier to push yourself and the car harder.
Autocrossing is also closer to street driving and street emergency speeds, but the downside to most autocross lots is that you don't have things like pavement edges and the ruts/dirt/mud just off-pavement to be keeping at least in the back of your mind like you have to in either street or road course driving.
Norm
Old 10-15-2017, 10:54 AM   #20
Norm Peterson
Your friend sounds like me
Physics at work here. As long as you're using much tire grip for cornering, you're limited on how much acceleration you can use (no matter how much acceleration potential your car has). Second gear with 3.91's in the diff, the front wheels still turned and the car not pointed pretty close to directly down the straight, and you won't feel like you're using anywhere near the torque that you know is available because you won't be. Can't. The lower powered Miata won't be throwing away nearly as much of what isn't one of its strengths in the first place.
Classes are supposed to be set up such that cars of generally similar performance compete directly against each other. Small, light, and NARROW being good things (it can be mathematically proven that any given slalom requires higher lateral g's in your Camaro than in a Miata if you're going to run through it in the same amount of time).
FWIW, your performance through a slalom as a driver gets better (you'll at least come to hate them less) once you start consciously starting your turning to go around each cone before you get to it. It takes a finite amount of time to spin the wheel over, and the tires are only gradually getting around to where they need to be pointed, so you need to be giving yourself a head start on it all. That's when "getting behind the cones" starts making more sense.
Norm
Old 10-15-2017, 04:22 PM   #21
hzycamaro
hzycamaro's Avatar
Norm
That's some really interesting comparison between road course and autocross. I don't have any track experience but I do notice a lot of cars lost control in autocross
hzycamaro is offline   Reply With Quote
Old 10-15-2017, 04:26 PM   #22
hzycamaro
hzycamaro's Avatar
Norm
I'm not sure I understand but I'll try to practice it in next autocross
Old 10-15-2017, 06:21 PM   #23
Tim202
Not yet. I'm still running AS. If it does end up in SS...I'm not sure where I'll race. SS and CAM-C here are pretty much non-existent.
Old 10-15-2017, 07:06 PM   #24
apexit53
apexit53's Avatar
If its SS does that mean it also qualifies for SSR? Cant lie that car might be a lot of fun on Rcomps! hah
#53 F Street
Autocrossing Videos
Old 10-17-2017, 07:56 PM   #25
jwisjw
Should maybe try making the trek out to our local events...
The events here on, out, are at AAA speedway but CAM-C is mighty healthy when the events are at Irvine, can't speak for Fontana though. Link below is from our last event, quite a few people from the SD region do drive up.
http://members.quixnet.net/free2000/..._fin.htm#CAM-C
Jeff Wong
ESP Camaro
