Old 09-01-2017, 07:35 AM   #15
Paully104
Novice Driver
Paully104's Avatar
Drives: 2016 2SS Silver
Just wanted to follow up that I ended up returning the part as I was having issues with the connection. This may be user error but I am asking others who have installed the part if you experience issues where you get pop ups stating you need a suspension service to contact DSC to let them know.
Modifications: BMR suspension & front brace, DSC v2 controller, ported throttle body, Rotofab intake, Rimblades rim protection (red)
Paully104 is offline   Reply With Quote
Old 09-01-2017, 04:23 PM   #16
Ryephile
Hot Dog
Ryephile's Avatar
Drives: '17 1SS 1LE
That's a bummer. My connector was perfect out of the box and is still perfect after several connection cycles. I understand your frustration though. Are they sending you a replacement, or are you getting out of the game?
Old 09-01-2017, 04:55 PM   #17
Paully104
Novice Driver
Paully104's Avatar
I actually received a replacement and had the same issue and I attempted to correct on the new unit with needle nose pliars and I was unable to resolve the issue. I spoke with their support several times and tried various methods but ultimately I kept.getting suspension pop ups.
Old 09-15-2017, 11:29 AM   #18
bigwormgraphix
Drives: 1991 Z28, 2015 SS & 2017 SS
I have the same issue with mine. Some days it works great and other days I get the warning going on and off every 5 minutes.
bigwormgraphix is offline   Reply With Quote
Old 09-17-2017, 02:32 PM   #19
Chris V
Chris V's Avatar
Drives: 2017 1SS 1LE
Does it act up on hot days?
Chris V is offline   Reply With Quote
Old 09-17-2017, 05:13 PM   #20
Paully104
Novice Driver
Paully104's Avatar
Can you call them and let them know? If enough people mention it they are looking at doing a redesign.
Old 09-17-2017, 06:37 PM   #21
Atomic Ed
Drives: 2001 Audi TT, 2016 Camaro
Mine is working fine, even in 90+ degrees.
Atomic Ed is offline   Reply With Quote
Old 09-17-2017, 08:13 PM   #22
Chris V
Chris V's Avatar
I've had issues with two units, but correlated to high heat situations. Lots of traffic and idling in particular. Since the unit sits over the muffler, I think that's at the heart. The guys at DSC have been great though.
Old 09-17-2017, 08:57 PM   #23
bigwormgraphix
Mine acts up with no real pattern, it has done it at night when it was in the 70s and the car had been sitting and also in traffic. I also asked DSC about heat related problems since my car is a 2SS and the Bose amp is on top of the suspension computer, tech said he wouldn't get hot enough to cause a problem. Lately once I start getting the error message it repeats every 5-10 min as long as I'm driving. If I let the car sit overnight then it quits for a longer amount of time. I have checked the pins like DSC mentions and all pins are sticking out the same amount.
Old 09-17-2017, 08:58 PM   #24
bigwormgraphix
Yes, I have called them twice now. It's going back for them to check out the pins/connection.
Old 12-04-2017, 05:37 PM   #25
glamcem
glamcem's Avatar
Drives: '19 RivrsdBlu 1LE ('17 1LE HB sold)
any updates on pin or heat related issues?
glamcem is offline   Reply With Quote
Old 12-04-2017, 09:37 PM   #26
Chris V
Chris V's Avatar
Last update I got was a few weeks ago they said they were almost ready with the new version with the heat resistant processor.
My car is basically parked for the winter so I’ll order again in the spring so that if I have issues I can return it easily.
