Old 07-12-2017, 08:42 PM   #15
Blk16SS
Blk16SS's Avatar
Drives: 2016 Chevy Camaro
Originally Posted by DFW1LE View Post
I had thought about the Caddie racing lifters as well, but some of the comments in that link concerned me.
Concerns me too bro....
Blk16SS is offline   Reply With Quote
Old 07-16-2017, 10:00 AM   #16
bobshannon22
bobshannon22's Avatar
Drives: 2016 camaro 1ss
I went with the VVT-2 and TSPs heads with all the add ons. Heads are at TSP now.
If you want sound then just get exhaust and cutouts. If your auto you'll need a converter and if you're stick you're going to loose drivability with a stage 3.
2016 1SS (M6) Kooks headers and exhaust, pray ported MSD/TB, JLT CAI, JLT catch can, TSP heads/VVT-2 cam, E85, Centerfirce clutch, g force axels and DS, most of what BMR makes, blah blah blah
bobshannon22 is offline   Reply With Quote
Old 07-16-2017, 03:00 PM   #17
DFW1LE
DFW1LE's Avatar
Which fuel lobe are you going with: stock, 10, or 32%?
Old 08-14-2017, 05:14 PM   #18
ChadFarr
Instagram: @SSAVAGEVERT
ChadFarr's Avatar
Drives: 2016 SS M6 Vert
Can you still do the DOD Delete with the VVT-2 Cam?
2.9L Whipple | Compstar Rods, Diamond Pistons & GPI Cam | Mantic Triple Disc | Corsa Performance Exhaust | DSX Aux Pump | LT4 Fuel System | BMR Lowering Springs | ZL1 OEM Conversion | 360 Customs Built | And More!
Click & Follow My Build
ChadFarr is offline   Reply With Quote
Old 08-14-2017, 06:05 PM   #19
djfury05
djfury05's Avatar
Drives: 2017 ZL1 A10
Patrick G can always spec you a custom cam to your wants/needs. The cost for his recommendation is $25 and Texas Speed can grind it for you on your choice of lobes and material.
djfury05 is offline   Reply With Quote
Old 08-14-2017, 06:31 PM   #20
SSDanny
Drives: 2017 Camaro SS M6
How much are cam installs running aside from the tune?
SSDanny is offline   Reply With Quote
Old 08-14-2017, 06:34 PM   #21
ChadFarr
ChadFarr's Avatar
$1000+
Old 08-14-2017, 07:36 PM   #22
Daniel20162ss
Drives: 2016 2ss
Point me to anyone that can install for 1k thats not gonna ruin your motor. I was quoted $2700 for my lowest install price, thats with me supplying absolutly everything! Hence the reason my e85 kit and vvt-2 cam is now up for sale. I ordered my procharger!
Daniel20162ss is offline   Reply With Quote
Old 08-14-2017, 07:38 PM   #23
Daniel20162ss
Drives: 2016 2ss
$350 shipped if anyones interested in the cam. Thats 70 off price, plus shipping cost. And tsp is good with working with you also, they told me if I wanted a boost friendly custom ground cam to simply send them the cam back and pay the $25 price difference for the custom ground cam.
Old 08-14-2017, 07:38 PM   #24
ChadFarr
ChadFarr's Avatar
That's why I said $1000 Plus Bc it depends on if someone is doing the DOD delete kit or not. If you are doing DOD delete, you gotta remove the heads and it goes up to $2500 and more. But if it's just a regular cam swap, then it's only $1K or so.
Old 08-14-2017, 09:08 PM   #25
USP45
Well, I am not someone to tell someone that they are wrong because I do not know everything, and there may be a way, but a cam install on one of these engines is going to run more than $1,000... Here is my build thread where I just did heads/cam on my 17 ZL1.
http://www.camaro6.com/forums/showthread.php?t=500829
In my opinion (FWIW) there is really no way to do a cam in this platform, reliably at least, without pulling the engine. Now that is not to say someone will not try, and they may even succeed, but it would be a crap shoot. You CANNOT get the timing chain off without removing the oil pump. Cannot get pump off without dropping pan. Pan is sealed on and it would be very, very hard to drop it enough to clean the surfaces well enough to ensure a good seal and then there is a great chance that bits and pieces of sealant would drop in the pan. Other issue will be that there is not enough room to pull cam out the front without removing radiator which is in turn connected to all of the heat exchangers in front of it.... which means cracking open a/c and removing all of it.
My initial intentions were to do everything with engine in the car but after taking things apart and looking it very quickly became apparent that pulling the engine was the only way to go. Hence you will not get it done for a grand. But I've been wrong once or twice before.
USP45 is offline   Reply With Quote
Old 08-15-2017, 01:47 PM   #26
SSDanny
Is DOD delete only required on A8's or do you have to do the same with M6's?
Old 08-15-2017, 08:53 PM   #27
ChadFarr
ChadFarr's Avatar
I think it's required on M6 cars Bc it's in the engine but just disabled.
Old 08-15-2017, 09:21 PM   #28
USP45
Even the ZL1, none of which have DOD, have the DOD lifters. I went with the LS7 lifters in mine simply because they are tried and true, they have a good reputation. Not overly expensive either.
