Old 06-25-2017, 01:30 PM   #15
cmitchell17
Drives: 17 2SS, 8L90, Cam, Heads, E85
Originally Posted by jrs580 View Post
Yes I did. I found a good concrete launch area and it made all the difference.
Does launch control still work right with all your modifications?
cmitchell17 is offline   Reply With Quote
Old 06-25-2017, 07:31 PM   #16
bybcous
bybcous's Avatar
Drives: 2016 Hyper Blue 1SS
I don't believe these tuners. I used my 1/4 For the first time today and never have ran below 11 seconds. I ran a 12.9 on the street. I run 11.5 faithfully on track.
1ss/Auto-Hyper Blue
DELIVERED 12/29/15
Old 06-26-2017, 07:44 AM   #17
jrs580
jrs580's Avatar
Drives: 2016 2ss
Yes the launch control works well. You just have to stand on the brake and trust it.
2016 Black Camaro 2SS A8 Red interior
Modifications:Red powder coated Whipple LT1 blower, Aeroforce interceptor w/vent pod, FI Interchiller, Roto-Fab breather, ARH full length headers with high flow cats, JRE AFM modules, Borla S type NPP exhaust, Mishimoto catch can, JMS fuel pump voltage booster,MRR 017 1LE replica rims, 285/35zr20 Goodyear Eagle F1 G:2 front, Toyo r888r 325/30/zr20 back, Phastek blackout kit for the reflectors, GM dark tail lamps, Blendmount radar detector mount with Escort Redline hardwired in.
jrs580 is offline   Reply With Quote
Old 06-26-2017, 03:10 PM   #18
Jason@JacFab
Send a message via AIM to Jason@JacFab Send a message via MSN to Jason@JacFab
Ran this 3.92 this morning on the way to work.
Old 06-27-2017, 07:56 PM   #19
cmitchell17
What are you using to time?
Sent from my XT1635-01 using Tapatalk
Old 07-01-2017, 06:44 AM   #20
Goohead
Horsepower whisperer
Drives: Camaro
Is it just me that I can never use launch mode on the a8 and do the 0-60 timer?
Track mode
2x tap on track control
Foot on btake and pedal to the floor
Waiting for the timer to say press sel to start and all it says is car needs to be stopped first??
Seems the car moves slightly throwing off the sensor must have tried this for an hour straight
Goohead is offline   Reply With Quote
Old 07-01-2017, 07:13 AM   #21
HyperBlueX2
HyperBlueX2's Avatar
Track mode
hit the button after you are on the brake under power.... or it will drift and start the timer....
Old 07-01-2017, 11:21 AM   #22
Jason@JacFab
That's a P3 Multigauge in the picture. Along with typical gauge things it can read from the obd2 port, it can also do 0-60, 0-100, 60-100, 60-130,0-130,60-0, Etc times using the vehicle speed data through the obd2
Old 07-01-2017, 11:40 PM   #23
Goohead
Drives: Camaro
Yeah tried that, won't allow me to go into the mode cause it detects the car moving. In track mode, competition mode, launch mode at 2k
Old 07-02-2017, 09:39 AM   #24
jrs580
jrs580's Avatar
Drives: 2016 2ss
Are you hitting the brake really hard? If so I would take it to a dealer.
Old 07-06-2017, 09:45 AM   #25
attymf
attymf's Avatar
Drives: 2017 SS
Was just tooling around last night and tried it out. Road was a little rough and had a little spin before it hooked. I'd say I can prolly get 3.3 or 3.2 out of it if i tried a little harder. Just punched it. Didn't use foot brake or heat the tires.
SS, A8, Procharger, M&T's and stuff...
attymf is offline   Reply With Quote
Old 07-06-2017, 09:49 AM   #26
jrs580
jrs580's Avatar
Drives: 2016 2ss
Nice!
Old 07-06-2017, 10:16 AM   #27
attymf
attymf's Avatar
Drives: 2017 SS
What do you think it will run in a 1/4 mile with a 3.4 0-60 on the street. I ran 12.258 bone stock and best 0-60 stock was 4.2.
Old 07-06-2017, 02:21 PM   #28
ULTRAZLS1
ULTRAZLS1's Avatar
Nice run you got me.
You should be in the tens at the track with a hard launch and decent conditions.
My car launches much harder at the track than it did on the street for the 3.5 0-60. That was launch control with slight bog.
