#15 |
![]() Drives: 2017 Camaro 2SS Join Date: Mar 2017
i've noticed that mine do not return exactly where they should. Like they are angled down ever so slightly from where they were. I don't use them anymore.
2017 NGM 2SS NPP M6 MRC Vortech SC, 2" TSP LT No Cats, Borla X, Eibach, Hurst shifter 603hp/547tq |
#16 |
![]() Drives: 2018 Red Hot ZL1 1LE Join Date: May 2017
Stupid question:
Is a backup camera not standard? |
#17 |
it is but the tilt mirror is more for checking wheel clearance from curb and what not,
#18 |
#19 |
yup exactly
#20 |
Just thought I missed something.
My GT had static mirrors and no backup camera, and I sort of managed. Just have to be careful. My F150 has the camera and no mirrors, and still haven't really had an issue. So, this should be a breeze. |
#21 |
雪の玉
Drives: '22 Z71 RST Silverado Join Date: Feb 2011
only have the passenger side tilt down.
#22 |
![]() Drives: 17 NFG ZL1 17 GTR 22 RS6 Join Date: Apr 2017
^ ill try that!
#23 |
The Black Emerald
Drives: '17 ZL1, '08 Trailblazer, '11 1LTRS Join Date: Sep 2011
Try changing the tilt while in reverse and see if it goes back to the position you chose.
#24 |
@Blackmamba_1LE
Drives: 2017 1LE Join Date: Jun 2017
Under what setting is this exactly, sorry but i have 3 days with my car.
#26 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2019 Silverado Z71 6.2L A10 Join Date: Mar 2017
I just set mine today. I didn't know I could do it. And also set the auto seat movement when I get out of the car. I love it. What a great car.
Current ride
2019 Silverado Z71 LTZ 6.2L L87 425hp A10, 4 inch BDS Lift with Fox Factory Race 2.5 Coilovers, Borla Cat back (15HP bump), BFG KM3's 33's. Past Rides 2017 M6 Camaro ZL1 Hyper Blue 2016 M6 GT350 White with blue strips 2014 M6 Mustang GT Premium Track Pack Ruby Red 2012 M6 M3 Melbourne Red Metallic |
#27 |
![]() Drives: 2017 ZL1 10 Speed Auto Join Date: Dec 2016
Do this:
Let's say that you have one key fob that you use and you keep the other stored for backup. Identify the assigned number of the key fob that you use (#1 or #2). For this example, let's say you are using #2. In SETTINGS - VEHICLE - COMFORT & CONVENIENCE, turn EASY EXIT and AUTO MEMORY RECALL - OFF. Also turn off the tilt mirror in reverse function. Now set the driver's seat to your exit position. Press Set, keep holding, 1 beep, keep holding, press EXIT, 2 beeps, let go of both buttons. Adjust your driver's seat and mirrors to your normal driving position. Repeat the procedure with SET and button 2. Adjust only the mirror or mirrors to tilt down to your prefferred angle then repeat the procedure and Set button 1. Finally, Turn on Easy Exit and Auto Memory recall - NOT the tilt mirror thing. Now Driving position on start and easy exit on engine off and door open should work automatically. When reversing, press (manually) and hold button #1 to tilt the mirrors to your specs. That is how my Z is setup.
Previous cars:
1964 Pontiac GTO 1967 Pontiac GTO 1969 Pontiac GTO Judge 2004 Pontiac GTO 2006 Pontiac GTO |
