Old 07-16-2017, 08:38 PM   #15
Brianw36
SNSTRSS
Brianw36's Avatar
Drives: 2016 Camaro 2SS A8
Any progress with this build?
2016 Black Camaro 2SS A8 NP
Brianw36 is offline   Reply With Quote
Old 07-16-2017, 10:42 PM   #16
hitmix300
2016 loaded 2SS
hitmix300's Avatar
Drives: Maverick X3 Turbo R
Originally Posted by Fast6.3 View Post
he can do a relay & resistor method as well for 10$ if there is a budget, works good.
https://www.hptuners.com/forum/showt...ng-for-nitrous
hitmix300 is offline   Reply With Quote
Old 12-01-2017, 02:43 PM   #17
Turbo_RORO
Turbo_RORO's Avatar
Drives: Camaro 17 SS
Updates? Progress?
Turbo_RORO is offline   Reply With Quote
Old 01-19-2018, 01:04 AM   #18
SilverSS1LE
SilverSS1LE's Avatar
Drives: 2017 Summit White 2SS A8
any updates on the build?
Mod List: Stock (for now)
SilverSS1LE is offline   Reply With Quote
Old 01-22-2018, 11:56 AM   #19
DiGiam
DiGiam's Avatar
Drives: 2016 NFG SS A8
Man, this dude has left the building. Good luck getting him to respond to anything
2016 NFG 1SS A8. Pray ported intake manifold, Rotofab dry cai, kooks 2" catted longtubes, E85,
DiGiam is offline   Reply With Quote
Old 01-22-2018, 01:38 PM   #20
BlackbeastSS2
BlackbeastSS2's Avatar
Drives: 2019 Camaro 1LE Shock Candy
Originally Posted by Blk16SS View Post
Here's a universal tank from Nitrous Express. The pump, regulator, and plumbing retail for another 500-600 bucks to complete a standalone fuel system. So roughly $1000 bucks for that, then there's the question of how you deliver the nitrous by either a window switch or a progressive system. A progressive system would be alot better but wheel hop could still be an issue. So a one piece drive shaft and upper and lower control arms should be a high concern. A full hit on a window switch , its 50/50 on just how much the stock stuff will absorb. Then there's the AFM lifters. As I'm told , they seem to not like anything above a 175hp shot of nitrous. Im yet to 100% verify this however....
Just put this model NX 1503 in my build. Tank and pump in the trunk and regulator will be positioned as close to the solenoid as possible. I will be running the pump soon to set the pressure to 8lbs and will be putting a return tank in the engine bay. Still have to drill a hole and vent tank in the trunk for safety concerns. Wiring not complete, going to order custom lines measured for plumbing on Holley High Rise so it does not look like an octopus. LPE box is on order for Lingenfelter in order to retard timing for track runs. Still thinking on which level of shot to start with. The kit came with 100,200,300,400,500.
Rational I will start with a 100 shot, then 150, 175, and the goal is to be at max 200 shot. This all depends on how the 150 shot feels. At 200 shot and running race fuel in stand alone fuel system should be fine. But it depends what the dyno reads in HP power at 150 shot. With a plate system that sprays in each runner the HP can exceed the nozzle size and potential manufacturers estimate.
My cost was $389 for tank. (lines/fittings/gauge added another $200)
My build is Natural Aspirated so no high boost stand alone fuel system which is a lot more and probably like the quoted post said.
LT4 1.7 Supercharger snout ported & 100% Meth
103 Katech TB, KATECH Custom Heads, DSX In-line fuel
TSP Headers, Spec P Super Twin Clutch, TSP EL C7 CAM
Diamond Piston & Manley Rods, Roto Fab Big Gulp
BTR Push Rods,LS7 Lifters, ARP, FI Chiller, Kirkey Seats
SJM Line Lock, Hurst Pistol Grip. 747/739 RWHP street tune - 821/794 RWHP track tune 101 octane.
2014 Mini Cooper countryman S All4 M6 daily driver
BlackbeastSS2 is offline   Reply With Quote
