#15 |
![]() ![]() ![]() ![]() ![]() Drives: 18 Silverado 1500 Join Date: Dec 2015
It's like buying octane boosters. Waste of money.
#16 |
Drives: 2017 Camaro 2SS 6MT Join Date: Aug 2006
You won't get a performance boost by using 100 octane......
However...... If you look for pure gas, as in 100% gas with 0% ethanol, that can actually help pep up your engine and improve fuel economy. Not every gas station carries it, they're sort of few and far between. You can look on pure-gas.org for your closest station. It's not cheap either, with regular 87 octane going for about $3.79/gal. |
#17 |
![]() ![]() ![]() Drives: 17 2SS, 8L90, Cam, Heads, E85 Join Date: Dec 2016
#18 | |
Sent from my XT1635-01 using Tapatalk |
#19 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 17 Camaro SS 1LE & 16 Sierra AT CC Join Date: Nov 2016
Man, you all are getting gouged, I pay $2.69 for 91 octane 100% gas in the OKC metroplex. There is some confusion though with what is being said, yes pure 100 octane will not give a "performance boost" but 4-6 gallons of it will raise you up to 93 octane and all but eliminate the chance of detonation. With GM now saying to only run 93 octane in the Camaro SS/ZL1 it is now apparent that the powertrain calibration was done on 93 and not 91 octane. |
#20 |
![]() Drives: 2016 Mosaic Black, 2SS Camaro Join Date: Nov 2016
Are cars with California emissions able to take advantage of 93 octane fuel?
#21 | |
@zle_blackwing
Drives: 2018 ZL1 1LE Join Date: Mar 2017
#22 |
The owners manuals for all of the 6.2l vehicles all say now to run 93 octane and that if engine damage occurs running anything less it could void the warranty coverage.
#23 |
@zle_blackwing
Recommended in the 6.2. Required with the supercharged 6.2 with the caveat that using 91 will reduce performance and fuel economy. Voiding the warranty only comes into play if using less than 91 in the supercharged 6.2. A good deal of the country does not have ready access to anything higher than 91.
#24 |
I have a few different tunes set up, but with my 105 tune I run about 5 degrees more timing then my 93 tune. I did pick up more the a tenth and 2 mph in the 1/8 mile which would calculate to about 3 tenths in the quarter. Unless you tune for the higher octane I agree you probably one see any gains.
#25 | |
The updated manual now says all of the 6.2's now are required to run 93 and a warning of engine damage if running 87 that wont be covered under warranty. |
#26 |
![]() ![]() ![]() ![]() ![]() ![]() Drives: 2017 SS 1LE, 2016 1SS (previous) Join Date: Apr 2016
OK, I'm going to say a few things that haven't already...
Should you? No, I would not use it. Why? Nearly all available, at-the-pump, 100-octane has lead in it. This is not an issue if you do not have catalytic converters, but you most likely do (I don't know what you've done to your car, but the cats are probably still there). Lead can and will contaminate the catalyst. [Side note, can you guess a major reason why the ZDDP (zinc and phosphate package) in oil was greatly reduced almost a decade ago?] HOWEVER, if you want to try it, only do it in a small dose, like a gallon or two. BUT, I'll tell you exactly what you will find. And this is from experience. You will not gain more [peak] power, although you may feel that you do. What you will likely feel is that the engine is more lively throughout the entire RPM band, regardless of nearly any condition the engine is under. What I mean is this: I did this in my old 2012 Mustang GT during a summer. I only put in like 2 or 3 gallons mixed with about a gallon of old 93-octane. Over the course of about two days, I noted what I said above. Both days were very hot and humid. No matter how hard I drove the car, or what type of driving I did in the car, the engine just felt like a bull. But it didn't seem to have any higher of a PEAK power level. I even was able to do an autocross with the car during that period. I know what you're thinking - "Pff, autocross". But when you're banging the car around, going up and down the RPM, during very hot and humid weather in a setting that gives little airflow for good cooling... Also, yeah, Coyote to LT1. But both engines have high compression V8's that get strung out to about 7,000RPM (6,600 RPM for the LT1 - close) and the 2011-12 GT's have worse cooling than the 2016-17 Camaro's. The magnitude in which this will occur would likely be less in the Camaro, but similar. Last edited by Mountain; 05-12-2017 at 10:44 AM. |
#27 | |
@zle_blackwing
#28 | |||
![]() Drives: 2016 2SS, 2018 ZL1 A10 (RIPx2) Join Date: Jun 2016
Anywhere else where lead is still permitted, just look carefully at the pump. The EPA mandates disclosure of lead in the fuel and it should be fairly prominent on the pump. |
