Old 05-12-2017, 08:36 AM   #15
Michigan1LTRS
Blessed ❤️
Michigan1LTRS's Avatar
Drives: 2017 1LT RS I4
Originally Posted by psykostevo View Post
Based on your initial comment that spurred his reply, it sounded like you were stating that the stock charge pipe used to get hot, and the RPM pipe was just warm?
Well, I'm not sure of the heat differences between stock and your RPM pipe, but it looks fantastic and certainly hasn't hurt performance. It's a fine piece.
Old 05-12-2017, 09:55 AM   #16
Corner carver
Corner carver's Avatar
Drives: 2017 Camaro 2.0T RS
Looks great Michigan! Just those 2 parts really cleaned up the engine bay
Have you thought about doing something with the valve cover (or any of the other plastic 'covers')?
Mishi's coolant overflow tank would look mint in there also
As Delivered: 2017 Mosaic Black 1LT RS 2.0T | M6 | HD brake and cooling | Bose & 8"screen | Front lip extension | Blade spolier | Black bowties | Painted splash guards
Installed Mods: 25% Window tint | Headlight, side marker and third brake light Phastek tint kit | GM black taillights with Gen5diy LED harness and bulbs | LED license plate bulbs | Gorilla lug nuts, black | GM 'performance' center caps | RS and sheild badges removed
Old 05-12-2017, 10:26 AM   #17
Michigan1LTRS
Blessed ❤️
Thanks! I'm very pleased with both of these items. Next thing I was looking at changing was the metal turbo cover. Not a lot of options out there for this. Only one I've seen is from ZZP, but it really doesn't look that different.
