Old 05-01-2017, 02:28 PM   #15
Evil-Bee-NH
603 Camaros
Evil-Bee-NH's Avatar
Drives: 2017 NGM I4 1LT Coupe
I don't honestly trust 3 second 2.0T times posted on Facebook when some trim models use the same gauge cluster. honestly if I ran a 3 sec 0-60 mph i'd do a complete walkaround of my car with the DIC up for 100% clarified truth because a 3 sec. pull in a 2.0T would be insane. I like how one member on youtube Coolest Courier actually does his on video don't know if that's anyone on here hope so.
Old 05-01-2017, 02:30 PM   #16
Evil-Bee-NH
603 Camaros
Originally Posted by rickwelch69 View Post
and the stupid timer will not let you actually step on the gas at all without the timer starting, how the hell you supposed to get a good launch? you think woulda made it key off movement ie: gyro
I can get it to not activate 0 to 60 sometimes I was thinking of adjusting it but mentioning it wasn't a true 0-60 but a 1 to 61 time I think may be the only option for some of us. I think my mods are actually hurting my 0 to 60 because of the extra torque and hp causing really obvious wheel hop.
Old 05-01-2017, 02:33 PM   #17
Corner carver
Corner carver's Avatar
Drives: 2017 Camaro 2.0T RS
Originally Posted by Jason@JacFab View Post
Well the timer doesn't really care if the car actually moves or not... If you spin the wheels to 60mph and the car doesn't even move because you're just spinning the whole time, the timer will still stop once they hit 60mph.
This was kinda what I thought... So someone 'traveling' 50-55mph with the tires lit up could stop the timer and have it say '60'...
@Evilbee: I don't think my time should be allowed as it was actually 0-57mph... I didn't know how to properly set the timer up last year; this weekend I'll try again and report back.
As Delivered: 2017 Mosaic Black 1LT RS 2.0T | M6 | HD brake and cooling | Bose & 8"screen | Front lip extension | Blade spolier | Black bowties | Painted splash guards
Installed Mods: 25% Window tint | Headlight, side marker and third brake light Phastek tint kit | GM black taillights with Gen5diy LED harness and bulbs | LED license plate bulbs | Gorilla lug nuts, black | GM 'performance' center caps | RS and sheild badges removed
Old 05-01-2017, 02:34 PM   #18
Michigan1LTRS
Blessed ❤️
Michigan1LTRS's Avatar
Drives: 2017 1LT RS I4
My timer does not start until I move. I launch from 3000+ rpms many times and timer is not going. Maybe you aren't braking enough?
Old 05-01-2017, 03:23 PM   #19
Jason@JacFab
Send a message via AIM to Jason@JacFab Send a message via MSN to Jason@JacFab
Mine starts as soon as I touch the gas pedal, even if the car isn't moving. It's almost impossible (for me) to get the rpms up for a good launch to get a good time. I've even tried holding the E brake button up while my foot was on the brake pedal. Timer just starts. It's just a gimmick me to as I can't get accurate info from it if the timer won't start when the car actually begins to move.
Old 05-01-2017, 03:25 PM   #20
Michigan1LTRS
Blessed ❤️
I wonder if this is a difference in 16 to 17 model years. My timer will not start until I move.
Old 05-01-2017, 03:29 PM   #21
Jason@JacFab
perhaps? I know 2016 manual trans guys it doesn't start until the car moves. But the Automatic guys seem to have the problem. Might a simple fix like a reflash from the dealer? idk...
Old 05-01-2017, 03:34 PM   #22
Michigan1LTRS
Blessed ❤️
Let's hope so, because yeah, that makes the timer pretty much useless for you.
Old 05-01-2017, 03:48 PM   #23
Corner carver
The 2017 manual is the same... Timer doesn't start till the tires start to roll
Old 05-01-2017, 05:48 PM   #24
Cgc15
Drives: 2017 1lt 2.0t white
2017, m6, injen Evo, zzp catless down pipeName:  image.jpg
Cgc15 is offline   Reply With Quote
Old 05-01-2017, 06:58 PM   #25
rickwelch69
rickwelch69's Avatar
Drives: 2016 1LT RS Turbo 4
16 m6, mine does the same....as soon as i touch the gas it starts timing
2016 2.0 RS::K&N drop-in filter::RPM Catless down pipe::RPM Tune::Mishimoto Hot&Cold side charge pipes::65ish mm throttle body::289rwhp/328lbft
rickwelch69 is offline   Reply With Quote
Old 05-01-2017, 07:01 PM   #26
Michigan1LTRS
Blessed ❤️
Nice job Cgc15!!
Old 05-01-2017, 07:10 PM   #27
Michigan1LTRS
Blessed ❤️
Ok, looks like the problem is A8 and M6 for 2016. I would think it has to be a software issue.
Old 05-01-2017, 08:12 PM   #28
turbojeep95
turbojeep95's Avatar
Drives: 17 Camaro lt, 22 Camaro LT1
Wow! What was your launch rpm for a time like that? Did you play with the tire pressure and did you happen to notice the temp?
turbojeep95 is offline   Reply With Quote
