Old 04-25-2017, 12:12 PM   #15
JeromeS13
Drives: 2017 1SS/1LE
Originally Posted by Sixgunsled View Post
Mine is a 1LE also which comes with additional cooling features. Same as the ZL1. It has auxiliary coolers in the front wheel wells.
All SS's have those.
Old 04-25-2017, 12:12 PM   #16
Sixgunsled
Sixgunsled's Avatar
Drives: 2017 camaro SS 1LE
Originally Posted by DevBlackSS View Post
Sweet install! got a p1sc going on with stg2 intercooler and race bov. Are you going to get professional tune?
Yes. A local shop here. Carl Messenger from Competition Auto tuned it.
2017 1000+hp Camaro SS
88/96 single turbo
manual to TH400 swap
15" conversion
Port injection
22K+ followers on Instagram @Sixgunsled
6.4K subscribers YouTube: Sixgunsled
Sixgunsled is offline   Reply With Quote
Old 04-25-2017, 12:14 PM   #17
Sixgunsled
Sixgunsled's Avatar
the auxiliary coolers in the front wheel wells, yes. But that also helps with the cooling with the intercooler being in front.
88/96 single turbo
15" conversion
Port injection
Old 04-26-2017, 08:53 AM   #18
ProCharger
Drives: Many C7's
Its wild that the SS's have them.... yet the ZL1 does not....
(One is actually a helper intercooler on that car)
ProCharger is offline   Reply With Quote
Old 04-26-2017, 09:55 AM   #19
toro1966
toro1966's Avatar
Drives: 2017 Camaro SS Convertible 50th
Only on coupes. The convertibles do not have the wheel well vents/coolers.
toro1966 is offline   Reply With Quote
Old 04-26-2017, 12:15 PM   #20
exxit
Drives: 2016 1SS D1SC Methfed Lowered Wrapd
Six, how was fitment of the stage 2 intercooler and the AC condenser? Did you do any bracket mods to make it work?
exxit is offline   Reply With Quote
Old 04-26-2017, 12:36 PM   #21
MR 45TH
MR 45TH's Avatar
Drives: 2018 ZL1
See post #43
http://www.camaro6.com/forums/showth...=491390&page=4
2018 ZL1…Many mods to come
MR 45TH is offline   Reply With Quote
Old 04-26-2017, 12:54 PM   #22
exxit
Originally Posted by MR 45TH View Post
Thanks for the response brother, I notice the pic shows that it is awful close... Mine was like that too, we bent it a bit away from it, but it wasn't that much distance even after that.
Is that after you adjusted or before? After adjustment did you clear all the way or just created a bit more gap
Old 04-26-2017, 01:05 PM   #23
MR 45TH
MR 45TH's Avatar
Drives: 2018 ZL1
No problem! That's the before pic. Once I removed that bolt as pictured I was able to make a decent amount of room.
Old 04-26-2017, 01:10 PM   #24
exxit
Did you end up putting a spacer between on the crash bar like another member did?
Old 04-26-2017, 01:25 PM   #25
MR 45TH
MR 45TH's Avatar
Drives: 2018 ZL1
I did. I used washers. Its a very tight fit without it.
Old 04-26-2017, 01:46 PM   #26
exxit
So just to be clear, that pic you sent with the really close hardline, that was With a washer before you bent it back, or did you go back and put spacers as well after that pic?
Old 04-26-2017, 01:47 PM   #27
MR 45TH
MR 45TH's Avatar
Drives: 2018 ZL1
That picture was before I did anything. that was just following the directions. From there is when I started making adjustments.
