Old 03-24-2017, 04:27 PM   #15
Megahurtz
Snackbar Tuning
Megahurtz's Avatar
Drives: 2023 SGM ZL1
Originally Posted by marknagy13 View Post
I am not wrong. The definition of a catback is an exhaust that is behind all the cats. You can google every page on the internet for that.
Also, the borla system is behind the cats but they offer another pipe called "adapter pipes" that delete the 2nd cat. The catback system in itself does not.
https://www.borla.com/chevy-2016-201...haust-systems/
I have the Borla system. There are no adapter pipes, only a different version of the Xpipe. The secondary cat delete midpipe bolts right to the factory manifolds after the primary cats.
Catback is a very loose definition so if you want to get technical fine. But your definition did not answer the OP's question properly. You only repeated what you've read on the internet.
Old 03-24-2017, 04:39 PM   #16
JeromeS13
Drives: 2017 1SS/1LE
Originally Posted by 16mosiac2SS View Post
Does the borla catless system bolt to the factory exhaust after the second cats or would I need a full borla catback with 2nd cats delete? If I can avoid having to pay for the portion of their exhaust with the AFM valves that's what I would like to do. Currently I have a botched second cat delete and I'm just trying to replace what makes sense. If I can get by with the factory mid pipe or most of it that would be fine. Hopefully this makes sense haha. I'm open to other options as well.
I plan on using the Borla 60606 with my OEM NPP muffler. However, to do so, I believe we'll need two of these style clamps to make it work.
https://www.summitracing.com/parts/vpe-1176
Old 03-24-2017, 04:52 PM   #17
SanDMaN2091
SanDMaN2091's Avatar
Drives: 2016 Camaro SS A8 NPP
And an added perk... when you delete 2nd cats its defined as a "RACE ONLY".... havent had to run inspection on mine yet but i feel like its going to cost a few extra bucks
DMS Flex Fuel-E85
HPTuners Ngauge
Roto Fab CAI,
LPE Ported/Polished 95mm LT5Throttle Body,
PRAY Ported MSD Intake Manifold,
SP Coated TSP 1 7/8" Catlless Longtubes
Hooker BlackHeart Cat-Back,
Mishimoto Catch Can (Which always has some nasty in it)
Instagram@Weapon_6
SanDMaN2091 is offline   Reply With Quote
Old 03-24-2017, 09:10 PM   #18
Sunsnare98
Drives: 2017 camaro ss
Ok smart guy...if you actually knew how our exhaust system works you would know that those adapter pipes delete the primary cats. The mid pipe option 60606 which is designed to turn an axleback system into a catbacks system deletes the secondary cats.
Hooker makes catbacks that delete the secondary cats as well. You just can't win...you a WRONG. Just admit it.
Sunsnare98 is offline   Reply With Quote
Old 03-24-2017, 09:53 PM   #19
Sunsnare98
That system also adds another pipe. Their catback sits behind the secondary cats. Anyone can remove the secondary cats and attach it to the catback but that does not mean that the cat back system deleted the cats. Its just a catback system with another pipe added. You will not find a catback without adding pipes that deletes cats.
Wrong again captain catback... they make test pipes that delete the primary cats. The secondary delete is picture below. You can clearly see it's one piece and that the ends bolt up to the primary cats. Seriously...what's the deal with people spreading misinformation...
Old 03-24-2017, 10:10 PM   #20
bryguycbr
bryguycbr's Avatar
Drives: 2016 2SS Nightfall Gray
Send a message via Yahoo to bryguycbr
I'm glad to see this pic you posted, this is exactly what Stainless Works put in my car, it shows the AFM valves also..........well done
2016 2SS, Nightfall Gray Metallic, Jet Black Leather, A8, MRC, Clear-Bra, ROTO-FAB CAI sound tube removed, Stainless Works Catback with AFM valves, ORACLE ghosted sidemarker set
bryguycbr is offline   Reply With Quote
