Old 03-07-2017, 11:12 AM   #15
iPODFAN11
iPODFAN11's Avatar
Drives: 2019 Shock ZL1
Normal. LV3, L83, L86, LT1 and LT4 are on the engine list for this PI (all those are Gen V small block engines).
#PIP5179B: Extended Crank Cold With DI (Direct Injected) Engines
The following diagnosis might be helpful if the vehicle exhibits the symptom(s) described in this PI.
Condition/Concern
DI (Direct Injected) Engines with concerns of extended or long crank time during cold ambient airtemps
Recommendation/Instructions
Direct Injection engines may have slightly longer cold crank times than that of port fuel engines.
Direct Injection systems run at higher pressures, and the mechanical pump on the engine must buildup the required pressure before the first injection event occurs.
The below are typical Direct Injection engine crank times on GASOLINE
Start up Coolant Temperature Crank Time
Above 10° C up to 1.5 sec
Between 10°c (50F) and (- 10°c 14F) up to 2.5 sec
Between (-10°c 14F) and (-20°c -4F) up to 3.5 sec
Between (-20°c -4F) and (-25°c -13F) up to 5 sec
Between (-25°c -13F) and (-30°c -22F) up to 7 sec
Below -30 deg. C -22F, the recommendation is to perform an assisted start (such as use of a blockheater).
Note: For ETHANOL fuel see #PIP5174: Extended Engine Crank Times When Using E85
Please follow this diagnostic or repair process thoroughly and complete each step. If the condition exhibited is resolved without completing every step, the remaining steps do not need to be performed.
From Super Chevy mag, April 2002: "Most of the weekend Settlemeire was meeting and greeting and quickly became known as simply "The Camaro Dude" (note, even his initials are SS)."
Originally Posted by fbodfather View Post
we're certainly looking at it -- but right now, the emphasis MUST be on getting the Camaro V6 and SS out -- and having it exceed your expectations....
Once that's done....................
iPODFAN11 is offline   Reply With Quote
Old 03-07-2017, 11:14 AM   #16
ChevyRules
Drives: 2021 Tesla Model 3 LR
If the LT4 is like the LT1, the high pressure fuel pump needed to build the fuel pressure to the levels needed for DI is driven by the camshaft. Where most other HPFP for DI engines are electric. Since the pump is mechanically driven, needs a few seconds to turn over to build that pressure before light off.
ChevyRules is offline   Reply With Quote
Old 03-07-2017, 11:20 AM   #17
Ryephile
Hot Dog
Ryephile's Avatar
Drives: '17 1SS 1LE
^^^it's a nice official sounding excuse, just keep in mind that no other OEM has long-crank issues that's related to DI.
A datalog of the rail pressure, and ultimately injector pulsewidth, would prove this.
Old 03-07-2017, 11:37 AM   #18
Kanine
Kanine's Avatar
Drives: 2017 Camaro ZL1 Hyper Blue
Mine does the exact same thing. I think its normal, although I did think it was odd initially as well.
Kanine is offline   Reply With Quote
Old 03-07-2017, 11:39 AM   #19
Blown67
Blown67's Avatar
Drives: 1967 Camaro, 2017 HBM ZL1
There's like a million posts on this apparently as I was told to use the search when I posted the same thing about mine a couple months ago. It's normal on the first start of the day or if the car completely cools down between drives. Mine does it every time, sounds just like mlee's video. That first hit is always the loudest and I usually forget that I'm in an apartment with the valves in track mode. Has to do with the high pressure pump being run off the cam, or so I've read from research.
Blown67 is offline   Reply With Quote
Old 03-07-2017, 11:41 AM   #20
ChevyRules
And as I mentioned, other DI engines use an electrically driven high pressure fuel pump so the pump is up to speed the moment you press the button. The engine has to be turning in order for the Gen V small blocks high pressure fuel pump to work.
Not sure how that is hard to understand. It's not a DI issue as others tend to say, but how GM decided to power the high pressure fuel pump that is needed for DI for the Small Blocks.
Old 03-07-2017, 11:52 AM   #21
^^^This... I just went out and did my 1st cold start of the day.
Same as in the video.
And really sorry someone told you to search. That's not the way we operate here.
Old 03-07-2017, 11:52 AM   #22
1967RS327
1967RS327's Avatar
Drives: 1967 RS 327 Muncie, 2017 ZL1 6spd
The long crank times has nothing to do with DI or push-button in general, otherwise every other DI and push button on the market would have the same "issue".
My hunch is it's priming the oil system prior to actually going into the crank fueling state. The crank times appear to be coolant and/or oil temp related. A warm LT1/LT4 engine fires much quicker than a cold one, and that's all in the calibration.
Until I do a datalog to prove or disprove this theory. You can rest assured however it's not a rule of thumb issue for DI or push button. This is a very intentional calibration by GM.
This is my theory also..
1967RS327 is offline   Reply With Quote
Old 03-07-2017, 12:12 PM   #23
Hammerli
Hammerli's Avatar
Drives: 2017 ZL1 Summit M6 PDR SR ECW
I appreciate this thread, was wondering if the long start times I experience were an issue. Interesting on their pump choice. In my 911 when I walk up to car in my garage, even before I touch the car I hear the whine of the fuel pump, the proximity key must trigger it, so is there a reason for the cam driven fuel pump in the LT4?
Hammerli is offline   Reply With Quote
Old 03-07-2017, 12:20 PM   #24
ChevyRules
Not sure if you're hearing the high pressure fuel pump or the normal fuel pump that is in the fuel tank.
As for why GM chose a mechanically driven pump vs electric, going to have to ask them. I believe GM uses electrically driven HPFP's for their other DI engines( the LFX in my dads ATS starts right up).
Old 03-07-2017, 12:27 PM   #25
mkorgan
Drives: 1970-1/2 Z-28, 2017 ZL1
Just so everyone know, my response was what I was told when I picked up my Gen6 ZL1 from the dealer. It has an extended cranking scenario (took longer to crank than my Gen5) to which I asked the mechanic in the shop to review. The mechanic who was their main guy for the Vette's said it was normal for the LT4 to take a bit longer to crank due to the fuel system pressure needing to build to support the DI. This is not me or my opinion, this is what I was told by the dealer.
mkorgan is offline   Reply With Quote
Old 03-07-2017, 01:01 PM   #26
Ryephile
Hot Dog
Ryephile's Avatar
Drives: '17 1SS 1LE
I'm sorry but you're mistaken. Every OEM GDI HPFP I'm aware of is mechanically driven, usually off a camshaft. Feel free to link me to an electric HPFP, but what you're probably thinking of is the low pressure pump in the fuel tank, those are always electric.
I do agree this "issue" doesn't make sense to be DI related, but a conscious GM calibration decision. Have you done any datalogging to observe the lack of injector pulsewidth during cranking?
Old 03-07-2017, 01:15 PM   #27
ChevyRules
Yep, you're right. My bad. Yeah the ones I found are also mechanical including the LFX's pump and as mentioned, it starts right up in my dads ATS.
So interesting...... Either way it's normal operation for these engines. Nothing wrong.
Old 03-07-2017, 01:17 PM   #28
Ryephile
Hot Dog
Ryephile's Avatar
Drives: '17 1SS 1LE
Ok cool.
The only reason from a calibration side I would allow for long crank is to prime the oiling system.
If someone can datalog rail pressure and injector pulsewidth during cranking, that would put a lid on the situation really quick. I'm away right now so it'll be a bit before I can get back to my car and datalog it myself.
