#15 |
![]() ![]() ![]() Drives: 2017 Camaro; 2017 Acadia Denali Join Date: Jun 2016
Failing to disconnect the battery should not set a code. There is no code for 'failure to disconnect battery'. Most commonly, I've seen codes being set for not tightening the clamp from the rear of the tube to the turbo and allowing unmetered air into the engine.
#16 |
![]() Drives: 2016 Camaro RS I4T Join Date: Jan 2017
I never disconnected my battery and i did not get a code maybe i got lucky
#17 |
It's not luck. Disconnecting the battery has absolutely nothing to do with installing a CAI. The only reason for disconnecting the battery is to not shock yourself, or damage any electrical components if you somehow make a ground connection with the positive post.
#18 |
![]() Drives: 2017 RS Turbo Join Date: Aug 2016
I added a link to a short video in the first post. It's just in the garage after work td. The fan is loud af but you can still here the difference from stock.
2017 1LT | RS | 2.0T | M6
331 rwhp , 350 rwtq ZZP Intercooler | ZZP Catted DP | Magnaflow Catback | Injen CAI | Tuned (BBR) | CNC Honed Turbo (TPC) w 14lb actuator |
#19 |
![]() ![]() ![]() ![]() ![]() ![]() Drives: 2017 Camaro 2.0T RS Join Date: Jul 2016
Was just gonna say 'turn off the industrial sized hair dryer!' lol
It does sound way more aggressive I bet it 'sings' under load now
#20 | |
I will probably wait to tune until I go turbo back. For now this is fun first mod to enjoy for a while until the weather gets warmer.
#21 | |
#22 |
Honestly I'm pretty certain I am going to go with Trifecta. I have been in contact with them and the support seems there. I tuned an old ride using them about 6 years ago and had only good things to say about their product and service. I know people have been hating on them a little here but that's not going to make me change my mind.
#23 |
#24 |
![]() Drives: 2016 Chevrolet Camaro LT Join Date: Oct 2016
#25 |
![]() ![]() Drives: 2012 Summit White 1Ls Join Date: Jan 2012
#26 |
603 Camaros
Drives: 2017 NGM I4 1LT Coupe Join Date: May 2012
If you put some powder or something on the seal you'll see it on your hood liner it seals alright I modified mine to keep the heat out from the small side and bottom openings.
MY 2017 I4 CAMARO BUILD JOURNAL | YOUTUBE | INSTAGRAM | 316RWHP - 385 RWTQ HPTUNERS DYNO TUNE | 12.693s @ 105MPH 1/4 Mile |
#27 |
I was curious about the seal to and did the same thing to see where it made contact. It really is not the perfect fit. A lot of open space at the bottom of the shield too.
#28 |
Blessed ❤️
Drives: 2017 1LT RS I4 Join Date: Sep 2016
The more I think about this, why would you not have a lid on it? Only reason I can think is for easy access. Hot engine bay air has got to be seeping in.
Kindness and compassion #OthersFirst |
