#15 |
603 Camaros
Drives: 2017 NGM I4 1LT Coupe Join Date: May 2012
I can imagine that has had quite a few broken parts unless they upgraded the internals. Which we can do through ZZP now.
MY 2017 I4 CAMARO BUILD JOURNAL | YOUTUBE | INSTAGRAM | 316RWHP - 385 RWTQ HPTUNERS DYNO TUNE | 12.693s @ 105MPH 1/4 Mile |
#16 | |
![]() ![]() ![]() Drives: 2017 Camaro; 2017 Acadia Denali Join Date: Jun 2016
#17 | |
#18 | |
I used to be Dragoneye...
....but there is a relationship... |
#19 |
Yes, I fully agree! A 6.2L piston will have a significantly larger area to distribute the force than a 2.0L piston. But this is cylinder pressure, not manifold pressure. Manifold pressure is essentially irrelevant since cylinder pressures are 20x higher! That was my point. It just irrationally irks me when people make uneducated comments about 'dur all thems boosts is gon' wear ur enginez out'. You know what I mean? And I'm not referring to you.
#20 | |
I gotcha now, just wanted to clarify since you seemed to reply to me. I made my comment based on the sheer power density of the thing. derrr.....
#21 | ||
Owning SSes for 50 Years
The new ride: 2023 Camaro, LT1, Sharkskin Grey
Previous Performance Cars: 1966 Chevelle SS 4M, 2010 Corvette 6M 1968 Dodge Charger R/T Auto 2012 1SS 6M 1982 Corvette Auto 2010 1SS 6A 1984 Corvette Auto 2016 2SS 8A 1999 Camaro Auto 2017 HBM 1SS 1le 2002 C5 Corvette 6M 2018 2SS 2006 Corvette Auto 2023 Camaro LT1 |
#22 |
Blessed ❤️
Drives: 2017 1LT RS I4 Join Date: Sep 2016
Wow, that is BAD!!!!
Kindness and compassion #OthersFirst |
#23 |
Make America Fast Again
Drives: 2016 HBM 1SS - M6 Join Date: Sep 2016
Hardly.
That motor running 30 pounds of boost as mentioned in a previous post wont last long between rebuilds. Sure, 650hp is really damn impressive, but hardly puts V8s to shame. A 6.2 on 30 pounds of boost would be well over 1000whp, and would handle the power better. I came from imports. I've had my share of 400whp 240sx's, and whatnot. I'll tell you first hand I'd take the 6.2L 450hp LT1 over those any day of the week. The power is much more usable, and starting with 450hp stock is a lot easier than starting with a less powerful 4 cylinder engine. Not to mention you can spool bigger turbos with the larger displacement engine. |
#24 | |
![]() ![]() ![]() ![]() ![]() ![]() Drives: 2017 Camaro 2.0T RS Join Date: Jul 2016
30psi of boost isn't as big a deal as it was 15+years ago, these engines will demand 20+psi stock; no argument that a 650hp 2.0 will have a vastly different power curve than a 650hp 6.2. Also, although the 2.0 can be built to support 'like V8' power you can't cut 200lbs out of the 6.2... To each his/her own ![]() Just want to be clear: no hate for any of the engine options here... They all have their own strengths and weaknesses... And there's nothing like the sound of an open exhaust Chevy small block
As Delivered: 2017 Mosaic Black 1LT RS 2.0T | M6 | HD brake and cooling | Bose & 8"screen | Front lip extension | Blade spolier | Black bowties | Painted splash guards
Installed Mods: 25% Window tint | Headlight, side marker and third brake light Phastek tint kit | GM black taillights with Gen5diy LED harness and bulbs | LED license plate bulbs | Gorilla lug nuts, black | GM 'performance' center caps | RS and sheild badges removed |
#25 | |
Blessed ❤️
Some people get their cages rattled by threads like this. That's their own insecurity. Most though can appreciate the reality here. Hope it's your reality CC soon!!
#26 | |
considered internal debate when ordering the car (ya, I was thinking about my build way back then)... And even though I died a little on the inside not getting the V8, I just couldn't 'check the box' that added all that weight to the nose of MY car.
#27 | |
Blessed ❤️
#28 | |
