Old 01-14-2017, 08:18 PM   #15
PolynesianPowerhouse
Big Samoan ina little car
PolynesianPowerhouse's Avatar
Drives: 2016 camaro
Originally Posted by bybcous View Post
Yea i dont even try, not worth it to me.
same... don't do car shows, and more about go, than shine.
Originally Posted by SSDan View Post
Well I guess so but I never use anything but top tier 93 and I get plenty of soot. Its just a fact of life and I roll with it.
same... from about 5K to 19K on this car. since then I've been back to 87. also ran 93, and even once put in some 100 octane from Sunoco at 7.99 per gallon, but pretty much the whole time I had my 2013 with LFX engine 31k to 102K... it still occurs.
didn't make much any difference in soot accumulation from my experience. its a by product of the combustion engine.
if you drive hard, and let off the gas after a good acceleration. unburned fuel will be in excess for a very small amount of time which can add to it.
our cars, and the LFX setups can adjust, but its usually the pulse width per octane used from the injectors. at a lower octane, the pulse width is usually a bit longer...higher octane will spray for a shorter pulse width. that's why people say, the gas lasts a bit longer. theres a guy that ran and datalogged tables over on Camaro 5 about this.
When I see posts asking "whats the best intake, exhaust, etc" .... the answer to that is like a grandfather telling his grandkids "if you put salt on a birds tail, it'll let you catch it" #ThinkAboutIt
"Winning Tip: Don't take my (or anyone else's) word for it. GO TEST IT!" - Dennis Grant
PolynesianPowerhouse is offline   Reply With Quote
Old 01-15-2017, 08:11 AM   #16
freddyD
Drives: 2020 rally green rs
yes mine does it too, they all do!just clean them and do not let the soot build up.After I claen my windows I take the damp paper towel and wipe out the tips just do this and they will always look good.Its just like brake dust-some things just have to be cleaned.
freddyD is offline   Reply With Quote
Old 01-19-2017, 11:22 AM   #17
JiffyMo
JiffyMo's Avatar
Drives: Summit White 2016 V6 RS 2LT
Originally Posted by Dayle1 View Post
At 2400 miles, mine was totally black. Cleaned it up as best I could, but I couldn't get it all off the chrome tip. Anyway, is this a common issue on the V6 and is it something to be concerned about?
I clean my almost daily.
JiffyMo is offline   Reply With Quote
Old 01-19-2017, 02:48 PM   #18
KirkH
A good sealant will help some of the soot slide off. I polished mine with drill attachment exhaust polish pads and Chemical Guys Light Metal Polish. Then I applied Jet Seal. They don't get as dirty now and what does stick wipes right off with a rag.
Old 01-19-2017, 07:14 PM   #19
CamaroBruno
CamaroBruno's Avatar
Drives: 16 Mosaic Black: 1LT; RS; NPP; Bose
Pull that NPP fuse and you'll have 1/2 as many tips to keep clean!
2016 Mosaic Black Coupe;
- 1LT, V6, A8;
- RS Appearance Package, Dual Mode Exhaust ("NPP"), Technology Package;
- Black Bowties, NPP "Fuse delete", Vitesse Throttle Controller
CamaroBruno is offline   Reply With Quote
Old 01-20-2017, 09:18 AM   #20
Goobaba
Drives: 2016 V6 RS Manual
Yeah, either obsessively clean or let 'em turn black. Lately I've been leaning towards the latter....
Goobaba is offline   Reply With Quote
Old 01-20-2017, 12:49 PM   #21
Sub
Sub's Avatar
Drives: 2017 ZL1
you can use 0000 steel wool. Wont harm the finish and gets it off (with a bit of rubbing). Then use a soap to clean it.. I think I use p21s. It helps a lot on the next clean..
My Car Blog and mods. Previous Chevys: 2016 2ss, 2015 C7 z51, 2004 C5 Z06
Sub is offline   Reply With Quote
