Old 01-08-2017, 11:54 PM   #15
awpti
awpti's Avatar
Drives: 2017 1SS Camaro; 2016 4Runner
I've got the rear-diff groaning problem as well. Already had the fluid replaced once, still doing it.
awpti is offline   Reply With Quote
Old 01-08-2017, 11:56 PM   #16
OMEN
OMEN's Avatar
Drives: Camaro SS
so have can you fix this thing? so if i buy 1 it must have that issue?! :(
2017 2SS RED HOT
Instegram:@Monther1988
Oman Camaro Team
Middle East, Oman
1LE front splitter, ZL1 Corsa Xtreme quad tips, x pipe, ZL1 Rear Diffuser, 1/LE Rear Emblems
CoCo 4 Life
OMEN is offline   Reply With Quote
Old 01-09-2017, 06:44 AM   #17
ctrlz
To which problem are you referring? There are at least 3 mentioned in this thread.
Old 01-09-2017, 05:27 PM   #18
activepat
activepat's Avatar
Drives: Red Hot SS 1LE
Is it me????
5000 miles and 10 months later and not one issue. I don't get it.
activepat is offline   Reply With Quote
Old 01-09-2017, 05:39 PM   #19
I`m Batman
I`m Batman's Avatar
Drives: 2016 Camaro SS M6
This guy seems to have similar problems as you. See vid below..
https://youtu.be/VJ00b7mN36M?t=65
Here's the fix... software update. There's a TSB for it apparently.
I`m Batman is offline   Reply With Quote
Old 01-10-2017, 01:11 PM   #20
ctrlz
This looks different to me. His goes to one screen and then is unresponsive. The OP showed a touchscreen which is switching views as if it keeps registering an edge press.
Old 01-10-2017, 01:22 PM   #21
whiteboyblues2001
whiteboyblues2001's Avatar
Originally Posted by xonos View Post
Oh shit, guys. I forgot to tell you something. Get this. On one of my warranty work service sheets, it says this:
"REAR DIFF FLUID DARK WITH METAL DEBRIS - DRAINED AND REPLACED FLUID"
What the ****, right? This thing is going to explode.
The metal debris is normal, it's from the gears wearing into each other.
whiteboyblues2001 is offline   Reply With Quote
Old 01-10-2017, 01:23 PM   #22
I`m Batman
I`m Batman's Avatar
If you look at 1:36 when he presses the home button. Then press "Audio", you can see the screen responded that the button was pressed. BUT the screen has a "phantom finger" that kept pressing "Text" then the "Phone". Then again when he press home. You can see that a "phantom finger" is repeatedly pressing around that area very rapidly, which causes the "unresponsiveness". Even though you can see that the screen did response when he presses other buttons. The OP's "phantom finger" doesn't press as rapidly as this guys' when the screen started to respond. lol
https://youtu.be/VJ00b7mN36M?t=96
Old 01-10-2017, 08:24 PM   #23
ctrlz
More likely from the clutch packs or plates in an LSD. The helical gears themselves will wear very slowly. The clutch packs are compressed by a preload spring or springs. The gear oil in an LSD serves to cool the gears and keep them lubricated. The friction modifiers act within the clutch assembly. These "modifiers" alter the shear properties of the gear oil.
An LSD strikes a balance between static and sliding friction. In straight line movement the preload spring locks both sides of the differential together and the rear wheels moves like a solid axle. This is static friction. In a turn, the wheels want to move at different speeds. The preload spring is tuned so that the clutches start to slip in a turn. This is sliding friction which has much lower "grip" than static friction. The friction modifiers are called that because they "modify" the friction coefficient and encourage the plates to keep slipping. This keeps the clutches from going grab-slip-grab-slip-grab-slip... and so on. That action causes chatter or groan.
For proper operation the clutch surfaces need to be machined properly and be free of debris. Some LSD's require a break-in procedure. I have not heard of that for a factory car, but those having noise problems might want to give this a try:
http://diffsonline.com/images/Differ...break%20in.pdf
EDIT: Some stuff I found on the Gen5 diff sounds similar, as does the solution:
http://www.camaro5.com/forums/showth...=417907&page=2
