Old 01-07-2017, 02:02 AM   #15
Sharp Shifter
Drives: 98 Transam drag car SOLD now 17 ZL1
1700 miles when i had it dynoed
Break in process, drive the hell out of it lol, I had a fully build trans am 780whp 850wtq and ever part i "broke in" never lasted. Everything i drove the heck out of including the broke in stuff i had to replace lasted for years. So i fully believe in break in how you plan on driving it.
Sold 780rwhp 840rwtq 98 Trans Am
Current car 2017 ZL1 Camaro
Sharp Shifter is offline   Reply With Quote
Old 01-07-2017, 02:04 AM   #16
Sharp Shifter
And thank you for the complements guys, i will be paint correcting and and ceramic coating it this weekend hopefully so ill be sure to post pics. Whitehead will be doing my work as far as mods
Old 01-07-2017, 02:45 AM   #17
396ssrat
Drives: 66 Chevelle SS
Being in Texas and having a broken in ZL1 ready to go you can be the firstreal owner to lay down the big number on a track. Find some sticky back tires and go make a few test and tune runs. You may find yourself a hero out of the box.
Represent the Chevy ZL1.
Old 01-07-2017, 09:38 AM   #18
bkswede
Drives: 2010 C63 AMG
What are you going with for ceramic coating? Doing clear bra as well?
bkswede is offline   Reply With Quote
Old 01-07-2017, 10:45 AM   #19
cwebster
Cal
Drives: 2017 6th Gen Camaro ZL1 Coupe M6
Nice dyno numbers! Those ODO miles rack up fast when you've got those wide open roads in TX, huh? Mine's just over 100 and parked under its cover 'til the weather clears here in E. NC. Nowhere to run it here with local drag strips closed and back roads treacherous.
cwebster is offline   Reply With Quote
Old 01-07-2017, 11:15 AM   #20
Sharp Shifter
Haha yes sir. Im using crystal serum black and exo. Also xpel front end which someone else will do that lol.
Track runs will happen asap!
Old 01-07-2017, 03:18 PM   #21
Zeke.Malvo
Zeke.Malvo's Avatar
Drives: 1969 Mustang MaCh1
Originally Posted by camelhead View Post
Engine builders usually laugh at the break in process procedure. Nascar engines see 9,000 rpm right now and they will endure far more than your ZL1 or minivan will ever see in its lifetime.
Will a Nascar engine last 150,000+ miles?
1969 Pro-Touring MaCh 1 - CHP 427w 10.8 comp - 3140 lbs. - 460 rwhp / 490 rwtq
T56 Magnum || 14" 6 piston front / 13" 4 piston rear Wilwood brakes || Hydraulic clutch || 9" Detroit Locker || TCP Coilovers || Forgeline Wheels 18x10 275/35 front, 19x12 325/30 rear
Zeke.Malvo is offline   Reply With Quote
Old 01-07-2017, 03:40 PM   #22
Zeke.Malvo
Zeke.Malvo's Avatar
Nascar engines are built to incredible tolerances. Street cam and compression in a fresh sprint cup motor and you'd probably get 1,000,000 miles.
Data please, and sources.
Old 01-07-2017, 05:50 PM   #23
bobby35ny
bobby35ny's Avatar
Drives: 18 ZL1 A10
How many pulls did you do?
Power change if you did more pulls?
-Bobby
ZL1::J-E-T-S JETS JETS JETS
bobby35ny is offline   Reply With Quote
Old 01-07-2017, 06:57 PM   #24
lt4camaro
lt4camaro's Avatar
Drives: 2021 LT1 10 speed auto
570 rear wheel HP = 655 at the crank. Exactly what it should be putting out. If the pull was done in a cold bay, that should help it not hurt it.
lt4camaro is offline   Reply With Quote
Old 01-07-2017, 08:00 PM   #25
Zeke.Malvo
Zeke.Malvo's Avatar
I'm more of a believer of about 10% losses.
Old 01-08-2017, 01:54 AM   #26
DGthe3
Moderator.ca
DGthe3's Avatar
Drives: 05 Grand Am GT
I tend to assume 13% for manuals & 16% for automatics these days. Time was, 15 & 20 were considered the norm but drivetrains have gotten a bit more efficient since then.
Yeah sure, coming right up. Keep in mind that the old 3.8L GM motors from the 90s have gone that far in taxi cabs, my "sources" there are the guys who own the cab outfits and drivers. Its really not a big deal Dude, believe what you will. Hope you enjoy your car man!
An engine in a taxi has a very different usage cycle than a racecar. Not sure who is more abusive to their engines: I've been in a cabs that weave through traffic quicker than Jeff Gordon at Watkins Glen. But even the worst of cabbies still need to get several thousand miles out of their engine, whereas a Nascar driver maxes out at 600some & typically in the 400 to 500 mile range for a given weekend.
........and HE WOULD KNOW!!!!
Camaro Fest sub-forum
Old 01-09-2017, 02:31 AM   #27
Sharp Shifter
Did 567 on the second pull, so did lose 3hp.
Old 01-09-2017, 07:47 AM   #28
Sales @ CAI Inc
Sales @ CAI Inc's Avatar
Drives: 2010 SS/RS Supercharged 427 Build
Impressive Stock numbers! Congrats!
Sales @ CAI Inc is offline   Reply With Quote
