Old 12-18-2016, 07:20 AM   #15
BowtieRocket
BowtieRocket's Avatar
Drives: 2016 Camaro 2SS- M6
Originally Posted by Norm Peterson View Post
They are in fact more properly called 'links', most likely because they have exactly two pivots, one at each end. This probably sounds picky when most DIY'ers call just about every suspension arm or link an arm, but it's technically correct to call these things links.
They just aren't "endlinks".
Norm
Excuse my ignorance, I was just referring to them as BMR does...
http://www.bmrsuspension.com/?page=p...687&superpro=0
2016 Camaro 2SS M6- Garage
BowtieRocket is offline   Reply With Quote
Old 12-18-2016, 08:07 AM   #16
BowtieRocket
Another point of note, is that the end links should be upgraded with the larger sway bars. Now that is where the "weak link" is in the front suspension. Stiffer sway bars are really gonna stress those end links and may not feel the full improvement of the sway bars.
Old 12-18-2016, 08:20 AM   #17
F1FTY
Drives: 2018 ZL1
Not an absolute. If GM uses the same end links from the factory on SS, 1LE or ZL1...then no endlink upgrade is necessary. Otherwise, GM would have done that..especially on the $62k ZL1.
F1FTY is offline   Reply With Quote
Old 12-18-2016, 09:12 AM   #18
BowtieRocket
Guess BMR doesn't know what they're talking about then huh? I get every company is out to make more money and sell more parts. But seems rather common sense that if you increase tension, supporting parts need increase strength as well...
Old 12-18-2016, 09:24 AM   #19
Norm Peterson
corner barstool sitter
Norm Peterson's Avatar
Drives: 08 Mustang GT, 19 WRX
If you go with bars stiffer than anything Chevy fitted, better/stronger endlinks would at least be the 'safe' way to proceed. You might also gain easier or more reliable access to the attaching hardware.
The metal portions of endlinks aren't going to compromise bar stiffness unless the links are actually bending (likely about to break if this is the case). Bar stiffness gets lost in the rubber chassis-side bushings, and in older endlink designs where split bushings were used as "pivots" instead of spherical joints.
The only excuse I can offer for BMR's and the rest of the aftermarket suspension industry's blanket use of the term 'arms' to cover 'links' is that they've painted themselves into a corner using common terminology all these years. Heck, even the term 'sway bar' is really something different from the way it's used in the aftermarket and on most car forums (it's really something related to trailer towing, not chassis cornering roll and handling).
Norm
Old 12-18-2016, 10:19 AM   #20
08z51c6
Drives: 2016 Camaro SS - A8, MRC, NPP
GM is supposed to be coming out with a kit that allows you to install the 1LE suspension on an SS with MRC. It even includes a calibration for the MRC.
Delivered: 2016 SS Nightfall Grey - 1SS, MRC, NPP, A8
Current Vehicle:
2001 C5 Corvette
Previous Cars:
2009 C6 Z06
2008 C6 Z51 PKG
08z51c6 is offline   Reply With Quote
Old 12-18-2016, 10:21 AM   #21
F1FTY
Drives: 2018 ZL1
Another absolute. Just because the ZL1/1LE bars don't exceed the capabilities of the factory endlinks does not mean BMR doesn't know what they're talking about.
GM wouldn't put swaybars on endlinks that snap or bend and warranty the vehicle.
That's not to say that with other, larger aftermarket bar offerings an endlink upgrade is not necessary. Nor that what BMR offers isn't necessary for different uses. If I wanted to corner balance a car, I'd want adjustable endlinks for example.
Old 12-18-2016, 10:51 AM   #22
BowtieRocket
I see your points gentlemen. I guess that says something about the GM offerings ability to make much difference. Guess we'll have to wait to see what Matt says...
Old 12-18-2016, 11:27 AM   #23
Norm Peterson
Going stiffer with the bars just to go stiffer isn't a good way to proceed when cornering & handling balance is really what you're after. Ultimately, you end up in the land of diminishing returns where huge amounts of added stiffness only reduce roll slightly and outside wheel operating cambers improve only fractionally with respect to that. While still adding considerable wheel rate in one wheel bump situations.
My semi-educated guess puts 2°/lateral g as a reasonable point to shoot for in a dual purpose street/track car. At that point (with springs somewhere between 50% and 100% stiffer than OE, bars maybe 50% stiffer), one front bar adjustment (soft to mid, or mid to firm) is only going to reduce roll by something like 0.1°/g. A single rear bar adjustment, maybe less than that. You probably wouldn't even notice this small of a difference in roll.
GM may well be erring on the side of conservatism with softer bars and springs, but I think once you've firmed things in roll up by 50% or so without screwing up the handling balance - that further improvement in terms of roll and cambers is going to come much more slowly than the increase in bar stiffness.
Norm
Old 12-18-2016, 11:22 PM   #24
Mountain
Mountain's Avatar
A few other points to consider about aftermarket components: adjustability and capability in respect to a said aftermarket company's suspension system.
BMR also sells lowering springs and sway bars MUCH stiffer than what GM offers for the Camaro (LT, SS, 1LE/ZL1).
Old 12-20-2016, 10:40 AM   #25
Nick S
Nick S's Avatar
Drives: 2013 Camaro 1LE
Plus the wall thicknesses for any bar that is not solid.
Be best with the two front bars pictured together and the two rear bars pictured together. Overall shapes and in particular the 'arm' lengths matter.
Norm
Hey Norm, not sure how the OP is going to measure wall thickness on the new bars (if they are even hollow) when there are no open ends of the tube. He would have to cut the bar into two pieces to measure this?? Or is there some other way I'm not thinking of to measure the wall thickness of the tubing with ordinary measuring tools?
Nick S is offline   Reply With Quote
Old 12-20-2016, 03:24 PM   #26
JaxChris
Sledge,
If you had ordered the MRC version, then there would be a calibration code in the box that you need to take to the dealer for the MRC to be tuned for the stiffer ride. Check with TGPG to see if he can provide it for you. You won't be giving an accurate review without it and it would be cool if the rest of us can find out these calibration codes and go to the dealer as well to have our shocks adjusted.
Cheers!
Old 12-20-2016, 03:44 PM   #27
Eric SS
#becauseracecar
Eric SS's Avatar
Drives: 2016 SS Sedan, 2016 Camaro SS
Originally Posted by JaxChris View Post
Sledge,
Cheers!
He didn't order the kit that comes with the springs and MRC calibration.
Eric SS is offline   Reply With Quote
Old 12-20-2016, 05:05 PM   #28
Sub
Sub's Avatar
Drives: 2017 ZL1
Lethal, how do they feel? Whats the consensus?
Is this considered a "GM" upgrade? Warranty still ok?
Sub is offline   Reply With Quote
