Old 02-23-2017, 07:42 AM   #15
Corner carver
Corner carver's Avatar
Drives: 2017 Camaro 2.0T RS
Turbo4s with the M6 are the same... 5th is to tall for major hwys and 6th is useless; I'd be in for this even if I had to do the axles and drive shaft as well to make it work
Old 02-23-2017, 07:58 AM   #16
Cdflyer
Cdflyer's Avatar
Drives: 2016 1SS 6speed
If you're willing to go that far, call up GForce and get the 9" conversion. Bolts in, still IRS, and more gear choices then you'll ever actually need! Be prepared to shell out over $5K though.
2016 1SS M6 P1SC Stg II 592rwhp/548rwtq (for now)
GForce Outlaw axles & driveshaft, TSP 2” LT’s, turndowns, RTS S71 drag pack with radials.
Cdflyer is offline   Reply With Quote
Old 02-23-2017, 12:25 PM   #17
Corner carver
I'll check it out, thanks for the heads up Cdflyer!
Old 08-08-2018, 03:26 AM   #18
phaedrus
phaedrus's Avatar
Drives: 2018 Camaro ZL1 Convertible, M6
Replying to this 2 year old thread bc that's how bad I want 4.10s foe my 2018 M6 ZL1 Convertible. Someone take my $!
phaedrus is offline   Reply With Quote
Old 08-08-2018, 07:24 AM   #19
Mountain
Mountain's Avatar
The diff in th 6G Camaros has gears fused to the differential carrier. There’d have to be an aftermarket differential and then gears could be made. OS Giken was looking at this, but have likely dropped out.
https://www.camaro6.com/forums/showthread.php?t=520468
Old 08-08-2018, 11:43 AM   #20
phaedrus
phaedrus's Avatar
Thanks, Mountain!
Old 08-08-2018, 12:07 PM   #21
DFW1LE
DFW1LE's Avatar
I am not sure that the ZL1 and 1LE eLSD has fused pinions like the SS, its a totally different pumpkin.
Frankenstein Engineering Dynamics Stage 1 H/C/E85 536HP/488TQ
Old 08-08-2018, 12:31 PM   #22
rotis
rotis's Avatar
Drives: 2019 ZL1 1LE
OS Giken has not given up, it's just been slow going.
rotis is offline   Reply With Quote
Old 08-15-2018, 01:35 PM   #23
Mountain
Mountain's Avatar
No, you are right. My statement was too much of a blanket...
Old 08-16-2018, 11:22 AM   #24
KingLT1
KingLT1's Avatar
Drives: 2016 1SS NFG A8
One solution is to go to a smaller wheel with a shorter tire and lower the car. 26" tire with a 3.73 is not a bad combination.
Old 09-02-2018, 03:19 AM   #25
gsbeavis
Drives: 2020 Camaro 1SS
I'm running a Tremec 6060 in my 68 Camaro with 4.11s and it's perfect but my trans is close ratio so 6th gear is .62. 75 mph is 2400 rpm. Might even consider a 4.30 in the newer cars with the longer 6th gear..
gsbeavis is offline   Reply With Quote
Old 03-23-2023, 10:49 AM   #26
BeefTaco
Drives: 2017 Camaro 2SS M6
I know this is a long shot, but have there been any updates on this?
BeefTaco is offline   Reply With Quote
