Old 12-10-2016, 07:45 PM   #15
So what makes the E-85 upgrade easier or more economical on the LT1 than the LS3? I'm thinking Injectors?
Old 12-10-2016, 08:00 PM   #16
Hard Parker
Hard Parker's Avatar
Drives: ZL1
Tune and sensor
2017 Camaro 1LE Nightfall Gray Metallic RIP ☠️☠️☠️
2017 Camaro ZL1 Black Exposed CF|Sunroof|6 Speed
Click HERE to follow my build!!
Click HERE to follow me on Instagram
#savethemanuals
Hard Parker is offline   Reply With Quote
Old 12-10-2016, 08:37 PM   #17
Originally Posted by Venom SS View Post
Tune and sensor
so are you saying it comes with a flex fuel sensor or easy to swap and the ECM is set up for this.
I just know it was my next step on my last car and was quite expensive to do.
Old 12-10-2016, 08:45 PM   #18
Burly
Burly's Avatar
$375 for inline fuel sensor and $400 tune. That's it. I want it bad.
http://efi-tuning.net/efi-tuning-201...kit-pre-order/
Burly is offline   Reply With Quote
Old 12-10-2016, 08:53 PM   #19
On the 5th Gens we had to change injectors. No wonder this has taken off on the 6th Gen.
Old 12-10-2016, 09:01 PM   #20
ULTRAZLS1
ULTRAZLS1's Avatar
They also gain more than the ls3 and most other na motors. Higher compression better gains from e85. The lt1 is 11.5.1. Ls3 10.7.1.
30-40 hp gains compared to 20-30.
Old 12-10-2016, 09:03 PM   #21
True, and I was going to do it with the LSA. Pretty sure that will be my 1st mod on the LT4 along with lower pulley.
Old 12-10-2016, 09:43 PM   #22
bybcous
bybcous's Avatar
Drives: 2016 Hyper Blue 1SS
So will this new option make it literally plug and play? Because the whole plugging the 1 wire in myself was holding me back from doing it myself.
1ss/Auto-Hyper Blue
DELIVERED 12/29/15
Old 12-11-2016, 07:05 AM   #23
JFM-jr
JFM-jr's Avatar
Yes this install could not get much easier.
2016 Hyper Blue 2SS A8,NPP,Moonroof
Pray ported factory intake manifold Ported TB
Rotofab
ARH 1 7/8 longtubes hi flow cats AFM deleted E85
11.0@124.9
11.65@118.8 pump gas,stock tune/exhaust
New combo: Pray Performance Heads/cam
MSD intake manifold and Circle D 3C
554/491 on E85 all work & tuning done by Pray
JFM-jr is offline   Reply With Quote
Old 12-11-2016, 08:06 AM   #24
Sub
Sub's Avatar
Drives: 2017 ZL1
If we needed service, and we removed it, would there be a record of its presence in the computer?
Install vid forthcoming?
Sub is offline   Reply With Quote
Old 12-11-2016, 08:11 AM   #25
EFI Tuning
EFI Tuning's Avatar
Drives: 2016 Camaro SS
The install will still require you to add one wire to the ECM connector. This is not difficult. You use a pair of needle nose pliers to remove the plug for that pin location then insert the new pin. Just take your time. I will be doing a full write up on the installation procedure.
The tune will leave a trace in the ECM.
Tim
EFI Tuning is offline   Reply With Quote
Old 12-11-2016, 10:21 AM   #26
pinoyscorpion951
pinoyscorpion951's Avatar
Drives: 2016 Bright Yellow 2SS A8
I have very little experience turning a wrench. I've let the pro's do any type of installation for me in the past. If I can do this, it should be a breeze for you. The instructions are pretty straight forward but I felt like a few steps were missing. Unbolting the fuse box really helps with accessing the ECM X1 connector. Also make sure you insert the signal wire all the way in. You'll feel it seating properly when you insert it all the way. I had the DMS kit by the way. EFI's setup seems much more install friendly.
pinoyscorpion951 is offline   Reply With Quote
Old 12-11-2016, 10:29 AM   #27
oldman
Drives: SS 6 speed of course
You are going to have a flash count change period.
Old 12-11-2016, 11:58 AM   #28
oldman
yes unbold ecm, wish the instructions were in color or just give me a color pdf. It take a while to make sure you have the correct pin, it snaps in and a gentle tug will tell you it is seated. This is a very easy install.
