Old 11-28-2016, 03:19 PM   #15
Boilermaker128
Drives: 2010 CobaltSSTC
Better for winter. Lol.
Boilermaker128 is offline   Reply With Quote
Old 11-28-2016, 03:20 PM   #16
Heavymetal454
Drives: '69 RS Pro Street
Mice across the nation were being decapitated. In fairness GM raised the car.
Heavymetal454 is offline   Reply With Quote
Old 11-28-2016, 09:06 PM   #17
nvrlast07
Drives: 2011 synergy green rs
i agree the tire to fender clearance is to much, but GM engineers did that for a reason i am assuming. Possibly due to down force, safety regs, or just simply to allow for the front end of the car to have more clearance when driving thru the autocross track.
I would not change the suspension to make it look lower in the front. Due to the magnetic ride control.
nvrlast07 is offline   Reply With Quote
Old 11-28-2016, 09:27 PM   #18
17CamaroZL1
Life's Short, Live Fast!
17CamaroZL1's Avatar
Originally Posted by Heavymetal454 View Post
Straight front axles are all the rage. ZL1 Gasser!
Rock it old school!
Life's Short, Live Fast! https://youtu.be/rTUv2p4T7OA 10.94 at 128 mph, 11.13 at 127mph 870 DA, https://youtu.be/e_X_LcpFp50 11.19 at 127mph 1100 DA, https://youtu.be/OXQiCQdQuH4 11.40 at 125mph 1800 DA
https://youtu.be/uWba1qs8M6Q 11.52 at 123mph 3500 DA
12/26/2016 Ordered!
2/8/2017 Built!!
3/2/2017 Brought Home!!!
Old 11-28-2016, 09:34 PM   #19
17CamaroZL1
I'd love to find out why they did it. The MR wouldn't be affected by lowering it. They're not position sensitive like good off road shocks. The MR can soften or stiffen at any point in the Pistons travel and the system monitors for adjustments 1000 times per second.
12/26/2016 Ordered!
2/8/2017 Built!!
Old 11-28-2016, 09:38 PM   #20
Mr. Wyndham
I used to be Dragoneye...
Mr. Wyndham's Avatar
Drives: 2018 ZL1 1LE
You just have to worry about over-travel on the ride-height sensors...
I doubt a 1/2-3/4 drop would risk that...but something to consider...
Old 11-29-2016, 11:08 AM   #21
Reichler
Reichler's Avatar
Drives: 2004 GTO & 2005 GTO
Yep. They may have MR, but it's still a strut/shock with internal physical travel limits. I'd really want to know those limits before I risked trashing a set of expensive MR dampers with drop springs.
Reichler is offline   Reply With Quote
Old 11-29-2016, 12:03 PM   #22
17CamaroZL1
Hopefully there's an easy way to drop them at the spindle instead of changing out springs. Then there's no worry on the shocks. As long as there's still clearance at full compression, everything's good. I'm sure company's will have drop spindles for them if there's not another way to do it. GM could have even stuck a spacer above the strut. Maybe someone can check there for us.
12/26/2016 Ordered!
2/8/2017 Built!!
Old 11-29-2016, 04:19 PM   #23
Heavymetal454
I know a guy who dropped his ZL1 already. Here's a spy photo. Sorry I couldn't get the whole car. Garnet Red ZL1 with dropped spindles. Sweeeeeet!
Old 11-29-2016, 04:45 PM   #24
BradfordCamaro
SABIO
BradfordCamaro's Avatar
Drives: 2016 CAMARO 1SS
The height is normal when it leaves the factory, GM never accounted for the shipping pucks. They are damaging the MRC and ZL1's are stuck in a unsafe high condition.
They are recalling all the ZL1's to replace the front suspensions.
Joking
Old 11-29-2016, 04:55 PM   #25
KaBoom1701
KaBoom1701
KaBoom1701's Avatar
Drives: 13' ZL1 Red M6
Dosent look right to me either.....
Mods:
Roto-Fab Intake, WW Res. kit & Big Gulp Air Scoop, Elite Catch Can, ATI Super Damper & 18% OD Pulley, LF Idler pulley bracket, Metco CC breather, ID850 Injectors, Stainless Power Headers w/ ceramic coating, TR71X Spark Plugs, JMS Fuel Pump Booster, Bo White TB, Tuned by Ted @ Jannetty Racing, Ron Davis HX, D3 Reservoir, Pfadt 1" Springs, Moreno Camber Plates, ZL1 Addons Splitter guard washers, Tow Hook kit & rock guards, Hurst Shifter Billet Plus 6 Speed Short Shifter, ZL1 DRL lighting harness, ZL1 Recaro Seats.
KaBoom1701 is offline   Reply With Quote
Old 11-29-2016, 06:58 PM   #26
tones2SS
tones2SS's Avatar
Drives: '13 Roush S3 '16 Ram Sport 4X4
HA HAAAAAAAAA
Dropped spindles!!!
tones2SS is offline   Reply With Quote
Old 11-30-2016, 09:20 AM   #27
Stoner
Drives: 2017 ZL1 HBM, M6
Originally Posted by hawk02 View Post
I agree the front seems to be sitting higher than the pre-production models that were shown at the various cars shows and press conferences.
Here's a side by side comparison I made of the front fender gap of my ZL1 and that of a pre-production ZL1. Sure looks like the gap is larger on my car.
Is it an optical illusion, or is there more clearance all the way around the fender opening, not just at the top??
Stoner is offline   Reply With Quote
Old 11-30-2016, 09:46 AM   #28
KLR ZL1
H-Town Camaro Club Member
KLR ZL1's Avatar
Drives: 17 Hyper Blue Metallic KLR-ZL1
People did the springs on the 5G ZL1 without any problems, don't see why there would be any issue with the 6G.
KLR ZL1 is offline   Reply With Quote
