Old 02-24-2017, 03:45 PM   #15
Ventmaster
Ventmaster's Avatar
Drives: 2017 1SS 6spd
Computational fluid dynamics aside, gentlemen- there is a difference in sound. Significant enough that some people may prefer the stock pipe.
Ventmaster is offline   Reply With Quote
Old 08-16-2017, 10:14 AM   #16
gippy87
Drives: 2016 2ss
All science behind I cant figure out why GM would have done this anyways. I see no added benefit there is plenty clearance in all directions.
gippy87 is offline   Reply With Quote
Old 08-16-2017, 12:06 PM   #17
1LE Red Dragon
Train Driver
Drives: 2018 Summit White ZL1 1LE
I also used to work for an OEM exhaust manufacturer in Toledo Ohio. Typically, the OEM and aftermarket replacement systems are not designed for power, they are designed for sound. Different baffling arrangement, resonator etc are used in OEM to get desired sound. If a crushed pipe has no affect on airflow, then the laws of fluid dynamics that have existed for many years, are all bogus. This is not the case. The velocity of the air will increase as the area is decreased through the crush section, and the flow rate stay the same. This will cause increased back pressure. This is fact.
Q=V*Area. If Area goes down, then Velocity, V must go up to keep Q (flow) the same. Increased velocity through this crush section and additional frictional losses.
If this were not the case, then no mandrel bent exhaust system or straight thru muffler would ever have added horsepower or torque. This is also not the case. NA motors are not as sensitive to back pressure issues as a turbo or supercharged car. Turbo being the most sensitive to back pressure because of the backpressure in the turbine housing which has a very small area.
Put both setups on a flow bench and you will see a higher air flow rate through the smooth diameter pipe compared to the crush diameter pipe. However if the crushed sections air flow rate when run on the car is still capable of flowing the amount of air needed for the airflow being moved by the engine, then the HP increase will be insignificant. But make no doubt the air flow potential of the fully circular area is greater than the crushed pipe and its reduced area.
2018 Camaro ZL1LE
/ / Katech TB // RotoFab Dry // Borla 60606 // ATI Super Damper / /
1LE Red Dragon is offline   Reply With Quote
Old 08-16-2017, 12:44 PM   #18
Sub
Sub's Avatar
Drives: 2017 ZL1
With all that said, one of the exhaust manufacturers did a study on the crushed pipe and found zero difference in horsepower. It may restrict flow, but its still not affecting performance. Save your money.
There is a video out there somewhere. I'm too lazy to search for it.
My Car Blog and mods. Previous Chevys: 2016 2ss, 2015 C7 z51, 2004 C5 Z06
Sub is offline   Reply With Quote
Old 09-25-2017, 07:02 PM   #19
SSDanny
Drives: 2017 Camaro SS M6
But is there a significant difference in sound? lol
2017 Camaro SS - Kooks Long Tube Headers 1-7/8th - EFI Flex Fuel Kit - Megan Racing Coilovers - FORGESTAR F14's 20x9.5 & 20x11
SSDanny is offline   Reply With Quote
Old 09-26-2017, 07:31 AM   #20
oneredry
HYPER SS
oneredry's Avatar
Drives: 2016 Supercharged 2SS
Crushed vs non crushed. No.
Ordered: 1/15/2016
2000 status 02/01/16
3000 status 02/29/16
3400 status 03/07/16 TPW of 03/14/16
4200 status 03/17/16 in transit!
Delivered 03/23/16
2SS Hyper Blue | 6M | NPP | Mag ride | ceramic white Int. | Black out bow ties | P3 Gauge| Front splitter. | 6 pot upgraded brembo brakes. | Magnuson Supercharger/95MM pulley | Rotofab Intake | ZL1 side skirts | HRE FF04 wheels - Michelin PSS4 | ZL1 add ons rock guards and lift points.
| AWE touring - resinated catback with link pipes.
oneredry is offline   Reply With Quote
Old 09-26-2017, 03:34 PM   #21
Redlinez
Shifts under load
Redlinez's Avatar
Hooker designed this BlackHeart crush pipe delete kit for the 16-17 Camaro SS to eliminate the crushed, factory mid-pipe that GM skimped out on. By replacing the inferior pipes you will gain up to 12.84 horsepower and 17.28 lb/ft of torque (tests were recorded on a dual mode NPP Camaro). This offers great bang-for-the-buck as the kit costs less than a few tanks of gas.
Sure would like to see the proof of this.
22 Suzuki GSX-S 1000GT blue
Old 09-26-2017, 03:49 PM   #22
SSDanny
I honestly can't see those gains being possible. Did they disclose if a tune was done?
Old 09-27-2017, 10:39 AM   #23
oneredry
HYPER SS
oneredry's Avatar
I would agree with this.. wonder if more flow was offered with the mufflers. Something in this equation is missing. you simply don't had 5 HP let alone the claimed numbers by just simply replacing the crushed pipes, of which has been noted many of times that it makes NO difference in HP or sound rating by just replacing that section. They do it for a reason.
Ordered: 1/15/2016
Delivered 03/23/16
Old 09-27-2017, 11:04 AM   #24
KingLT1
KingLT1's Avatar
Drives: 2016 1SS NFG A8
I am guessing since the crush pipes are so far back in the exhaust system where velocity is greatly reduced, the restriction is not that big of a issue compared to if it was up by the cats.
KingLT1 is online now   Reply With Quote
Old 12-02-2018, 10:11 PM   #25
wildchevy
wildchevy's Avatar
Drives: 2018 Hyper Blue 2SS convertible
you think for one minute GM spent a dime crushing those pipes for no reason?
2018 HBM 2SS CONVERTIBLE A8
wildchevy is offline   Reply With Quote
Old 12-02-2018, 10:44 PM   #26
What I read is the vert requires them to ensure clearance for the underbody cross-braces it requires for rigidity, and GM decided to save some cash by not having separate parts for the vert and the coupe, they simply installed the crushed pipes on both.
Old 12-03-2018, 07:32 AM   #27
EDFHOBBIES
Dyno Show Queen LOL
EDFHOBBIES's Avatar
If that adds 12hp than a CAI must close to 30 LOL!
Probably another scenario where a tune was factored in with the mod!
Old 12-03-2018, 09:04 AM   #28
Umbriel
Drives: 2016 Camaro SS
So there is no point on doing a cat back exhaust just buy an axle back?
Umbriel is offline   Reply With Quote
