Old 09-27-2016, 11:42 AM   #15
Mountain
Mountain's Avatar
Originally Posted by Mountain View Post
Rohana, Advanti, Konig and Forgestar are all wheels I've been considering. Probably going with Rohana's.
For sway bars, there's Strano, BMR, AFE and Hellwig. Probably doing BMR based on availability and design.
These are the wheels by the way:
Advanti DST Optimo
Advanti Svelto
Forgestar (CF5, CF5V, CF10, F14)
Rohana RFX5
Old 09-27-2016, 01:23 PM   #16
rotis
rotis's Avatar
Drives: 2019 ZL1 1LE
The BMR adjustable bar looks like 1.25" x .250w. That is the same size as the front bar that comes in the Hellwig set, which is what I tested at Crows Landing.
IMO, that's too much for the stock rear bar in F-Street trim, even on the softest setting. The Strano bar is 1.25" x .188w, which effectively softens each setting by the equivalent of one hole. I run mine on soft, and the car works very well.
rotis is offline   Reply With Quote
Old 09-27-2016, 04:54 PM   #17
Mountain
Mountain's Avatar
It is 1.25"x0.188" like the Strano:
http://www.camaro6.com/forums/showpo...4&postcount=17
http://www.lsxmag.com/tech-stories/b...sion-with-bmr/
Old 09-28-2016, 09:56 AM   #18
detltu
detltu's Avatar
Drives: 1992 Z28 1LE; 2015 Zl1
Very cool thread guys. Makes me wish I had a 6gen so I could set a car up for autocross.
1989 Camaro RS convertible- Sold
1999 Camaro SS - Stolen 2x
1991 Camaro Z28-
1991 Camaro Z28 1LE-
1992 Camaro Z28 1LE- 25th anniversary
2015 Camaro ZL1
detltu is offline   Reply With Quote
Old 09-30-2016, 10:19 AM   #19
apexit53
apexit53's Avatar
Drives: 22 1SS 1LE Summit White
The front camber is that with crash bolts or just what they can get out of the car factory? I wonder if they will have crash bolts for it.
apexit53 is offline   Reply With Quote
Old 09-30-2016, 06:48 PM   #20
Memphis43
Memphis43's Avatar
Drives: Chevy
This is all making me think the 1LE is definitely not going to be in f street anymore.
Meaning I'm gonna have to find my own combination of this as well when the time comes
Memphis43 is offline   Reply With Quote
Old 09-30-2016, 08:35 PM   #21
DetCam
DetCam's Avatar
Drives: 2016 1SS (12/10/2016)
IF the 1LE does somehow get classed as FS.... would those of us with the 2016 be able to run the 1LE wheel sizes?
DetCam is offline   Reply With Quote
Old 10-01-2016, 12:55 AM   #22
Gefiltefish
Drives: '17 1SS, HB 6M
No, that would not be legal.
I could see the 1LE SS being a good BS option. Or even CAM-C. CAM has some wild rules so pretty much anything goes.
STP could also be a place to play although you would have to downsize tires. I believe 285 is the current max allowed in STP.
STP was rather low on numbers so hopefully the STAC makes some changes to get numbers up.
Gefiltefish is offline   Reply With Quote
Old 10-01-2016, 01:50 AM   #23
Egon
Egon's Avatar
Drives: 2014 2SS/RS 1LE
With the performance we have already seen from the 2016 SS there is absolutely no way in Hell that the 1SS 1LE will get classed in FS. Its just too good of a car and it would completely upset the class. My guess is that it will go into AS where the GT350 (non R) is classed. I do believe that the V6 1LE will be allowed to run in FS and I think it will be an extremely tough competitor there.
In order to run the 1SS 1LE wheel sizes you would have to perform a complete option package conversion and it would have to be on a vehicle that was manufactured in the same year that the option package was available from the factory. Since the 1LE package was not available in 2016 you would not be able to perform this type of conversion on your car. In addition the complete option package conversion would entail replacing or adding the magnaride with the special tuning of the 1LE along with any special suspension components that were different from the base SS. You would also have to install the correct rear gears, e-diff, six piston Brembo brakes and rotors. If the cooling package is different between the 1LE and the SS you might have to change that as well since there could be a weight difference.
Thats a hell of a lot of work and expense just to keep the car in a street class, likely to be AS, where it will have an uphill battle against the C5 and C6 Z06 Vettes which dominate there due to their higher HP and a lot less weight. If it gets classed in BS it "should" have an easier time against the C4 and C5 non Z06 Vettes although they will still have a significant weight advantage. Bottom line although I think the 6th Gen 1SS 1LE will be the performance bargain of the century and I would love to have one, I think it may end up being uncompetitive in any of the SCCA Street classes and we are unlikely to see any 6th Gen 1LE winning a Nationals event in Street. However it could be a phenomenal inexpensive CAM car. (if there is such a thing) In the end if your goal is to get a car to be competitive in SCCA Street classes I think the regular SS's will be the car to get and run in F-Street.
Egon is offline   Reply With Quote
Old 10-03-2016, 03:43 PM   #24
apexit53
apexit53's Avatar
It wont be in F street.
From what I've heard it will be A Street or B Street.
Old 10-03-2016, 07:09 PM   #25
Memphis43
Memphis43's Avatar
Drives: Chevy
I figured as much. I'm leaning towards running NASA though now more so than SCCA.
Not autocross though.
Old 10-04-2016, 12:28 AM   #26
Z3papa
Drives: 2011 BMW M3 ZCP
There is no update/backdate in FS. You can't convert a 2016 to a 1LE. That's why putting the 1lE in FS is a problem beyond what it does to the rest of the class.
Z3papa is offline   Reply With Quote
Old 10-04-2016, 07:59 AM   #27
Norm Peterson
corner barstool sitter
Norm Peterson's Avatar
Drives: 08 Mustang GT, 19 WRX
SS to SS/1LE would only be an option package conversion for a 2017 SS, which is Street Category legal preparation.
Fitting the 1LE pieces to a 2016 SS is what would constitute update/backdate.
On edit, I suppose that means if you did convert a 2017 SS to 1LE spec, you'd then end up in whatever Street class a production 1LE gets put in.
Norm
Old 11-01-2016, 10:30 AM   #28
destoups
Drives: 2019 1SS 1LE
Well, here's a good idea.
TL;DR: 2.0T with brakes, intake, exhaust and most of the handling goodies.
destoups is offline   Reply With Quote
