Old 08-09-2016, 03:30 PM   #15
Gmanuel
Drives: 2007 335i
Walbro 450s are very popular E85 pumps. Could go with two, where one starts flowing when you pass a certain boost pressure. The BMW crowd I came from did setups like that on the N54.
Gmanuel is offline   Reply With Quote
Old 08-09-2016, 05:23 PM   #16
GirlyNFG
GirlyNFG's Avatar
Drives: 2016 Camaro SS M6 w/ NPP
Originally Posted by mild2wild View Post
Sweet build! Also off topic a bit, but did you get the New Era cam in before the other upgrades and dyno it? I'm local to them but haven't seen any other 6th gens around really, let alone modded.
I have:
Stock - 426
E85 -455
Procharger with 4.38 pulley & cam
Procharger with 3.90 pulley & cam & stainless works LTs on 28" hoosiers
Whipple 2.9, Custom New Era Performance cam,
E85, LT4 fuel system, Motec powered port injection, teeny tiny Nitrous Outlet system,
Stainless Works LTs, Centerforce Triad, GForce 9" with strange pro case 3.50 gears. Carlyle 15" conversion
28"x10.5" MT ET Drag 28"x4.5" M&H fronts
PB: 9.569 @ 151.05
GirlyNFG is offline   Reply With Quote
Old 08-09-2016, 05:23 PM   #17
GirlyNFG
GirlyNFG's Avatar
I decided to try the Cordes LPFP or whatever we are calling them today
PB: 9.569 @ 151.05
Old 08-11-2016, 03:04 PM   #18
JaxChris
I believe the Corvette crowd would be telling you right now that you are also out of pistons now too. Might want to get on the phone with Wiseco and tell them your specs.
Old 08-12-2016, 12:46 PM   #19
GirlyNFG
GirlyNFG's Avatar
I'm kinda excited that I might have the highest stock bottom end 6th right now... but I am also looking forward to forging it. oh, the struggles...
PB: 9.569 @ 151.05
Old 08-12-2016, 02:38 PM   #20
JaxChris
If your numbers are corrected and accurate, then I believe you do have the most power on the stock bottom end for a 6th gen. Now that you've set that bar, go get those pistons before you mar that beautiful block.
Old 08-12-2016, 02:44 PM   #21
GirlyNFG
GirlyNFG's Avatar
I am gonna run redlist first
PB: 9.569 @ 151.05
Old 08-13-2016, 09:57 AM   #22
Slowhawk
Drives: 1999 Trans Am
That's pretty good. I've seen the low side pressure drop hard at 600rwhp just on pump gas. Wonder if the lt4 stuff is just pulling a better vacuum on it.
Haven't had one of these tanks out yet but on C7's we drill the tank and add a secondary pump/boost activated that feeds into the low pressure line.
C7 pump runs out/bounces around the same 640, with secondary we have hit 1000hp with no low pressure side dropping.
Slowhawk is offline   Reply With Quote
Old 08-13-2016, 11:34 AM   #23
toohighpsi
Drives: 2015 C7 Z06 M7
Originally Posted by GirlyNFG View Post
Nope. On the roller with 28" Hoosiers on no less
I'd use some caution at the track, you are heading lean above 5500 (as told by the peak power nosing over so early and the A/F ratio). Have you set the rev limiter to 5500 to prevent operation in the higher RPM? Dynos are quite easy on the engine, but hitting that lean 6K+ rpm 3-4 times at the track in a row might not be a good thing.
Look forward to see you at Redlist! You should be able to knock down some serious times with that power. I ran 10.8 with 610 RWHP so 9s should be easily attained with nearly 750 RWHP!
Old 08-13-2016, 01:01 PM   #24
Joe@CPR.com
Drives: 03 vette, 94 trans am, 04 gto
your system is on the way to you sir! Thank you so much for all the orders Our C7 system, truck, and now 6th gen will support big power on the lt platforms and do it reliably. When it comes to the LTX platform we have been pioneering them since the first 14' C7's came out as our development car was vin #12 and that car makes 854 rwhp and has been doing so for 23k miles and does a ton of half mile and drag events on the stock bottom end.
Joe@CPR.com is offline   Reply With Quote
Old 08-13-2016, 04:06 PM   #25
GirlyNFG
GirlyNFG's Avatar
Right now I have timing pulled at 5500... fuel system is here. going in on monday. I have to work next saturday so I wont be there until about 5-6pm, but I will be there. My car is a M6, so I am not shooting for the moon. low 10s ( and still driving it home ) will make me happy
I'm a girl
I am a little nervous about being first to install this kit... but fingers crossed!
PB: 9.569 @ 151.05
Old 08-13-2016, 04:07 PM   #26
Joe@CPR.com
I'm a girl
This system is cake. Email me joe@cordesperformanceracing.com and I'll send you the instructions.
Sent from my SM-G935V using Tapatalk
Old 08-13-2016, 04:11 PM   #27
GirlyNFG
GirlyNFG's Avatar
emailed
PB: 9.569 @ 151.05
Old 08-16-2016, 03:33 PM   #28
LTWon
Drives: 2016 2ss
Great numbers! What are the specs on your cam?
LTWon is offline   Reply With Quote
