Old 08-09-2016, 09:10 AM   #1
GirlyNFG
GirlyNFG's Avatar
Drives: 2016 Camaro SS M6 w/ NPP
Low pressure fuel pump solutions
Mornin' guys.
I am on the hunt for a LPFP system. Last night my car made 746 at 5500 and we ran out of low side fuel. I have the LT4 high side pump and injectors.
Meth is a possibility, especially if I want to run 91 ever again. Whats out there for us?
GirlyNFG is offline   Reply With Quote
Old 08-09-2016, 09:29 AM   #2
V8SS
Drives: 2017 M6 NFG
Wow! 746!! sounds fun What octane?
Sorry I have no answer to your question :(
V8SS is offline   Reply With Quote
Old 08-09-2016, 09:33 AM   #3
GirlyNFG
GirlyNFG's Avatar
It's been on full e85 since about 2 weeks after I bought it.
Whipple 2.9, Custom New Era Performance cam,
E85, LT4 fuel system, Motec powered port injection, teeny tiny Nitrous Outlet system,
Stainless Works LTs, Centerforce Triad, GForce 9" with strange pro case 3.50 gears. Carlyle 15" conversion
28"x10.5" MT ET Drag 28"x4.5" M&H fronts
PB: 9.569 @ 151.05
Old 08-09-2016, 10:33 AM   #4
Atomic Ed
Drives: 2001 Audi TT, 2016 Camaro
Upgrade your in-tank pump yet? Assuming that you're done adding on goodies and will stay in the current configuration.
It's interesting data in that you hit the upper limit with your current setup on E85. Us normal gas guys can roughly extrapolate back to upper flows for us from this.
Atomic Ed is offline   Reply With Quote
Old 08-09-2016, 10:59 AM   #5
V8SS
Drives: 2017 M6 NFG
Oh, corn fed beast
Old 08-09-2016, 12:07 PM   #6
GirlyNFG
GirlyNFG's Avatar
I've still got the factory in tank pump. That is what I am looking to upgrade. It looks like the LT4 fuel system will be sufficient for now...
Current config... AHAHHAHAHAHAHH! for this week anyway.
PB: 9.569 @ 151.05
Old 08-09-2016, 12:08 PM   #7
GirlyNFG
GirlyNFG's Avatar
Originally Posted by V8SS View Post
Oh, corn fed beast
we practically have twins! M6 FTW
PB: 9.569 @ 151.05
Old 08-09-2016, 12:55 PM   #8
AGP Turbo
Drives: All things Turbocharged
Originally Posted by GirlyNFG View Post
Mornin' guys.
Are you talking power at the crank?
AGP Turbo is offline   Reply With Quote
Old 08-09-2016, 12:58 PM   #9
GirlyNFG
GirlyNFG's Avatar
Nope. On the roller with 28" Hoosiers on no less
PB: 9.569 @ 151.05
Old 08-09-2016, 01:01 PM   #10
AGP Turbo
Wow. That is unreal that you can flow that much E85 on the stock lift pump with your other upgrades.
Old 08-09-2016, 01:28 PM   #11
Ian SS
Ian SS's Avatar
Drives: 2016 1SS, 2017 JKU Wrangler
Do you have a build thread going? Kinda off topic but I'm curious as to what all you have into the setup. Planning on a similar route myself with the D1SC and I'm already on corn and would like to stay that way.
SLO 1SS - sold
1SS MRC NPP 6MT
2018 Ram Rebel 4x4 5.7
Ian SS is offline   Reply With Quote
Old 08-09-2016, 01:36 PM   #12
GirlyNFG
GirlyNFG's Avatar
I have the LT4 injectors and lift pump
As well as a 30% increase on my fuel lobe
Yup. its in the build section under ITBFST. I started it late though, I resisted the forum rabbit hole as long as I could.
PB: 9.569 @ 151.05
Old 08-09-2016, 02:22 PM   #13
Atomic Ed
Oops, my bad. Should have read closer.
A couple of shops who hang around on this sub-forum have, or will soon have, upgrades to the in-tank pump. None of them list them on their websites that I could find. Shoot the main two or three an e-mail and they can fix you up.
Old 08-09-2016, 02:24 PM   #14
mild2wild
Drives: 2017 1LE
Sweet build! Also off topic a bit, but did you get the New Era cam in before the other upgrades and dyno it? I'm local to them but haven't seen any other 6th gens around really, let alone modded.
mild2wild is offline   Reply With Quote
