Old 07-13-2016, 04:38 PM   #15
SuperSound
SuperSound's Avatar
Drives: '17 Camaro 2SS A8
Everyone missed the fact this is the first MRC car on the skidpad and it turned a better time than the prior review of a '16 SS. Looks like MRC has measurable performance increases over the standard suspension.
Old 07-18-2016, 02:53 PM   #16
Bobfly
OspreyTech
Bobfly's Avatar
Originally Posted by Fraxum View Post
Not really lame for a M6. This is just about the best you can get in bad air or with only a little seat time. Try it.
I've run mine at the track twice. 5 runs each time and my best time was a 12.82 @110 mph. I'm not a pro but I'm not without skills either. I learned to drive a stick about 48 years ago. Granted it was hot and humid but I expected a much better time and speeds near 115. Some cars just won't run...
2SS Nightfall Grey Metallic w/Ash Grey Interior, Silver Rally Stripes, 6M, MRC, DPP, Nav, Sunroof & Black Bowties
Bobfly is offline   Reply With Quote
Old 07-18-2016, 03:12 PM   #17
GreaseMonkey83
GreaseMonkey83's Avatar
Drives: 2016 Camaro
Do you know the date and an approximate time that you ran your car? You can go to dragtimes.com and find out what the DA was at the time you made your pass. That can have a huge affect on times. I recently went 12.46@114 in my stock '16 2SS M6 on a day where the DA was at a horrible 3350ft!! At first i was upset but after checking the corrected time (11.95@119) i was pleased with my run. It would be nice to know the day/time/place of these magazine runs as well.
2016 Garnet Red 2SS M6 MRC NPP and Sunroof
100% Stock - 12.10 @ 115.6mph - 3620 lbs lookin' at it
GreaseMonkey83 is offline   Reply With Quote
Old 07-18-2016, 03:32 PM   #18
AZCamaroFan
Camaro6 2016-2018
AZCamaroFan's Avatar
Drives: sometimes
No the blue 2SS they tested vs. a BMW a couple months ago had MRC. they said they prefered the standard suspension in that article.
Old 07-18-2016, 03:55 PM   #19
SuperSound
SuperSound's Avatar
Just went back and reread that. What's odd they said the both had the same times on the figure 8 in that H2H but in this review the MRC car posted a better one. Think optimistically there is very little performance difference between the two on the track.
Old 07-18-2016, 03:56 PM   #20
AZCamaroFan
Camaro6 2016-2018
Drives: sometimes
i've always thought of them more to benefit ride than handling.
Old 07-18-2016, 04:02 PM   #21
SuperSound
SuperSound's Avatar
Agreed, but with the dampening being stiffer and reacting faster than the standard dampers, there would be some tangible benefits. Just wondering if different test times/environment conditions are the cause here, or if it was a different lot they used altogether (one bumpy vs. smooth).
Old 07-18-2016, 04:10 PM   #22
C6J
My car is loaded like yours except auto. Ran a 12.2 @114 with 1100km on the car. Location where these car run would be good to know.
C6J is offline   Reply With Quote
Old 07-18-2016, 06:59 PM   #23
SS 1LE
マスタング = 遅い
SS 1LE's Avatar
Nothing to do with the cars, build tolerances on SAE engines is very tight.
It comes down to three things really on equal cars...
1- Driver skill
2- Track prep
3- DA
Old 07-18-2016, 07:41 PM   #24
prod
prod's Avatar
Drives: HHR
I see nothing wrong with a second test and reporting the honest numbers, people know the variables and that time difference really isnt much...
prod is offline   Reply With Quote
Old 07-19-2016, 08:28 AM   #25
jonny5cam
Drives: IOM SS/RS LS3/6sp. man.
Originally Posted by aestil View Post
If you guys had read the article they commented that they assume because it was a fresh engine it's running a little slower. They said they plan on going back and doing the measurements again once the engine had loosened up.
Do you guys not read the words and only look at the numbers? The whole article reads almost like a love letter with the only complaints being that the seat belt can be hard to find and that they don't like the 1->4 skip shift feature [which I think every dislikes].
Yeah, LS engines really start to wake up after about 5k to 10k miles.
jonny5cam is offline   Reply With Quote
Old 07-19-2016, 09:48 AM   #26
SS 1LE
マスタング = 遅い
SS 1LE's Avatar
The new Camaro SS doesn't have an LS engine though.
Old 07-19-2016, 11:47 AM   #27
AZCamaroFan
Camaro6 2016-2018
Drives: sometimes
they had the manual SS at 12.4 in the quarter in the first two tests they did of it last year including car of the year.
Old 07-19-2016, 03:28 PM   #28
ForgedReality
Envy
ForgedReality's Avatar
Drives: 2011 SGM 2SS/RS - Black hood/hockey
Maybe it SHOULD. Isn't the LT1 an iron block instead of aluminum like actually fast engines?
ForgedReality is offline   Reply With Quote
