Old 01-27-2019, 02:10 PM   #15
grampa_ss
grampa_ss's Avatar
I'm no expert, but isn't disabling DOD accomplishing the same thing? And disabling
DOD is in the ECM. That's how my tune is.
Old 03-01-2019, 09:03 PM   #16
18ss376
Drives: Camaro
In my HPtuners I have DOD disabled & AFM has nothing to do with DOD. I'm going to have to buy a credit to tune the FSCM so I can disable AFM. At least it's this way on a 2018 Camaro SS with A8 & NPP
18ss376 is offline   Reply With Quote
Old 03-02-2019, 12:22 AM   #17
KingLT1
KingLT1's Avatar
Drives: 2016 1SS NFG A8
It does, but for those that are changing the exhaust, it's much cheaper to buy the x pipe for manual cars that don't have AFM valves. In order to run a non AFM valve X pipe you need to disable the AFM valves in the FSCM or you get a CEL. or you can leave the controllers plugged in and tie them up under the car but that is hoaky imo.
In a nutshell, the afm valves no longer close if DOD is disabled , but they will still throw a CEL if unplugged from the system and again you don't disable them in the FSCM.
Old 03-02-2019, 04:47 AM   #18
grampa_ss
grampa_ss's Avatar
Good to know, thanks. Can you tell me where the AFM table is in my tune file? I’m using HP Tuner.
Thank you.
Old 03-02-2019, 07:49 AM   #19
KingLT1
KingLT1's Avatar
Thank you.
Under the systems tab. If you don't see it then you need to check a couple things
1)Make sure you are on the latest version of HPT.
2) re-read entire system. A window should pop up with the option to read all 3 controllers. It will cost 1 credit to license the fscm.
Old 03-05-2019, 12:14 PM   #20
ruffryderj
ruffryderj's Avatar
Drives: 2016 camaro ss2/ a8
I have a 16 camaro ss a8 and I want to buy the 14788 corsa double x pipe only if I can tune the afm out and not have a check engine light. is this possible?
ruffryderj is offline   Reply With Quote
Old 03-07-2019, 10:13 AM   #21
gmw0181
gmw0181's Avatar
Drives: 2017 Camaro 2SS A8
Originally Posted by Red1Le View Post
Switching over soon to set of ARH headers and XPipe just got to thinking about AFM on these cars. There is another baffle that closes from my understanding to help with back pressure when it drops to 4cly mode. With the new system that baffle will no longer be in place. Is there potential of running into issues or are people already doing this with zero issues?
It will throw codes: ECM PO69E (fuel pump controller), PCM P12E8, PCM P12F5.
If you turn off AFM it will throw no codes at all for the AFM valves missing.
gmw0181 is offline   Reply With Quote
Old 03-09-2019, 11:39 AM   #22
Richkidd87
Richkidd87's Avatar
Drives: 2016 Camaro 1SS Red Hot
This worked for me thank you
Richkidd87 is offline   Reply With Quote
Old 12-24-2020, 07:06 PM   #23
Snyper25
Drives: 2015 Camaro SS
Originally Posted by jimmypop13 View Post
No. You have to keep the AFM valves. You'll have to cut them out and weld them into the new system or only replace the system up to that point. You can't tune the AFM valves out and you can't leave them hanging. They have to be attached or they will throw a code. There is only one system with AFM valves and that's Stainless Works. They give you the option of AFM valves or dummy mounts for cheaper that you can mount the AFM motors to but there's no actual valves inside the exhaust. It saves money but you'll hear the car sounding like a cylinder when it goes into v4 mode when using the dummy mounts over the actual AFM valve option.
So those are your choices, either transfer the valves to the new exhaust, don't replace that section, or go with Stainless Works over ARH. ARH did not bother to build a system compatible with automatic transmission/AFM cars. Neither did kooks
Maybe someone can help. Recently got a custom catback exhaust, installer removed the OEM pipes and the customs do not have AFM valves. He left the AFM wire and actuator connected to the car and ziptied them to the bottom of the car. All my research suggests that i shouldnt be throwing an AFM CEL but i am. Any reason im still throwing a CEL? Anything i can do to resolve this without tuning since i do not want to void my warranty?
Snyper25 is offline   Reply With Quote
Old 12-24-2020, 07:12 PM   #24
Snyper25
Originally Posted by Fast6.3 View Post
You just need the actuators leaved them plugged in and zip tie them. It will be ok no cel
I did this but it is still throwing a CEL. AFM actuator still connected to the wire harness and ziptied to the bottom of the car. Last time i checked the metal wheel of the actuator can still turn. Everything suggests that i shouldnt be throwing a CEL and i dont want to tune and void the warranty. Any suggestions??
Old 12-24-2020, 09:13 PM   #25
grampa_ss
grampa_ss's Avatar
Maybe you need these: https://wildhammermotorsports.com/16...-2-awe-tuning/
