Old 10-20-2016, 04:53 AM   #15
Eata34
Eata34's Avatar
Drives: 2011 Camaro 2LT
In my 2011 Camaro 2LT V6 RS, I hit 145 on I-82 in Ware County, GA. Let me tell you. That highway is like 15 miles long of nothing but a straightaway. That's my go to pulls. No cops late at night either lol
Eata34 is offline   Reply With Quote
Old 10-20-2016, 08:42 AM   #16
bigd1276
2017 HyperBlue 2SS
bigd1276's Avatar
Drives: 2017 HyperBlue Camaro 2SS
Top speed according to the brochure for the V-6 is 149 mph.
http://www.camaro5.com/forums/showthread.php?t=30755
2010 IBM 2LT RS......Traded for.....
2012 IBM 2SS RS......Traded for.....
2017 HBM 2SS
bigd1276 is offline   Reply With Quote
Old 10-20-2016, 08:48 AM   #17
gdespaux
Drives: 2016 Hyper Blue Camaro/2LT RS
Do our cars not have Redline?
Current:
2016 Hyper Blue A8 2LT RS
Previous:
2010 Victory Red 2LT
I've never had a V8
gdespaux is offline   Reply With Quote
Old 10-20-2016, 09:22 AM   #18
cellsafemode
cellsafemode's Avatar
Drives: 2016 Camaro 1LT
pretty sure the top speed is artificially limited to 149. Plenty of power and gear left to rocket past that. Just needs someone to throw the appropriate rubber on and take it to the salt flats
Old 10-20-2016, 09:30 AM   #19
bigd1276
2017 HyperBlue 2SS
bigd1276's Avatar
The Gen 5s were set with a factory limit of 155. I assume the Gen 6s are limited the same way at 149. You need a tune to get around it I'm guessing.
2017 HBM 2SS
Old 10-20-2016, 10:29 AM   #20
cellsafemode
yea. Just throwing better rubber on isn't going to unlock the speed limiter.
my comment had to do with the fact that the rubber you have on stock just isn't rated to go much faster than 149 without potentially catastrophic failure. So anyone who does intend to hit those speeds should have some that is rated for it.
Old 10-20-2016, 10:35 AM   #21
bigd1276
2017 HyperBlue 2SS
bigd1276's Avatar
True. It's all bout the speed rating of the tires. Only the Gen 5s with the Pirelli Z rated tires could do 155.
2017 HBM 2SS
Old 10-21-2016, 11:17 AM   #22
modestech
modestech's Avatar
Drives: Hyper Blue 2016 1LT V6
I have only briefly been at 138 or so, but didn't want to stay there more due to the wear and heat the tires would have to take. (I have a non-RS). That said, there is a new toll road somewhere in Dallas that is a wonderful place for a late night run on smooth payment.
modestech is offline   Reply With Quote
Old 10-21-2016, 12:55 PM   #23
BSR-1
BSR-1's Avatar
Drives: 17 ZL1 M6 Black
Originally Posted by PolynesianPowerhouse View Post
no clue where you were, don't need to know, but impressive. most will never have the confidence to get that high, even on a test track.
last time I saw numbers there, I was a passenger in my cousin Markus's brabus modded setup on the autobahn at 16.
I'm an adrenaline junkie. As long as the vehicle is safe I can't think of a speed I wouldn't do.
I've been to 170mph (GPS) a few times on motorcycles.
BSR-1 is offline   Reply With Quote
Old 10-24-2016, 09:01 AM   #24
Gen6Rs
Gen6Rs's Avatar
Drives: 16 black RS
I can tell you mine hit 155 twice on the dyno. Had to goto 4th to get pull power read of 269 rwhp. I'm sure with the governor removed they would easily hit over 160 - 170.
tires might explode at that point though.
Gen6Rs is offline   Reply With Quote
Old 10-24-2016, 05:08 PM   #25
BSR-1
BSR-1's Avatar
They would surely go that fast on a dyno (with limiter removed) but not on the street. Too much air to push and not enough HP.
Old 10-24-2016, 05:32 PM   #26
cellsafemode
I've seen videos of 5th gen un-modded v6 rs's doing over 150. The 2016 should easily hit 160-170 without a limiter with just air drag to deal with.
Old 10-24-2016, 05:51 PM   #27
BSR-1
BSR-1's Avatar
I hit 159 and that was it. That's just about redlined in 5th.
When I shifted to 6th it was like putting on the brakes. Just too tall of a gear to pull at that amount of drag.
I seem to remember that drag increases as the square of speed and another 10 MPH will require a lot more HP at those speeds.
Please correct me if I'm wrong here.
Old 10-24-2016, 06:29 PM   #28
BSR-1
BSR-1's Avatar
Do you think I might have gotten a lemon? Maybe I should take it back?
