Old 03-29-2016, 03:13 PM   #15
Modshack
Modshack's Avatar
Drives: 2SS, Hyper Blue
I don't know what your guys are doing, but it likely has nothing to do with the NPP circuit. You can easily wire a toggle to the #51 fuse using a fuse tap, some wire and a switch. This should not F with the computer at all. Since you're talking about 2 different things I suspect maybe their "Kill" switch wiring job is the issue...If you're doing a battery disconnect you would need some pretty big (Battery cables) wiring.
Steve
Hyper Blue 2SS, 6M, NPP, Sunroof, Nav
Modshack is offline   Reply With Quote
Old 03-29-2016, 04:51 PM   #16
ender2664
Drives: 2016 2SS
Originally Posted by SuperSound View Post
Turn on (as in power) or crank? And why exactly do you want it if you don't mind explaining.
Crank
I want it more complicated than just having the keys and pressing a button.
ender2664 is offline   Reply With Quote
Old 03-29-2016, 05:00 PM   #17
ender2664
Drives: 2016 2SS
Is this what you mean? Can I just put one on the starter fuse for a kill switch?
https://www.amazon.com/gp/aw/d/B0146...6693104NR819ZG
Old 03-29-2016, 05:29 PM   #18
SuperSound
SuperSound's Avatar
Drives: '17 Camaro 2SS A8
Originally Posted by ender2664 View Post
Crank
As a theft deterrent? Maybe you don't realize how complicated it is to start a car with a keyless system. Or do you just want it because you want it?
Old 03-29-2016, 05:44 PM   #19
ender2664
Drives: 2016 2SS
I want it for personal reasons. I'm not at all worried about someone stealing my car.
Old 03-29-2016, 05:48 PM   #20
SuperSound
SuperSound's Avatar
Ok all good then. I would maybe find the ignition wire off the "Start" button in the car and use that to wire a hidden switch. Running a switch off a fuse in the engine compartment fuse box seems like it would have more issues. But honestly I'm out of my league here since I've never attempted something like that on a newer car.
Old 03-29-2016, 05:51 PM   #21
ender2664
Drives: 2016 2SS
Thank u for ur suggestion and honesty.
Old 03-29-2016, 06:29 PM   #22
Darth Martel
Darth Martel
Darth Martel's Avatar
Drives: Black 1SS with 20% tinted windows
OK I had to reread your original post. I thought you were just wanting to wire a switch to simulate the fuse pull for the NPP. Honestly though, the theory is still the same for a kill switch for the Ignition. If you pull the fuse for your Ignition, you won't be able to start your car. The only difference here with a kill switch for Ignition is that you'd be tapping into different wires and removing the Ignition fuse as opposed to the NPP. The Ignition wire will most assuredly be a thicker gauge wire, most likely a 12AWG so you'd need the yellow coded connectors or taps. You'd also need a heavier duty switch to handle the current.
2016 Black 1SS w/ MRC, low-gloss black wheels, auto trans. Self-created custom Dark Knight Edition accents. Rotofab CAI with dry filter and sound tube delete, PRAY ported intake manifold and throttle body, Texas Speed cam, Stainless Works headers and exhaust, Skid Mark garage E85 kit, JMS fuel pump voltage booster, Circle D torque converter. Custom E85/mod tune by Jannetty Racing.
Darth Martel is offline   Reply With Quote
