#15 |
The Dogfather
Drives: #1 off the line for a customer. '16 Join Date: Oct 2015
C7 uses a completely difference suspension than the camaros. C7's use a leaf spring setup and you can lower a c7 by literally moving bolts to another notch and done. No need for aftermarket or anything. Just need to jack up the car and get to it haha.
#16 |
![]() Drives: 2021 Corvette Z51 Join Date: Dec 2014
Correct on Corvettes having factory height-adjustment, but there are no notches as you mention, just screw the bolt in or out. You can generally go about a 1/2" up or down from the factory height with the factory bolts. Lower if you go with aftermarket lowering bolts. I took mine all the way down on the factory bolts and MRC still functions properly with no change in ride quality.
#17 | |
The Dogfather
#18 | |
![]() Drives: 2016 Camaro SS Convertible Join Date: Oct 2011
Right, understood but my point the fact the it is mag ride would make not difference in lowing the car. Are the Mag ride and the standard struts the same size. If so should not be an issue. |
#19 |
The Dogfather
Gotcha. But there must be something we are missing when it comes to being an "issue". If not, they would've already released lowering springs for the MRC as they already did for the non-mrc cars.
#20 | |
![]() ![]() Drives: SW 1SS 1LE / Jeep XJ Join Date: Mar 2016
It would be interesting to see if GM comes out with a lowering kit for the MRC since they do for their non MRC shock/spring setup. Randy already mentioned driving the 2SS that MRC is a phenomenal system from the factory, so Id hope GM will come out with a lowering kit themselfs. |
#21 | |
The Dogfather
#22 | |
corner barstool sitter
Drives: 08 Mustang GT, 19 WRX Join Date: Jul 2012
Damping requirements in rebound go up as you make the springs stiffer (which any lowering spring even halfway worth its salt should be). Otherwise you'd generally expect the overall result to move closer to the ride quality end of the ride-handling spectrum and cost you a little tire grip. I don't think it'd be as difficult to reflash the MRC module as it will be to get GM to let go of the programming or only just the access to it. Norm
'19 WRX 6M (the family sedan . . . seriously) |
