Old 02-25-2016, 03:54 PM   #15
Phidelt59
Phidelt59's Avatar
Drives: 2016 Camaro SS
Originally Posted by kcpoloman View Post
Does the 16 SS support no lift shift?
I don't think so.
Camaro 2SS
Hyper Blue Metallic/Kalahari
6M, NPP, MRC, NAV
Black 5 Spoke
Phidelt59 is offline   Reply With Quote
Old 02-25-2016, 04:01 PM   #16
My87z28
Drives: 1987 Z28, 385cid, '16 Camaro 1SS
Originally Posted by Phidelt59 View Post
5th Gen ZL1 had it. It works well. The ZL1 also had no lift shifting. I finally finished my break in mine and it works the same. Pretty cool how it works. Just put it in sport or track mode, press the traction contol button twice for competition mode, press in the clutch and floor the gad pedal, wait for the revs tostabilize and smoothly let off the clutch little quicker than normal shifting. Don't dump it super quick and off you go.
Hmm, good info. I never owned a gen5. So with this launch control, when pressing the accelerator all the way down, the RPMs will stop/level out at a certain RPM instead of going up to redline? And one it stops (guess of 3000ish RPM) you just let out the clutch?
My87z28 is offline   Reply With Quote
Old 02-25-2016, 04:11 PM   #17
timmy8784
Drippin' Wet Auto Detail
timmy8784's Avatar
Yes, it's pretty simple on the M6.
You press the traction control button twice to turn off along with Stabilitrak and enter Competitive Mode. It must be in either Sport or Track Mode and the wheels must be pointed straight.
You put in the clutch and then you put the Accelerator all the way to the floor. The RPM's will level out and stabilize. Then you quickly let out the clutch and away you go.
I have had kinda mixed results with the launch control. Guessing it will be helpful for less skilled drivers to launch without spinning. However, the times don't seem to be that great so it's not the best for trying to get the best 0-60 time IMO
timmy8784 is offline   Reply With Quote
Old 02-25-2016, 05:18 PM   #18
Medic701
Drives: 2017 ZL1
Well I own a 2SS with 6 speed I did launch control today 0-60 3.9sec. I shifted and never let off the gas pedal. did have some wheel spin tell the computer took over and lowered the RPM automatically. the engine rev. to about 4500 RPM and i dumped the clutch fairly quick. I was suppressed how much wheel spin there was. i noticed a decent amount of tire smoke. Tires spun but not like a lot of spin for about 10 feet. felt nice.
Medic701 is offline   Reply With Quote
Old 02-25-2016, 06:38 PM   #19
lt4camaro
lt4camaro's Avatar
Drives: 2021 LT1 10 speed auto
I don't think so.
The gen 5 ZL1 had no lift shift. That was carried into the CTSV and The C7 vette. Your 16 SS should have no lift shift. You do not need to do anything to activate it, just powershift like the old days (do not lift off the gas). If you have never power shifted a manual I would practice shifting a warmed up car with the engine off. Just go thru the motions with the gas pedal to the floor, stab the clutch and shift as fast as you can for each actual shift 1-2, 2-3, 3-4 .
The biggest issue is to train yourself not to lift and you have to initiate the shift.
lt4camaro is offline   Reply With Quote
Old 02-25-2016, 07:32 PM   #20
Phidelt59
Phidelt59's Avatar
I'll have to try it. I'm sure it doesn't feel natural at first but I'll practice it first for sure.
Camaro 2SS
6M, NPP, MRC, NAV
Black 5 Spoke
Old 02-25-2016, 07:37 PM   #21
bybcous
bybcous's Avatar
Drives: 2016 Hyper Blue 1SS
I have not been able to get this to work on my a8, has anyone with automatic got it working. I pressed twice, then held foot on brake, and pressed gas hard, but the tire's just spin, like I'm trying to do a burnout, what am I doing wrong.
1ss/Auto-Hyper Blue
DELIVERED 12/29/15
Old 02-25-2016, 08:50 PM   #22
1709
9.56@144.09
Drives: 2013 zl1 black
there is no launch control on an automatic. any one who said there is is full of shit.
1709 is offline   Reply With Quote
Old 02-25-2016, 09:11 PM   #23
timmy8784
timmy8784's Avatar
When did you shift?
Old 02-25-2016, 09:38 PM   #24
Stex
Drives: 67 goat, 69 goat ram air III
Yep good advice but: all we ever did in the "old days" was power shift when serious about time or other car. And trust me they were long throws. Now one has a rev limiter , no? Also, miss a shift: lift right foot. In the "old days" Not power shifting when pressed for performance was referred to as Sunday driving.
But old days off show room performance to now show room, we were a lot slower even if you do not power shift. Enjoy how quick they are now because ,like before, it can go away.
Edit: As quick as they are now, I would modify my old days and keep these rides to the track, strip or very wide open roads. No red light drags as you would be all over someone just hitting second for a blink. And street racing (changing lanes) was never done in the "old days".
Stex is offline   Reply With Quote
Old 02-25-2016, 09:59 PM   #25
Medic701
Drives: 2017 ZL1
Originally Posted by timmy8784 View Post
When did you shift?
I think around 5500 6000 I was not looking at rpm, i was going by engine sound, Also fuse 51 npp pulled, love the sound better then track mode
Old 02-25-2016, 11:15 PM   #26
G.Edwan
Drives: 2SS Sliver BS MRC NPP A8
Check this video. Steps for launch control
http://youtu.be/xHJ2gZwT49g
G.Edwan is offline   Reply With Quote
Old 02-26-2016, 08:22 AM   #27
63falcondude
63falcondude's Avatar
Drives: 16 Camaro, 11 Stryker, 00 Explorer
You sure about that?
NGM, 2SS, 6MT, NPP, MRC, Nav, Kalahari, Grey Wheels
1100 12/14/2015
3000 1/8/2016 (TPW 2/1)
3800 2/1/2016
5000 3/5/2016
63falcondude is offline   Reply With Quote
Old 02-26-2016, 10:00 AM   #28
1709
9.56@144.09
that's not launch control. why did you not do it then. show us in the video, step on the brake and push the gas to the floor and show us what happens. you would need some kind of 2 step controller or trans brake.
