Old 06-22-2016, 08:17 AM   #15
LesBaer
FMPG
LesBaer's Avatar
Drives: 2016 2SS
Has anyone here used Braille batteries batteries before?
ARH 1 7/8" ceramic coated full sys w/NPP; Maggie 9.2psi (85mm); Jannetty rough idle cam(TSP), tune and LT4 fuel system; Forgeline VX1 Black PVD (20x10,11); R88R 315's; ALPriority; BMR rear arms, bushings, DS loop; RF intake (red); nGauge
93 octane: 712rwhp, 654rwtq / E85 (E66 mix): 734rwhp, 674rwtq (SuperFlow Dyno)
LesBaer is offline   Reply With Quote
Old 06-22-2016, 08:35 AM   #16
nvrsatisfied
nvrsatisfied's Avatar
Drives: 2016 SS
Batteries for the blind?
1SS Summit White Coupe MRC NPP A8
Ordered 1/12/16
TPW 2/15/16
nvrsatisfied is offline   Reply With Quote
Old 02-21-2018, 10:58 PM   #17
16WhiteSS
Drives: 2016 Camaro 2SS 6spd
I hate to necro an old thread, but since this is the only information regarding the SS battery type that pops up in a google search; I have to add that my SS has an AGM battery from the factory.
Where did this info come from:
Originally Posted by iPODFAN11 View Post
V6 cars use an AGM, group 48 battery, ACDelco 48PG. V8 cars use a flooded (lead/acid) 94 series battery , ACDelco 94RPG (same as V8 Silverado/Sierra).
16WhiteSS is offline   Reply With Quote
Old 02-21-2018, 11:06 PM   #18
Tenfive
Tenfive's Avatar
Drives: 2017 1SS camaro ,2SS a 68 + 08 C6
Advanced Glass Matt is in the SS
Tenfive is offline   Reply With Quote
Old 02-21-2018, 11:10 PM   #19
Glen e
Retired from Car mfrs....
Glen e's Avatar
Drives: 2LT RS/HR-V
Both cars get an AGM.
Old 02-22-2018, 10:56 AM   #20
Blazin383
Blazin383's Avatar
Drives: 2016 SS
Is the AGM battery compatable with the standard Battery Tender trickle charger?
Blazin383 is offline   Reply With Quote
Old 02-22-2018, 11:20 AM   #21
Glen e
Glen e's Avatar
Drives: 2LT RS/HR-V
Yes, But a trickle charger is a bad idea when the maintainers you can get for 30 bucks these days are so cheap. A trickle charger won't shut off and will over fry the battery, whereas a maintainer new tender will automatically shut it down and just float the charge when it needs it.
Old 02-22-2018, 12:05 PM   #22
WhyUMad1LE
Drives: 17 SS 1LE
What's the benefit of AGM?
Old 02-22-2018, 12:12 PM   #23
Glen e
Glen e's Avatar
Drives: 2LT RS/HR-V
Google shows:
Advantages
Spill-proof through acid encapsulation in matting technology
High specific power, low internal resistance, responsive to load
Up to 5 times faster charge than with flooded technology
Better cycle life than with flooded systems
Water retention (oxygen and hydrogen combine to produce water)
Vibration resistance due to sandwich construction
Stands up well to cold temperature
Less prone to sulfation if not regularly topping charged
Has less electrolyte and lead than the flooded version
Old 02-22-2018, 01:36 PM   #24
Cgocifer
Cgocifer's Avatar
Drives: 2018 1SS 1LE, 2015 RAM Ecodiesel
Good to know, was trying to figure it out since I have a fancy Optima charger. It has several modes for several battery types. I gave up and just let it default to the safe for all maintenance/trickle phase. :-/
If it is an AGM, I can chose that from the menu. Anyone know if the 1LE SS is the same baytery as the SS? 2018? We sure they are AGM since others have said lead acid?
Cgocifer is offline   Reply With Quote
Old 02-22-2018, 01:42 PM   #25
Cgocifer
Cgocifer's Avatar
Looked it up at AC Delco.
Battery*
Part Number:**48AGM
Product Notes:*
Automotive AGM Battery
All; BCI 48, minimum vehicle Reqment: CCA 700/RC 120; OE replacement; Battery is vented to outside of vehicle; AGM Valve Regulated Lead Acid (VRLA) is Reqd
Per Vehicle:*1; Years:*2016-2018
Old 02-22-2018, 03:09 PM   #26
camaro5
camaro5's Avatar
Drives: X-15 Velocipede
Optima is launching new AGM group H6 and H7 batteries this spring.
Camaro uses AGM H6
OR
MT7-48 H6
https://www.interstatebatteries.com/products/mt7-48/h6
Go from the presence of a foolish man, when thou perceivest not in him the lips of knowledge
General Motors ASEP, A.S. Automotive Technology, Telecommunications Specialist, CISCO Network Engineer
STANDARD DISCLAIMER
camaro5 is furnishing this information "as is". camaro5 does not provide any warranty of the information whatsoever,
whether express, implied, or statutory, including, but not limited to, any warranty of merchantability
or fitness for a particular purpose or any warranty that the contents of the information will be error-free.
camaro5 is offline   Reply With Quote
Old 02-22-2018, 10:02 PM   #27
guitarman8373
guitarman8373's Avatar
Drives: 2016 2SS Camaro fully loaded.
You think those battery prices are bad, look at the prices for marine batteries.
guitarman8373 is offline   Reply With Quote
Old 02-22-2018, 10:09 PM   #28
JRS
JRS's Avatar
Drives: 16 camaro M6/ 18 ZL1 camaro A10
Both of my camaro's have agm batteries for sure, ss and zl1 but in another post some people said they had standard acid filled batteries. I don't remember the post but I kind of thought that might have been the reason for some of them having slow starting problems which turned out to be wrong.
JRS is offline   Reply With Quote
