Old 10-03-2015, 05:57 PM   #15
dragonZ28
Drives: 2001 T/A, 2010 2SS/RS, 2006 Z06
Heads, Cam, AFM delete, high-stall converter, bolt-ons, tires, diet. 10 second car - all day.
This will all come after testing the car to make sure all mechanical function is good.
dragonZ28 is offline   Reply With Quote
Old 10-03-2015, 11:13 PM   #16
alfonsoj23
Drives: 2014 camaro ls
Originally Posted by Curr View Post
Tune as in take it to a dyno shop, let them change things like timing, AFR, etc to give it some more power. Most factory tunes are pretty conservative, and will leave horsepower on the table.
Be aware, this can void your powertrain warranty if something goes wrong and the dealer / GM denies repairs.
ohh ok thanx for warning me! & also do you think it's necessary to do it or nah?
alfonsoj23 is offline   Reply With Quote
Old 10-03-2015, 11:40 PM   #17
joemosfet
joemosfet's Avatar
Drives: 2014 Camaro SS
Depends on what you mean by necessary.
Obviously a tune isn't required for an acceptably functioning car, such as a vehicle coming from the factory, but certainly, like Curr mentioned, that tune from the factory is conservative in controlling the power the engine makes (to prevent knocking) but if a driver consistently uses quality high octane fuel and/or live in high altitude environments, those parameters can be tweaked to allow even more power. But again, a tune is not necessary.
Any exhaust modification downstream of the catalytic converter's and its O2 sensors definitely wouldn't require adjustments to tuning.
But, If you put a supercharger or set of turbos on, you'll definitely need a tune - the engine would have no idea how to deal with positive pressure in the intake manifold nor the signals coming from the modified sensor to support it.
Some will say that even a cold air intake requires a tune. And, technically, they're right. Changing the intake flow characteristics can cause air flow senors to give false readings. Generally the error isn't enough to cause an issue, and the engine's computer has enough room in it's self-adjustment that there can even be a power benefit from it, and thus I'd try a cold air intake without a tune, without hesitation.
SOLD: 2014 Camaro Coupe 2SS/RS M6 Blue Ray Metallic, NPP, Nav
2014 Stingray Premiere Edition Coupe #142/500 Z51 3LT M7 Laguna Blue, Magride, NPP, Exposed Carbon Fiber Roof, Carbon Fiber Dash, Suede Wrapped Interior
Canceled: 2016 Camaro Coupe 1AK37 2SS Coupe, G7E Garnet Red, BRJ Adrenaline Red Trim, F55 Magnetic Ride, NPP Exhaust, CF5 Sunroof, 56R Gray Split spoke w/ machined face, RN2 LPO Illuminated Bowtie, VYW Premium Floor Mats, W2D LPO Cargo Net
joemosfet is offline   Reply With Quote
Old 10-04-2015, 12:25 AM   #18
JAG47
Drives: Future 2016 camaro
285 or 305 tires square setup. Thicker anti roll bars. Custom made Strut Tower Brace.
JAG47 is offline   Reply With Quote
Old 10-04-2015, 12:11 PM   #19
Tr6
The Dogfather
Drives: #1 off the line for a customer. '16
Have NPP, and MRC thus no need to get a catback or touch the suspension. Already ordered Diablo i2 and will be working with DiabloLew to get my tunes done
AFE intake
Borla Xpipe
WeaponX ported throttle body
WeaponX ported intake manifold
Tower brace (not sure which one, may end up getting the convertible SS oem one)
Down the road, gonna grab a procharger as well.
Tint
Escort hardwire kit with red light
Tr6 is offline   Reply With Quote
Old 10-04-2015, 01:15 PM   #20
mt3130
Drives: Coupeless :(
  • Black bow ties/flow tie (if it becomes available)
  • Ceramic window tint
  • Strut tower brace
  • Blade spoiler (depends on price, look, and work involved)
  • Wheels & tires (after OEM run flats wear out and assuming OEM wheels are on the heavier side)
mt3130 is offline   Reply With Quote
Old 10-04-2015, 04:06 PM   #21
Imp
Dodges all the cones
Imp's Avatar
Drives: Soon
2SS with NPP, so...
Tint
Tires
Yeah, that's about it.
Imp is offline   Reply With Quote
Old 10-04-2015, 04:42 PM   #22
alfonsoj23
Originally Posted by Sledgehammer70 View Post
- BBK Headers
- BBK Intake
- BBK Throttle Body
- Tint
- Spoiler CF wrap
- Splitter CF wrap
How much would it cost to carbon fiber the spoiler?
Old 10-04-2015, 08:27 PM   #23
Tr6
The Dogfather
Originally Posted by mt3130 View Post
[LIST][*]Black bow ties/flow tie (if it becomes available)
You could've ordered them with your order. I ordered my 2ss in August WITH the black bow ties. I am assuming you can just call your dealership and have them order them and put em on before you take delivery.
2SS, Garnet Red with Adrenalin red, NPP, MRC M6 coupe
#33 off the line #1 order for Customer.
Build thread HERE!
Story of my delivery HERE!
Old 10-04-2015, 11:17 PM   #24
LesserO2Evils
GM repeat offender...
Drives: 16 2SS
Yup. A whopping $145. And, you dont have to worry about fitting film, peeling, or chipping paint.
'16 2SS, Summit White. A8. MRC. NPP.
Ordered:09/03/15. Received 12/22/15
INCOMING: ‘22 ZL1, Satin Steel. A10. PDR.
Ordered: 03/02/22.
LesserO2Evils is offline   Reply With Quote
Old 10-04-2015, 11:50 PM   #25
DenverTaco07
DenverTaco07's Avatar
Driver Mod, definitely Driver Mod, day one!
Old 10-05-2015, 05:01 AM   #26
amerhash28
amerhash28's Avatar
Drives: camaros in his dreams
NPP
,MRC
,6 PISTON brembos
Cold air intake
Window tint
Gloss black roof
Spoiler CF wrap
Black out the Front bumper's center(zl1 style)
_the end
amerhash28 is offline   Reply With Quote
Old 10-05-2015, 09:41 AM   #27
NASTY99Z28
Drives: 99z28 with bolt-ons and a mwc fab 9
I think just tires can make it an 11 second car.
probably but I'd want it to run that in any weather. Might just need a tune and tires to make it happen.
Necessary to get all the power out? Yes. If you don't care about it then no it'll drive just fine.
Depending on the heads and cam that'll be a very low 10sec car. Dare I say possible a 9.99 car with everything being perfect....
That's not a bad price at all.
I like my woman like my milk shakes, THICK!!!!
NASTY99Z28 is offline   Reply With Quote
Old 10-05-2015, 09:48 AM   #28
bdavies11
Originally Posted by KMPrenger View Post
GM is supposedly doing an intake for the car, so I'll likely go that route, and if I don't think the car is low enough, I may go with their lowering kit when it is available, although I think the stock height looks pretty dang close to my tastes as it is stock.
Just curious, where did you hear about a lowering kit from GM? How does that work? Shorter springs? Will the dealer install this after the purchase?
Sorry so many questions. Ha
bdavies11 is offline   Reply With Quote
